Question about Cisco 678 Router
Router restart automatically after some time and gone in cold start
    Sergeant:
  • 324 Answers
Reset ir manually
Posted on Sep 08, 2009
Can't connect to the internet with router
1.Powercycle equipment ( Unplug power wait 15 seconds then plug back in. 2.Make sure connections are tight in to the router and to the modem. 3.Check you network settings Windows XP: Start/Run/Type ncpa.cpl and hit ok. Check and make sure that your connection doesnt say Connected Firewalled if it does to the left hand side you will see change windows firewall settings turn to off.If it doesnt say that double click the connection hit properties click on internet protocol and hit properties again,ensure that obtain ipaddress automatically is checked as well as obtain dns server automatically If not check them both and restart your computer. Windows Vista/7 Start/Search bar type ncpa.cpl right click on your connection and hit properties uncheck ipv6 and click on ipv4 and hit properties. After Ensure obtain ip address automatically is checked as well as Obtain DNS server automatically is checked restart computer. 4.Use command prompt: WIndows XP: Start/Run/Type cmd and hit ok Windows Vista/7 Start/All Programs/Accessories/Right Click Command Prompt and hit run as administrator. 5.Type in Command Prompt the Following Commands Each line is a seperate line is a new command simply press enter after each. netsh int ip reset reset.log netsh int ip delete arpcache netsh winsock reset ipconfig /flushdns 6.Restart Computer Final: If you still have issues connecting refer to router manufacture.
Jan 12, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I was able to connect to my router but I have to manually turn on the wireless internet switch to "On" each time I restart the computer. Then I have to select the router and connect. Is there...
1. switch to "On" each time is need
2.automatically connect to your router need somesetting in your computer
3.you can chang the QUNE in wireless list then select auto,then del other wireless AP name.
Dec 29, 2010 | Sylvania G-Netbook
1989 Chevy K2500 350 will not restart after warmed up? I have replaced Heads, reset timing 0 TDC new plugs, coil, cap, button, module and pick up coil. Engine starts cold runs great but will not restart...
tdc is usually set at 8 degrees BTDC for an automatic and 4 BTDC for a manual transmission. This may help. Does the engine run rough at start up being set at 0TDC?
Oct 20, 2010 | 1988 Chevrolet K2500
Auto restart
Try Router Commander from www.routercommander.com. This program was designed to solve this kind of problems and fully compatible with this router
Jul 13, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Auto restart
if your computer auto re start. put little bit cool past on the in side of heat sink. if this problim not gone. chang your power supplay.
May 29, 2010 | Intel Motherboard
WGR614 v6 Fails to connect to internet, no wirelss signal
mabey there is a problem with the LAN cable or a connection error
Dec 12, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
It's performance has gone down considerably as the time passed..
Turn the router off.
Disconnect the electrical power.
Wait a few minutes.
Reconnect the power & restart it.
Restart your PC.
Search for a 'speedtest' web-site, to measure the performance.
Oct 09, 2009 | D-Link Computers & Internet
Hard starting will not restart after warmup
Try this: The next time you run the trimmer, and it begins to die, loosen the gas cap. It should start running again. This means that the gas cap is clogged. Clean the holes out of gas cap, or buy a new one. (If this doesn't help, give a more detailed explanation the next time.)
Jim
Jun 05, 2009 | Husqvarna 28cc Gas Line Trimmer
Automatic restart of the router
try checking ur modem button or reinstall windows .if problem presists then contact me at afzaalafridi@rocketmail.com
Apr 30, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Connection keeps cutting off
Hi, I have also faced the same problem many times....
Try to restart the router and see for the connection light to turn green.... then connect to internet..
This happens due to heavy load. When thre are many users your router will restart automatically.
If this still continues ask your tech guy to change the line.
Feb 01, 2009 | Westell Wirespeed VersaLink...
Cisco 678 Router Logo
302 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
