Question about HP Compaq Presario V2000 Notebook
Plugged in running on ac power doesnt charge battery
Have not changed anything, it just happened on its own.just stopped charging battery , checked connections and are good
    President:
  • 1,865 Answers
Battery could be bad, charger could be bad, or the jack needs to be replaced. If you cannot replace the jack yourself, I can do it for you.
You'll need a multimeter to troubleshoot the problem
Posted on Sep 08, 2009
I have an ACER M5-581 and when the battery gets low and I am working on it and I plug it in to an AC outlet and continue to work it will show a charge for a few seconds and then stop charging. I have to...
If the battery is actually taking a charge but it seems the battery only lasts a short time after charging... it's time to buy a new battery. They eventually won't hold a charge very long
Note this is a separate problem then the case where the AC cable is plugged in yet the battery takes NO charge (what happens when the power jack breaks its connection to the computer so NO power reaches computer at all via AC adapter.
http://www.aurabuy.com/cheap-4400mah-battery-for-acer-travelmate-8473t-8573-8573g-8573t-4370-5335-5340-7340-tm5742-4740z-8573tg-5742z-paypal.html
Mar 31, 2013 | Acer Aspire One PC Notebook
Asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Jul 12, 2012 | ASUS Computers & Internet
When i charge my acer aspire the power button flashes
The DC jack in the laptop is showing early signs of intermittent issues, the jack is solded to the motherboard which sometimes breaks free over time, this is something that will eventually need to be addressed.
Mar 25, 2012 | Acer Aspire 5336-2283 Notebook
The battery will not charge unless the computer is off. it runs on the battery even if its plugged in why? if i unplug the the adapter then plug it in it charges for a few seconds and then stops and then...
1. First remove the Battery, clean the Battery contacts with the pencil eraser and insert the Battery in the Computer.
2. Connect the AC Adapter (Battery charger) securely to the Computer and the Power outlet.
3. If the issue persists, try connecting the AC Adapter to different Power outlet.
4. Make sure that both the connecting points (DC IN port on the Computer and the Power outlet plug) are securely connected and not loose.
5. If the issue persists, try with different AC Adapter.
Good Luck!!!!!!!!!!!!!
Nov 18, 2009 | HP Pavilion zd8000 Notebook
Charging it doesnt want to charge the battery and wont run off ac power . the battery is bad but it still wont run on ac power
Laptops must have a good battery in order to operate. If you take a good laptop, and remove the battery but leave it plugged in to AC it will not run.. Go out and get a new battery and you should be fine.
Aug 11, 2009 | Computers & Internet
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Old battery not charging plug in charger green light goes out
If the system will not power on, and the LED on the AC adapter goes out when plugged into the system, then the most likely senario is the motherboard has failed. Remove the battery, Wireless card, Drives, RAM and connect the AC adapter see if anything changes. If no change, the MB is most likely bad.
May 01, 2009 | Dell Latitude D505 Notebook
Dell laptop doesnt charge only runs on ac power
How long have you had the laptop as all batteries even rechargeable have a limited life span. Dell laptop batteries normally have a life span of 1 to 2 years, so you may need to buy a new one
Apr 19, 2009 | Battery Technology Computers & Internet
Power supply issues
Have you checked the AC power pin (where the AC cord plugs in)?
Chances are that the pin has come loose from tugging and pulling on it. When this happens the battery charging is intermittent at best. The parts to fix this problem are usually under $10 but the labor if you take it in is gonna run $100-$200. You can repair it yourself if you're comfortable working with electronic components. Not that tough. WHen you get it fixed, invest in a Cable Retention device to keep it from happening again.
Here's a short video that talks about it. . .
Feb 26, 2008 | Dell Inspiron 710m Notebook
HP Compaq Presario V2000 Notebook Logo
103 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
