Question about Sony SDM-HS75P/S 17" LCD Monitor
Sony information window keeps displaying on the screen
    Scholar:
  • 154 Answers
That will happen if the menu button is pressed and held down. Verify that the menu button is not stucked.
Posted on Apr 12, 2010
I have Sony VAIO VGN-SZ2XP/C, installed Windows 7 All fine except the display is smaller than the display screen.
right click anywhere on your screen, find the screen resolution tab and click on it. change your display to 1920 by 1080. if this doesn't work, try a few of the other screen resolutions.
Feb 15, 2015 | Sony Computers & Internet
Tip
SERVICE MODE AND POWER FL PANEL CIRCUIT
1. Main Functions
• Diag
Performs unit test of devices installed on the board.
• Display Error Log
Error log is displayed. Displayed contents can also be saved in an USB memory device.
• Factory Initialize
Restores the unit to its factory settings.
• Network
Checks the wired network connection.
• Version Up Not used.
• System Information
Displays the system information of the unit.
Displays information such as the software version, drive information, etc.
• EMC Test Mode Not used.
• Drive
Write drive OP data and check drive.
2. Menu Tree
3. Service Mode Menu (Top Menu)
This is the top menu of service mode.
Each function is accessed from this screen.
Operation:
[1] Moves to Diag screen
[2] Moves to Log screen
[3] Moves to Factory Initialize screen
[4] Moves to Network screen
[5] Moves to Version Up (DISC version update) screen (Not used)
[6] Moves to System Information screen
[7] Moves to EMC test mode screen (Not used)
[8] Moves to Drive screen
[9] Moves to HDD mode (Not used)
[UP]/[DOWN] Moves the cursor [ ENTER] Moves to the screen of the item selected with the cursor.
FOR MORE CHECK THE LINK ...
Electronics Equipment Repair Center
on Feb 14, 2015 | Sony Televison & Video
Why does my popup open out side my screen
Check your display settings. Do you have multiple monitors? Which operating system are you using?
Jun 24, 2014 | Microsoft Windows 7 Ultimate for PC
Laptop screen keeps flickering
Changing the refresh rate might help.
Right click on the screen. In the box that comes up select Graphic Properties. In the window that comes up click information. Box that comes up select monitor tab. Will have a list of display sizes and refresh rates that are supported by your monitor. Once you have that information you can make changes.
FYI: Acer says max resolution 1920 X 1080 with 75 HZ refresh rate.
Also if you have a tube light or speaker system close to the monitor then try moving it further away.
Apr 30, 2012 | Acer Computers & Internet
OS won't start on Sony VGC-RB60G
To resolve this problem, start your computer in Safe mode, remove the display adapter, rename the .inf files that are associated with the display adapter drivers, restart your computer in Normal mode, and then update your display adapter drivers. The following steps describe this procedure in more detail:
  1. Start Windows in Safe mode. To do so:
    1. Restart the computer, and then press F8 while the computer starts.
    2. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Safe Mode, and then press ENTER.
    3. Use the ARROW keys to select the operating system to start, and then press ENTER to start Windows XP in Safe mode.
  2. In the message that states that Windows is running in Safe mode, click Yes.
  3. Click Start, click Run, type msinfo32 in the Open box, and then click OK.
  4. Under System Summary, expand Components, and then click Display.
  5. In the right pane, note the information that corresponds to the INF File item, for example, Nv4.inf, Oem0.inf, or Atim128.inf.
  6. Quit the System Information utility.
  7. Click Start, right-click My Computer, and then click Properties.
  8. Click the Hardware tab, and then click Device Manager.
  9. Expand Display adapters, right-click the display adapter, and then click Uninstall.
  10. Click OK.
  11. Click Start, click Run, type cmd, and then click OK.
  12. In the Command Prompt window, type the following commands, and then press ENTER after each line: ren %systemroot%\inf\INF file name from Step 5.inf *inf.old
    ren %systemroot%\inf\INF file name from Step 5.pnf *pnf.old
  13. Close all open windows, and then restart the computer in the typical manner.
  14. Log on to Windows by using an account that has administrative privileges, and then wait for Windows to detect new hardware.
  15. When the Found New Hardware Wizard starts, click Cancel.
    If you receive a stop error after you remove the updated display drivers, restart the computer and use the Last Known Good Configuration option. To do this, restart the computer, and then press the F8 key while the computer starts. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Last Known Good Configuration, and then press ENTER.
    If you receive a "System Has Recovered from a Serious Error" message when Windows starts, restart the computer again. This error message does not recur.
Oct 06, 2009 | Sony VAIO RB60G (VGCRB60G) PC Desktop
Information window keeps displaying on the screen
just release the menu button of the screen make sure it is not stuck.
Sep 08, 2009 | Sony SDM-HS75P/S 17" LCD Monitor
INFORMATION WINDOW KEEPS DISPLAYING ON THE SCREEN
Press once the Input button. The menu appears. Press the Input button again and hold it. Now this is reduced to the problem of blocking the Input button (holding it with something). (Not very technical but then again neither is the restart when the computer blocks :D) Cheers
Jul 19, 2009 | Sony SDM-HS75P/S 17" LCD Monitor
BRAVIA - Information bar on top of screen won't go away
You can turn off the information display using the user menus.
also hitting the display button should make any and all OSD information go away.
Jul 09, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Monitor keeps displaying model and serial information
@ baller98_199; did you ever get a solution to this? I'm having the same problem with the same monitor!
Mar 13, 2009 | Sony SDM-HS75 17" LCD Monitor
Sony SDM-HS75P/S 17" LCD Monitor Logo
191 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
