Question about Microwave Ovens
My hotpoint microwave has the kind of turntable that goes aroung while cooking. Yesterday it just stop going aroung. How can I fix this and if not will it burn up the microwave up if the turn table dosn't function right? Well it is pretty knew, and we keep it clean, It is mounted above our stove. and it dosn't take abuse such as slamming doors and such. It was manfactured in 2005. The model #RVM163WKO1 it has KWI.58 and was manfactured by GE.
  • 5,911 Answers
The problem is probably a burned out turn table motor. They wear out without warning and just stop working (no abuse required - just happened to me this weekend too). The motor can easily be replaced by following these steps:
1. Unplug the microwave oven
2. Remove the panel screws on the bottom panel UNDER the microwave. With the screws removed, the panel will drop down exposing the motor.
3. Open the door and reach inside and remove the glass tray and carousel.
4. Lift up on the small coupler (what the center of the tray rests on) and it should come off the motor shaft.
5. Remove the electrical connection from the drive motor and the mounting screws and the motor is out.
6. Reinstall the new motor in the reverse of the steps I just gave you.
This repair should take 30 minutes or less. The part number for the motor is WB26X10168 and can be purchased at appliancepartspros.com for about $38. This was the cheapest place I could find it for you.
NOTE: Running the microwave without the carousel will not cause any damage to the oven itself. This is primarily used to ensure food is cooked evenly. You can continue to use your microwave until the part arrives.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Sep 08, 2009
Testimonial: "Great answer!Not hard to follow. Betcha when Iprint these out and had them to my husband he will have no problem following(Until he see's me wathching"
  • Jeff Rockwell
    Jeff Rockwell Sep 08, 2009
    FYI: There is no belt driving the turntable motor.
  • 574 Answers
There's a small motor that I believe has a belt that turns the turntable. You'll have to take microwave apart to get to it.
My GE Profile Countertop Convection/Microwave Oven PEB1590DMBB Has stopped working.
It sounds like you may have a shorted cook relay on the control circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | General Electric PEB1590DMBB: Profile 1.5...
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Light goes out and turntable stops, but still hums like power is still on.
You have a bad door switch that will need to be replaced.
May 13, 2012 | LG Microwave Ovens
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
I have a Hotpoint Counter Saver Plus Microwave model RVM1435wd. The turntable does not rotate. How can I fix it?
If your turntable is not going around you may have one of two problems: the coupler under the glass tray may be worn and in need of replacement or the turntable motor needs to be replaced. Hope this helps.
Jan 24, 2010 | Hotpoint RVM1435 Microwave Oven
Clock works, timer works-but turntable and other functions stoppe
you have a bad control board . this board had 2 relays one for the magntron and one for the turntable and the cooling fan together . when the turntable goes out so does the cooling fanm and the microwave overheats ...... there is no good fix for this , the control will cost more than a new microwave . please do not use with this happening . i have see them start on fire when it overheats . please be carefull good luck
Jan 15, 2009 | Emerson MW8108P Microwave Oven
I own a Advantium 120 Oven. I love my microwave however there are times that I need to stop the turntable in order to reheat or cook something in a casserole dish. How can the turntable be turned off?
I guess my problem cannot be fixed. I was told that my microwave turntable is automatic and cannot be turned off, therefore, if you have a 9 1/2 x 11 dish and need to reheat something it cannot go in the microwave because it does not fit .
Aug 26, 2008 | Microwave Ovens
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
