Question about GE Refrigerators
Frost Buildup on GE Profile Arctica Side by Side Refrigerator
Frost buildup continues just above the icemaker and this is has become an ongoing issue. Temperature readings are in the normal range(s). Nothing that we know of has changed on the unit (parts loose, missing etc.)
Model is: PSS25SGNA BS
Other issue: icemaker water dispenser always drops additional water after dispensing the requested amount. This is more of a cleaning nuisance but was just wondering if anyone had experienced this same issue and whether there was an easy / inexpensive solution.
4 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: frost buildup around icemaker, what cause this?
Either the auto-defrost timer is not working properly or there is a lot of moisture and condensation that is building up due to humidity.
Posted on Sep 22, 2009
  • 35 Answers
SOURCE: excessive frost buildup in bottom freezer section of Kenmore refr
In my case, this happens when the drawer does not seal properly. If I am aware of this, I don not have the snow build up. My problem is why the drawer doesn't always close properly, and it is inconsistent. There is no adjustment. Anyway, if the drawer seal is the slightest bit open, snow-like frost will build up in freezer. Mine is a GE pds20mcrbb
Posted on Jul 01, 2009
Testimonial: "Very helpful description and pictures."
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile Arctica PSS25SGNA BS Icemaker is not
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Posted on Nov 18, 2009
GE Profile Arctica not making ice
Check to see if the fuse for the icemaker is blown. Check to see if the linkages are moving. Check the activation motor is getting power.
Jan 20, 2013 | GE Profile Arctica Customstyle...
My GE 2008 side by side , the freezer is working but the food storage is not help ?
one of 2 things can be wrong,#1) if theres a heavy frost buildup on the rear inside wall of the freezer compartment then its a defrost issue,which will block air flow to the refrigerator side,take off back panel and test defrost heater and thermostat both on evaporator coil for continuity,thermostat has to be below 32 degrees to test good,most of the time its the hearter on G.E.. #2)if no frost buildup,then check the damper vent door between the freezer and refrigerator compartments and make sure its not stuck or broken shut and can no longer open and close to keep temperatures in refrigerator cold
Sep 29, 2012 | GE GSL22JFR Side by Side Refrigerator
I have a GE Profile Arctica refrigerator that I purchased used last week. Developing quite a bit of frost buildup inside the upper half of the freezer. Also noticing that the flap for the ice doesn't...
Hi yes the flap will cause the frost, you need to replace the solenoid that controls that flap, if this is a side by side, the solenoid is behind the dispenser controls on the freezer door, you take off the control board, and then remove the little mount behind that it has 4 screws and you will see solenoid on right side, it needs to be replaced.
Sean
Mar 17, 2011 | GE Profile Arctica Stainless Steel Top...
Icemaker leaking
Check two things.
1: see if you have ice buildup in the water inlet tube above ice maker, if you do chance are the water valve is bad, if not,
2: see if you have icicles hanging from bottom of ice maker, if you do you have a bad ice maker.
Either way, will need full model number and serial number both to get you the right part numbers for parts.
Oct 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE Profile Arctica side by side. The top quarter of the freezer is above 32 degrees. I know that because all the ice in the ice maker has melted and icicles are forming down below. This happened...
Greetings,
This freezer coil is likely froze over. this is because its stopped its automatic defrost. The thing to do is remove freezer panal and see if evaporator is froze over. if so, derost it..this will give you temp service. there is a fan midway in freezer..its possible its not running as well and this is the problem. see if fans coming on while you have it apart.
Oct 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
No cooling
Both refrigerator and freezer operate from one system. Air from freezer cools refrigerator. Check back wall of freezer for frost buildup. If frost is evident on the back wall of the freezer it indicates a defrost system problem.
Aug 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 02, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Arctica Icemaker
YOU CAN PULL THE FRONT COVER OFF TO SEE IF THE GEAR WHEEL IS BROKE,OTHER THEM AT CALL YOUR LOCAL APPLIANCE PARTS STORE AND YOU CAN GET A NEW ONE FOR AROUND $70,THANKS-MIKE
May 29, 2008 | GE Profile Arctica Stainless Steel Top...
Ice maker not working
have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
Sep 02, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
352 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
