Question about Samsung SGH-L700 Cell Phone
Not able to view games folder using pc suite
Am not able to view games folder using pc suite, and also not able to create it, it show its already exits,can any help me for this
In My Computer Disk drive E - one of folder using earlier, now iam not find the same folder file. If i create in the same name folder showing the error message contains.... the existing file already...
you just accidentally hide your newly created folder. go to tools it in your upper view. click the folder options. > view > click the show hidden files and folders > and also unchecked the hide protected operating system file (Recommended). after that you will see the folder that you create. im sure virus and trojans are responsible for that.
Jul 12, 2011 | Computers & Internet
Java Problem
  • Download
I will assume that you have games already downloaded to your PC if not then download from here http://www.4shared.com/file/105643441/b4a82c89/Samsung_M8800_Pixon_Touchscreen_java_games__240x400_.html?s=1
  • Extract
Extract them into the Computer Folder extract till you see Game folders and save it in another Folder (IF you don't want to create a mess).These games are for Samsung Pixon but works on Samsung Star.
  • Load to Your Mobile
Now you can either connect it through "Mass Storage" or through the "Samsung PC suite" options (Menu-->Settings-->Phone Settings-->PC Connections-->Mass Storage and Save).
Connect your cable and wait for the loading...go to my computer or the connection will prompt you to open with a category...Select Folder...create a folder with the name "Games" or whatever you want.Copy the games from the computer folder,by copying and pasting or by dragging and dropping,to the mobile folder.
Once the copying is done Go to the panel (Bottom-right) where you have time and date and from there right click on the mass storage Icon and click "safely remove hardware"-->Select the mobile device and select stop--remove the cable.
  • Games Installation
Now comes the installation part Go to your mobile folder where you have Loaded the Games Floder (Menu-->My Files).
You'll see the folders with names of the games assigned.Open one of them and you'll see two files JAR and JAD select one and Click "Yes" on install prompt.Screen will flash "Content not signed" select "Cont." Again select Install Screen will flash Installation Complete "Play" or "Back" select Back
  • Play the game
Go to the Menu-->Applications-->Games and More-->You will see the icon of the game you have installed -->click it and then you can play the game...Enjoy!
n
For the pc studio if you have Driver CD don't install as it will not work.Download PC studio from here http://www.samsungmobile.co.uk/support/softwaremanuals/software.do?phone_model=GT-S5230&sw_type=SW
Install the Software
then in the phone menu--settings--phone settings--PC Connections--select Samsung PC Studio and Save.
Connect the Phone.It will connect.
Rate if you find it useful...
Jul 04, 2010 | Samsung SGH-S5230 Cell Phone
Ds i have a r4 which already has games loaded onto
Insert your sd card into the computer/laptop using the sd card adapter and open the file then click on the file named games. Downlaod your games you want from online sites and put them into the folder named gamnes.here you can also delete the already existing games or even add music by creating a new folder called music not in the games folder though.
Feb 26, 2010 | Nintendo DS Console
How can i download games from pc to the samsung tocco lite
you can download a free program called bitpim
You can download it from bitpim.org
Or use the verizon's free program that they offer. Then you can transfer anything with it.
Nov 23, 2009 | Samsung SGH-S5230 Cell Phone
Not ble to install java softwares in my samsung gt-s5233a
  • Download
  • Extract
  • Play the game
n
Sep 02, 2009 | Samsung SGH-S5230 Cell Phone
Can pictures be downloaded from a computer to a psp
yah they can and its easy and take 2 mins. so just
  1. Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how many photos you want it to hold, you may need to get a larger one than the stick that came with your system.
  2. Turn on the PSP.
  3. Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
  4. Scroll to the "Settings" icon on the home menu of your PSP.
  5. Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
  6. If there isn't one already, create a folder called "PSP" on the PSP Memory Stick -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. If there isn't one already, create a folder called "PHOTO" inside the "PSP" folder (on newer firmware versions, this folder may also be called "PICTURE").
  8. Drag and drop image files into the "PHOTO" or "PICTURE" folder just as you would save files in another folder on your computer.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.
Tips:
  1. You can view jpeg, tiff, gif, png and bmp files on a PSP with firmware version 2.00 or higher. If your machine has firmware version 1.5, you can only view jpeg files. (To find out what version your PSP has, follow the tutorial linked below.)
  2. With recent firmwares, you can create subfolders inside the "PHOTO" or "PICTURE" folder, but do not create subfolders within other subfolders. so just follow this and ur good to go! good luck!
Jul 16, 2009 | Sony PlayStation Portable (PSP) Console
China cell
my cell is china cell
and my model number is a968
in my cell i dont have the game folder
how can i create a game folder in my cell can you explain how to make my settings in my cell i have .nes format games but i cannot use this games can you explain how to use in my cell plz send me the settings to my id my id is chanduarunkumark@gmail.com
Feb 03, 2009 | Cell Phones
My pc is not showing a G drive whenever i insert my usb connected to my phone
You'll need to download the USB drivers to your PC, too.
Go to the following website:
http://motoroladownloads.webs.com
Sign up to enter the site. (It's as easy as 1-2-3)
As a member, you can then download the Motorola Phone Tools (PC Suite) for your PC for free.
**Make sure you download the USB Drivers, too.
The download for the PC Suite is in .zip format. You'll need to unzip it to a new folder. (You can create a new folder on your desktop)
After unzipping the file to the new folder, double click on it to open > locate the >>
Setup884ac5e.jpg icon and double click on it.
This will install Motorola Phone Tools (PC Suite) on your PC.
Start the Phone Tools Program by double clicking on the icon on your desktop.
Download the Data Cable/Modem drivers and attach your phone to your PC with a USB data cable.
(You may also be able to use Bluetooth)
The PC Suite will include all of your options on the left hand side.
Oct 29, 2008 | Motorola Mobility RAZR V3
Can't view my Music folder?
got this solution by google :D
go to settings on your mp3 then usb mode then click msc then reconnnect to computer go to my computer then tools folder option, then view tab, then hidden folders then click show hidden folders!
HOPE THIS HELPS!!
bigman14
Jul 10, 2008 | SanDisk Sansa e250 MP3 Player
Psp
you need to have the videos as a mp4 file then what I do is get the memory card from the psp, put it in my pc and copy and paste the files to the video folderon the memory card. or you can drag and drop the files to the video folder in the memory card thats what I do with mine and it works fine
Mar 09, 2008 | Sony PlayStation Portable (PSP) Console
Samsung SGH-L700 Cell Phone Logo
62 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
