Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I get a paperjam error message on the Kodak ESP7 printer . I do not see any paper jammed in the printer
    Sergeant:
  • 324 Answers
Clear the memory of the printer
Posted on Sep 08, 2009
Error paper jam
It is possible that there is a little peice of paper that has ripped off of the sheet that was jammed. Was the sheet whole when you removed it? If not, check the location where the paper was jammed for bits of the last sheet of paper.
Sep 17, 2013 | HiTi P510L Photo Printer
I have a Kodak ESP7 Printer that has paper jammed inside that there seems no way to get too. The Paper draw does not come right out.
Remove the paper tray. Turn the printer around with the back facing you. there should be two plastic tabs to press and open the rear paper port path of the printer. Open it and see if you can reach the jammed paper. If you cannot reach it from this area, unplug the printer from the power source, press and hold the power button for sixty seconds and turn it upside down. Shake it gently to see if the paper falls out (if it is a small piece ect.). If its not a small piece, plug the printer back in and when the jam error shows on the display click the "ok" or "accept" button. when you click that button - get ready to grab the paper quickly. Pressing the button causes the rollers to roll backwards and then forwards and reset the paper. It will roll the paper towards you and pause for a few brief seconds before pulling it back in again. that will be your change to remove it.
Oct 09, 2011 | Kodak ESP7 PP All-In-One Printer
Printer prints only photo size on 8-10 paper. Also ripping paper jamming. can not find anything jammed.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Dec 13, 2010 | Kodak ESP7 PP All-In-One Printer
How do you un jam paper stuck in the printer?
LIFT UP PRINTER AND PULL PAPER OUT FRON UNDERNEATH.JOB DONE.
Nov 17, 2010 | Kodak ESP7 PP All-In-One Printer
Why my printer on and off button keep blinking when I try to scan?
This error message is related to paper jam. Please turn off the printer and once again check for paper jam. I would also suggest you to clean the printer and restart it after few minutes.
Good luck.
Thanks for using FixYa.
Jun 19, 2010 | Kodak ESP7 PP All-In-One Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Screen says paper jam, can't find anything
close properly your paper jam cover at the back of your printer down side. if not clean and check the sensor for paper jam.
May 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Installed new black ink cartridge on Kodak ESP7. Cannot get rid of Error Message (saying need to install black cartridge!). Help!
Kodak had a batch of bad cartridges, I got 3 of them. All come from China. I used the online chat to describe the problem. They promised to send me new cartridges.
Jack
May 11, 2009 | Office Equipment & Supplies
Paperjam then no power
unplug it..both cables..wait around 1 min..try it again. got backup?
Feb 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
203 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
