Question about Kenmore Dishwashers
I was replacing my sink faucet today and in the process turned the water off to the dishwasher. Subsequently my girlfriend ran the dishwasher without the water on! Now when I go to run the dishwasher no water comes out (meanwhile I've turned the water to the dishwasher back on). Is there some kind of reset? I accidently touched the coil in the bottom of the dishwasher just after trying to run it and it was hot. What do you recommend? Thanks. Mark
  • mrkhfn01 Sep 08, 2009
    It isn't that the dishwasher won't drain, it's that no water is going into the dishwasher!
  • 10,515 Answers
You need to investigate the following :-
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 08, 2009
  • taran_2005
    taran_2005 Sep 08, 2009
    Thanks for your response!!
    OK , This minimized the issue. If the water is unable to enter the machine, there can be 2 problems on the basis of the situation you explained :-
    Water-inlet valve
    The
    water-inlet valve lets water enter the machine. If this valve is
    defective, you need to completely replace it. It's usually located
    behind the lower access panel on the left or right side. It's the
    device with the main water line (usually copper) from the house, a
    rubber tube to the dishwasher, and two wires attached to it.
    Float switch
    The
    float switch is a small electrical switch that's located right below
    the dishwasher "floor." Above the switch, on the inside of the
    dishwasher, is a plastic cylinder that floats up as water fills the
    dishwasher. If this switch is defective, or if the plastic float gets
    caught or trapped in the raised position, the water can't enter the
    dishwasher. If the float switch is defective, you need to replace it.
    Let me know the update!!
Hot water doesn't work
Does any water come out of the faucet when turned to hot? If not, you may have disconnected the fautet line from the valve and attached the dishwasher line. You can check this by looking under the sink and making sure all lines are connected to valves.
If everything is connected, you may have dislodged some mineral buildup and it is blocking your hot water line to the faucet. You'll have to remove the line and clean it out.
Mar 02, 2014 | Home
Can't disconnect the dishwasher from the water supply -- the faucet starts running the moment I disconnect it. I've closed the faucet all the way (as best I can, with a plier), and it still runs.
you can turn the water off using the main water valve that is located under the sink -- this will close all water off to the dishwasher and to the faucet.
c...
Dec 31, 2010 | Dishwashers
Sour smelling/ tasting water from bathroom faucet when not used for several hours. Smells like traces in water bottles, which I can bleach or wash in dishwasher. How do I clean possible bacteria from a...
Assuming the problem is right there at the faucet, and not further upstream (which you could verify by taking a little water from the tub faucet), perhaps you could try this--- turn off the water supply then remove the flexible water supply lines from the faucet underneath the sink. These are usually not too hard to remove from the faucet with a basin wrench (less than $10). If it's easy, remove the other end of the flexible water supply lines too. Maybe you should replace these. Otherwise, get the water out of those flexible line, then put some bleach into them. Reconnect to the faucet. Leave the faucet turned off, and turn the water supply back on. Then very slightly turn on the faucet to allow the air out, then turn it off. Leave the bleach to soak for a while (maybe 30 minutes) then flush plenty of water through it. If the smell comes back, there is probably something organic stuck in the faucet and you will have to disassemble or replace it. Good luck.
Dec 20, 2010 | Home
My kitchen sink will not let me turn the hot water off, it just keeps running. The cold water shuts off fine just not the hot side.. I turned the knob under the sink and the hot water turned off but now i...
Hi hi--
You'll need to rebuild or replace your hot water control stop--that's the valve on the faucet body. If it's a single handle control, you'll need to replace the control cartridge. If the faucet has two knobs, you'll need to locate whatever stem pieces are needed within the hot valve. Sometimes, on two knob faucets, you can get away with simply replacing the rubber pieces inside the control stem. If that is the case, your local hardware store should have manufacturer-specific rebuilding kits available. Be sure to locate the faucet's model name first! That should be written somewhere on the above-sink portion of the faucet body itself, and you should be able to see it without taking anything apart.
--Hope this helps.
Sep 27, 2010 | Plumbing
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
May 12, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Kenmore Ultra Wash water supply started making loud noise while water is entering washer. If you turn on sink faucet at the same time the noise will stop.
It sounds like the solenoid valves which let in the water are not fully opening and causing chatter -- probably corroded . Turning the washer-water supply faucets down (to the left) will probably stop it, but the solenoid valves need to be checked.
The reason opening the sink faucet stops the noise is that it reduces the water pressure to the washer -- this is the same effect as turning the washer faucets down.
May 05, 2009 | Kenmore Dishwashers
Kitchen Faucet Replacement
Option 1 ; Cap off the sprayer.  Option 2 ; Relocate the air gap as high as possible under the sink but then you have no drain under it in case it backflows (it is really a vacuum breaker ,  one way check valve) Option 3: Take back the faucet and get one of those that the spout is also the sprayer.
Jan 30, 2009 | Danze D316440RBT Fairmont Two Handle Wall...
Sink Help
it should tighten when you turn the water on ?
Mar 31, 2008 | Kenmore 17459 Free-standing Dishwasher
Dishwashers Logo
16 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
