Question about Motorola Mobility Krave™ ZN4 Cell Phone
Cant turn off my touch screen vibration - Motorola Mobility Krave™ ZN4 Cell Phone
My acutel one touch doesn't ring with in comming calls it only vibrates
go into settings click on MY DISPLAY and in the list you will see SOUNDS & NOTIFACATIONS click on that and another screen appears check that all these are on RINGTONE,MEDIA,NOTIFACATIONS , SYSTEM and make sure vibrate is turned to mid range .Hope this helps ....
Jan 02, 2016 | One Touch Cell Phones
Why my htc explorer wont stop vibrating and cant power on.
your phone have hardware problem so go to the service station to resolve
May 16, 2017 | HTC Explorer A310e Black Android 2.3...
My my touch 4g slide won't turn on. when i start it i feel a vibration but screen will not turn on. Help?
Dear:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 11, 2012 | Cell Phones
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Feb 14, 2011 | One Touch Jitterbug One-Touch Cellular...
Could you tell me how to turn off keypad tones when texting on a samsung Tocco
Adjust the volume of the key tones
In Idle mode, press [up /down] and adjust the key tone
volume.
Adjust the vibration intensity on the
touch screen
You can adjust the intensity of the vibration when you
tap the phone screen.
1. In Idle mode, press [up /down].
2. Select Vibration and adjust the intensity of the
vibration.
Jan 13, 2011 | Samsung Tocco F480 - Pay Monthly Cellular...
Hello, i have the samsung tocco lite, i changed my silent profile vibration to the max as i never feel it go off when in my pocket, but ever scince then my whole phone vibrates everytime i touch it even...
press the volume down button on the left side of the phine and a menu will pop up at the top o the menu you can click on "vibration" set it to 0 and touch vibrations will stop
Oct 06, 2010 | Samsung Cell Phones
Touch screen is not sensitive on touch
You can change the touch screen vibration settings:
press
-Menu
-Settings
-Phone
Press Vibration Feedback
Set the desired Vibration Intensity setting
Press Save to keep the Vibration Feedback settings
www.usedcellphoneshop.com
May 18, 2010 | Samsung SGH-A877 Impression Cell Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
Phone turns on, backlight comes on but screen wont work
frist wash the petrol and assid 2 check the display ok any more sent me mail sameer_mishra1@yahoo.com
Aug 24, 2009 | Cell Phones
How do I turn the touch vibrate off?
To my knowledge there is no way to do this. I have read all the menu options and have not seen any.
Aug 10, 2009 | Motorola Mobility Krave™ ZN4 Cell Phone
Motorola Mobility Krave™ ZN4 Cell Phone Logo
517 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
