Question about Patio Classic Barbecue Bucket Grill
I don't have a problem but some of these problems may be caused by the regulator on the barbecue kicking on. To solve this simply turn your propane tank on slowly. If you open it quickly the regulator will restrict the amount of propane that flows to the grill. I don't know if this helps but i hope you can try it.
We replaced the regulator and the grill still does not have big flame always seem to be on low despite knob adjustment
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 30, 2014 | KitchenAid Superba KFRS271TSS Stainless...
Gas grill no flow of gas
Jul 14, 2014 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Why wont my old grill work with new propane tank
Jul 13, 2014 | Weber Q Grill
Full tank but no gas smell and just bought a new hose and regulator
follow this steps and fix it. God bless you
Test the propane tank valve for leaks:
  1. Turn the grill control knobs on the front (and, on some models, the side) of the barbecue to the off position.
  2. Turn the propane tank valve fully counterclockwise to close it.
  3. Mix a test solution of equal parts of dishwashing liquid and water in a small container.
  4. To test for leaks, apply the test solution liberally to the connection between the regulator fitting and the tank valve using a small paint brush. Apply the test solution to the valve handle and threads, the length of the hose, and the connection between the hose and the regulator. If bubbles appear at any point, there is a gas leak.
  5. Tighten the connections and retest.
  6. If you still see bubbles at any of the tested connections, close the tank valve and replace the leaking component.
Test the hose fittings for leaks:
  1. With the tank valve open, brush the test solution on the fitting at the other end of the hose, located under the control knobs.
  2. Turn the control knob to high and test the hose and fittings leading from the control knob to the grill. Turn the right control knob to off. Repeat the process for the other control knobs.
  3. If you see any bubbles during any of these tests, close the tank valve and contact your propane dealer or your local gas utility. Do not use the barbecue until the leak is corrected
Oct 29, 2013 | Weber Genesis Silver A Grill
Hi, We have a Grande Cafe , it is 6 years old,
I think the problem is with the Over Fill Protection Device valve in the propane tank and it's locked up the grill's regulator. To solve the problem turn the tank valve OFF. Disconnect the grill's hose from the tank and wait 5 minutes. Reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, turn on and light the burner that farthest from the grill first. Does the burner light and the flame height look correct? If so, light the remaining burners the same way. Now, do all the burners flames look correct? If so, you solved the problem. Remember to always turn the tank valve ON very,very slowly.
If the above didn't solve the problem, you will need to replace the grill's hose/regulator assembly. You can purchase one at any home center or hardware store that sells gas grills and accessories. Take your old one with you for comparison purposes.
Hope this helped you to solve the problem. Please let me know. Thanks and Happy Grilling!!
May 22, 2011 | Barbeques Galore 38-inch Grand Turbo...
I just hooked up my new tank to my barbecue grill, than turned on grill and tank,but no propane is comming out of burners. It is 30 degrees outside.
This happens no matter how cold it is outside, First turn the tank off, then turn the barbecue grill burners on for a couple of minutes with the top opened to vent out any trapped gas, close the burner knobs to the off position and slowly open the LPG tank valve to 1/4 turn, then try restarting the grill in the regular fashion. sometimes we cause a vapor lock situtation in the regulator by turning the grill on first before opening the LPG tank valve, the newer tanks are supposed to detect a freeflowing valve and close themselves off internally. This should remedy the issue.
Jan 25, 2011 | Garden
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
No gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
STS Turbo heat problem
Problem solved. The store FINALLY sent someone out who knows what they're doing. After about a hour of adjusting and tweaking he got it working fine. Apparently, the adjustments have to be made with the grill partially disassembled so flames can be viewed from top and bottom. Also, it needs to be load balanced with adjusting with all burners on, then with fewer and fewer burners on. Dan B.
May 26, 2007 | Barbeques Galore Turbo Elite 4-Burner with...
Patio Classic Barbecue Bucket Grill Logo
Top Patio Classic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Patio Classic Grilling Expert? Answer questions, earn points and help others
