Question about Lexmark X4270 All-In-One InkJet Printer
Driver Can't install 4270 driver on my laptop running vista home premium version - Downloaded vista driver and hooked up printer to usb port installation automatically starts but just hangs - after I eventually shut it down with the task manager an error message is on the screen saying cannot open the file lxbmlpa.chm. Also how do you install the Fax Driver that shows up as a printer ? I lost my install disk that came with the printer and cannot find the fax driver on line.
  • Anonymous Nov 19, 2008
    can't install driver
  • 42 Answers
Goto drivers.com use "alldrivers" at sign on, search for your model.
Posted on Dec 09, 2007
I lost my installation cd, i need to dwload driver for my X 4270 printer+fax
Posted on Nov 17, 2008
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Need to use HP Deskjet5550 to print off laptop
Since Hp have Vista driver to your printer...to install the driver...do not plug the printer...install the driver that you downloaded (run the program as Administrator)..after you install, if the installation ask for restart..restart your computer...after restart and the whole system finish his task on loading driver and dll ..then plug in your printer...it will pop up message found new hardware. click next and choose automatic find the driver.
what Cable are you using to connect?
USB a and b?
parallel port to USB? if this you need to download the driver too.
Good Lock
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
I cannot install my Deskjet D2360 on Vista
Here is the HP Support page to download the Vista software.
D2360 Vista Software
Uninstall any software you have already installed and reboot before downloading and installing the Vista software and driver.
Nov 14, 2008 | HP Deskjet D2360 InkJet Printer
Samsung ml-1740 printer - their driver not compatible with my Windows Vista
you must go to printer in control panel, then right click the desired printer icon, then click properties, then click on Port. then if using usb port, you must check each port untill you find the correct usb port that you are connected to (click apply each time). may take a couple tries untill you find the correct usb Port that the cable is connected to. worked on my HP desktop, finally
Sep 01, 2008 | Office Equipment & Supplies
Hp photosmart c3100
Recommendation:
Make sure that java, direct X, and .NET components are up to date. Many installers not require these.
If the install just can't see the printer, I would completely uninstall any components you were able to get installed (if any), remove the device entirely from your system, download a Vista version of the driver from HP if possible, and run the setup.exe...If your using a system driver you'll have to hook the printer up first, otherwise when it asks you to attach the printer then hook it up in a different USB port.
If all else fails install the drive manually through the control panel using Add Harware and then browse for the INF file.
Reasons
  1. Downloading the driver gets you the newest version available and may resolve a bug.
  2. Changing the USB port will keep Windows from using the pre-configured settings set up in previuos installs.
  3. Installing manually will add the printer to the device library, even if you have to reinstall it a second time to get the USB configuration right
Jul 24, 2008 | HP Office Equipment & Supplies
Driver issues with vista basic
There are script corrections in Vista Ultimate that other versions of Vista don't have (yet). I have Vista Home Premium, and had to install my printer manually, since Vista incorrectly identified it when I first booted my new computer while hooked up to it. When I tried HP's website, to get the driver to install it, I found that it isn't available, because they simply advise me that in Vista, I don't have to install any drivers, since the drivers for my printer are built into the operating system. That's all well and good, but getting the driver to install automatically wasn't possible. I had to add a printer, and tell Vista that it wasn't connected to my computer so that I could fool it into letting me install the correct printer drivers. It now works, but it seems to me like Microsoft is still the least reliable operating system there is. I'll shut up now. =)
Dec 26, 2007 | Microsoft Windows Vista Ultimate Edition
MP160 unknown device error in Vista
How do I install the downloaded driver and software?
If you have upgraded to Windows Vista™ from another Windows version or have installed drivers and application software from a previous Windows version, the previous driver and application software must be uninstalled prior to installing the Windows Vista™ drivers and application programs. Uninstallation instructions
Prior to installing the driver software, power off the printer and do not turn it back on until instructed to do so during the installation.
Vista Software can be found here
http://software.canon-europe.com/products/0010392.asp
Select Vista for the OS
Select English
Click Submit
Download software and drivers applicable to
Windows Vista 32 bit.
Install the downloaded software
Dec 18, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Driver for windows vista home premium
I have Windows Vista Home Premium. I do not have my original Olympus disc. I downloaded the driver from driver guide (http://members.driverguide.com/driver/detail.php?driverid=583812) > installed driver (in this case pencam.exe. After installing the Olympus software I hooked the USB cable up, turned on my w-10 recorder and let Windows begin it's search.
I manually pointed it to the pencam folder where it proceeded to load the drivers successfully. I am now able to transfer my files successfully. Hope this helps in some way.
Oct 17, 2007 | Olympus W-10 Digital Voice Recorder
Lexmark X4270 All-In-One InkJet Printer Logo
102 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
