Question about Daewoo DVN-14F6N 13" TV
My tv is stuck in teh stand by mode...how can i fix this
Give up you can't fix this problem by a new one.
Posted on Oct 03, 2009
Have you tried unpluging it for a few minutes, then plugging it backin?
Posted on Sep 08, 2009
Samsung le19r86bd television which is stuck in standby mode
Sounds as if it won't reboot. Apart from the obvious like turning the power off and waiting, I can't think of much else to do. Have you checked to see if anything is fractionally loose? Is it covered by warranty? If so go back to the manufacturer.
May 06, 2015 | Samsung Televison & Video
Mute button not working and tv stuck on mute
See if you can can go on the TV direct to teh control panel and reset if it does not work check teh remote or you need to change teh censor on the TV that is the power setting are.
Oct 30, 2013 | Bush Televison & Video
My hp tv wont turn on
hi it sounds like your plasma has gone in stand by mode look on youtube will tell you all about stand by type in how to fix and tv make model stuck in stand by more than likely capacitors blown if your not any good soldering boards id phone tv guy out but if you are then youtube it hope this hopes
Mar 04, 2018 | HP PL5060N 50 in. Plasma HDTV
My Element 40" Tv is stuck in stand by how do I
hi have you changed the batteries in the remote, if the remote is ok there's a fault with the tv, could be a swollen capacitors shorted diode or poor solder joint,or a bad mainboard , thanks
shaun
Mar 08, 2017 | Element ELCHW402 40 in. LCD HDTV
My Sony KP-51WS500 is stuck in Stand by mode
Have you tried unplugging the TV for a few minutes? if it's some kind of computer error, unplugging it will allow the error to clear and possibly allow the TV to work again. Just an idea.
May 22, 2010 | Sony KP-51WS500 51" Rear Projection...
TV won't turn on or off. Stuck in stand by mode
its a power problem on the electronics board need an tec to open the tv and slve the problem
Aug 17, 2009 | Gateway LCD26TV 26 in. Television
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Jul 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I can not control the mute or volume with the remote through the Sat mode. It only works through the aux mode. It is connected to a Onkyo receiver.
Dish remotes are set up to operat between SAT and TV mode simultaneously to control these features on a stand alone TV once you introduce the receiver you lose that ability as it is a seperate piece of equipment. You could try entering the code for the receiver to the TV button but I personally have never had any sucess with that approach. In short you are stuck using the remote as you are currently or are left with purchasing a universal remote. Thanks for using Fix Ya,
May 06, 2009 | DISH Network 311 DTV Receiver
Stuck VHS Tape/Power Issue
It sounds like the vcr is not completely loading the tape, and is overloading or getting confused. If you feel up to it, you can take the cover off the tv, find the tape loading mechanism, and 'help' the loading rollers along yourself... once the tape loads, eject it immediately, and you should be off and running again. Just be careful not to touch any electrical connections. If you're not comfortable with that, you're right, it's probably cheaper to get a newer tv - check with a local independent shop first, though, it should be a really quick fix.
Mar 14, 2009 | Samsung Televison & Video
ILO 26'' HDTV is froze on a single channel....
Sorry i to with hundreds of other people have been messed around tv will not turn stuck on one channel only can cut off and and side of the tv will not work either. My suggestion and im sure this isnt gonna help. contact the Better Business Bureau and file a compliant the tv is useless now the control panels or motherboards have went out. check out some of these sites about different people having the same problem dating back to 2004 with walmart and these ilo tv and they are still selling this and willnot help at all. mm warranty is a week old today!! and they said it is out of warranty basically oh well!! http://www.snarkhunting.com and of this site that your on and Epinions.com
Mar 12, 2007 | iLO 2600 Television
Daewoo DVN-14F6N 13" TV Logo
190 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
