Question about Kenmore 94802 Front Load Stacked Washer / Dryer
Kenmore front loader won't spin and reads the error sign suds
My front loader fills and washes just fine but it often won't spin, just says suds even though I have put very little soap in. I have had it five years and it never did this before. When I can get it to spin it rattles like there is a loose screw floating around in there somewhere.
Fixed it thanks, found the filter, it was clogged.
Posted on Sep 09, 2009
My washing machine gets a sud error often during the cycle. I have cleaned the drain as suggested
Vinegar does a great job of cutting suds and bubbles. I would put it in the detergent, softener, and bleach reservoirs and run a cycle. Then make sure you read the detergent amounts. It's easy to overdo detergent on a front-loader.
Aug 17, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
My Kenmore Elite show SUD on the display but is still working. Should I clear it or is there something wrong with it?
you're using to much detergent and that's the number one killer of the front loaders.the extra detergent eats at the rear spider gear,you'll know when it happens,when it goes into spin it bangs all around loudly.you should be using 1/4 cup of detergent and it should be h.e. detergent.fill it with water,run it for a bit and drain it to get out the extra detergent.the pump can't pump out suds so the washer will start filling and draining to try to get out the suds.just cut back on the detergent and you'll be fine.i think you press pause/cancel twice to clear it
Feb 27, 2011 | Kenmore Elite 45986 Front Load Washer
My washer won't spin. It fills up and washes the
check the pump/filter if it has one
Apr 20, 2010 | Washing Machines
Kenmore front loader tub fills with water when not in use
your water fill valves are leaking severely,you should see water dripping in there all the time if its this bad and your clothes should still be wet,not damp even after a good spin after the final spin
Mar 23, 2010 | Kenmore 43142 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
"suds" error in kenmore elite HE3 front loader washer
Try a vinegar rinse or there are also defoaming products available.
Jan 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 94802 Front Load Stacked Washer / Dryer Logo
94 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
