Question about Clarion XMD3-RET AM/FM MARINE CD PLAYER
No ipod connection
Same problem: I have a Clarion Marine Magi 2 CENET XMD3 in my boat.
I was thinking about solving the problem with the 3.5mm to RCA adapter as a solution, but I was wondering if there was any way that I could hookup my ipod so that it would charge as well as play through the sound system (or does that only work for certain ipods?). I'm concerned that if I use the 3.5mm adapter, then the battery will run out quickly and I don't want to run cables everywhere. Any suggestions would be greatly appreciated!
SOURCE: NO SOUND FROM CLARION XMD3
I have a XMD3 with Sirius on a Larson boat. Had same problem - everything seemed to be fine on unit (everything lit up and CD showed different tracks and time changing), but no sound. I suspected a ground problem and checked wires I could see. Found one speaker wire that had been frayed due to faulty installation. As soon as I wiggled that wire I got sound on all speakers. Not sure why one faulty speaker would kill all sound, but it did for me.
Posted on Jul 08, 2008
SOURCE: connecting my ipod to xmd3
I believe that if you use the RCA connectors, you can use your iPod. If you use the clarion cca connector, you get more functionality from the dash of the clarion.
Posted on Sep 06, 2008
elecgooroo
  • 57 Answers
SOURCE: Instaling a Clarion XMD3
clarion website download + print
Posted on Jan 10, 2009
  • 7 Answers
SOURCE: can i connect ipod adaptor to rca output jacks?
With out an input jack you cannot connect straight to your head unit. The RCA out puts only send a signal out. Your best bet is use an FM transmitter for your Ipod. The sound wont be as good but I can't think of another way with buying a new head unit.
Posted on Jun 05, 2009
moto34
  • 155 Answers
SOURCE: CD doesn't eject CLARION XMD3 marine radio
Disconnect the fuse of radio and reconnect it again.
That should force him to eject the CD
Posted on Oct 28, 2009
I have a Clarion Marine XMD3 radio in my boat. There is a set of speakers in the back of the boat and a set in the cabin below deck. The set in the below deck cabin work fine. The set in the back of the...
Look for loose or broken wiring connections. Swap front and rear speakers wires at radio and determine if problem is the radio or the speaker system.
Aug 01, 2013 | Car Audio & Video
Clarion Marine Problem w Sirius CeNet Unit
When a CD changer or Sirius satellite receiver is added to a system, the source unit’s main wiring harness must be disconnected before the changer and/or satellite receiver’s CeNET cable is connected to the source unit. Otherwise, the source unit will not “recognize” that a CD changer or Sirius satellite receiver has been added.
Apr 09, 2008 | Clarion (NAVSIR) SIRIUS Radio Receiver
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Oct 27, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Clarion XMD3 Condensate Problem
the only way to remove moisture is to get it looked at by a local repair shop .Or remove radio yourself ..let it dry for a few days and see if it helped .Water in LCD may not dry completely and may rust LCD with in time
Aug 05, 2009 | Clarion XMD3
Can i connect ipod adaptor to rca output jacks?
Jun 05, 2009 | Clarion M255 AM/FM Marine CD Player
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
FM200
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Connecting my ipod to xmd3
Jul 07, 2008 | Clarion XMD3
Clarion xmd3
Yes, there are 2 Red RCA jacks on the back. A $10 cable from radion shack, 2 RCA on one end and a 3mm jack on the other.
Cheap way to do it, there is also a device you can buy from Clarion that will do it for about $90 that gives you more control from the radio.
Jun 23, 2008 | Clarion XMD3
Clarion Xmd3
Bottom line is that boats are a hrsh environment for electronics. Moisture, salt, and vibration all conspire to undo solder joints and electrical connections. 4 years is a pretty good life span on a boat. A solder connection within the unit could have let go. A good repair shop could probably fis the bad connection but you can probably replace the unit for less.
Jun 26, 2007 | Clarion XMD3
Car Audio & Video Logo
111 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
