Question about Uniden GMR638-2CK (22 Channels) 2-Way Radio
Uniden GMR1448-2CK The two don't communicate on same channel but on different channels by using the scan
  • 24 Answers
Sounds like you have one units side channels set diffrent than the other.you should be able to reset this by reverseing the battries in both units for a few moments then replacing them correctly. or remove battries for 24 hours or more to delete memory
Posted on Dec 13, 2007
Uniden bearcat scanner wont scan
Make sure the volume is up a little and then make sure the squelch is set so you do not hear any static (white noise). Also make sure the lock button is not on. Depending on the model, make sure the channels are not locked out in the menu. Make sure there are frequencies programmed in the channels. If these suggestions don't work, tell us more about the scanner like model number, how many channels, crystal or programmable, etc.
Jan 10, 2018 | Uniden Radio Communications
Re Uh8060S new unit cannot move off channel 80 nothing in manual explains. Can you help?
The manual tells you how to preset the Channel when you turn it on if you don't want channel 80. The normal is 16. It tells you how to scan channels and it tells you how to step up and down through the channels. Read from Page 3 with the unit in your lap.
Uniden UH8060S 80 Channel UHF CB Radio with Masterscan ' JB Hi-Fi
https://www.jbhifi.com.au/phones/UHF/uniden/uniden-uh8060s-80.../702883/
May 4, 2017 - The UH8060S is extremely compact, yet so versatile and full of features and is now equipped with Masterscan™ Technology. The UH8060S is ...
UH8060S - Uniden Australia
https://www.uniden.com.au/Australia/default_print.asp?product=p_uh8060s.htm Introducing the latest in UHF communication from the world leaders in wireless communication. The UH8060S is extremely compact, yet so versatile and full of ...
[PDF]UH8060S - Uniden Australia
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH_8060S_Brochure.pdf UH8060S. MOBILE. UHF CB. 18+ km# for AUSTRALIAN and. NEW ZEALAND conditions. BUILT. RUGGED. Master Scan. ™. 7 Colour LCD. Key Backlight.
UNIDEN UH8060S OWNER'S MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Uniden Manuals > Transceiver > UH8060S View and Download Uniden UH8060S owner's manual online. Uniden UH8060S Remote Speaker MIC UHF CB Transceiver. UH8060S Transceiver pdf manual ...
Uniden UH8060S Owner Manual Page 3
Sep 01, 2017 | Televison & Video
I purchased a used uniden bearcat 700bca scanner when I try to program a channel it's saying prg-loc after I try to program and set the channels.
Try this manual. It should answer your questions.
https://www.uniden.com/File%20Library/.../Owners%20Manuals/BC345CRSom.pdf
Aug 26, 2017 | Uniden Radio Communications
I have a uniden bearcat bc145xl 16 channel scanning radio, every time I push the manual button, and try to put in a code I can't get all the frequency numbers put in. I don't know what I am doing w
When you press the manual button and then enter numbers it thinks you are entering channel numbers not frequencies.
Try manual button and then prog button.
Then enter the frequencies.
Hope this helps
Aug 18, 2017 | Radio Communications
How do I program a uniden BC 145xl base scanner
  • Press the power button to turn the scanner on.
  • Press "MAN" (for manual)
  • Now pick a channel where you want to store a frequency at and enter it on the keypad.
  • Now press the "MAN" button again to go to that channel.
  • Now enter the frequency you want into that channel and don't forget to include the decimal point.
  • Now press the "E" button (for enter) and you have programmed one frequency.
  • Repeat these steps until your scanner is programmed.
  • Now you can press the up and down arrow buttons to scroll manually through the channels or just press "scan" to scan through them.
  • Make sure to keep your squelch just above the noise so you pick up stations well.
  • Hope this helps.
Nov 24, 2011 | Uniden Radio Communications
I NEED TO KNOW HOW TO ENTER CODES INTO THE SCANNER
hi what do you mean by codes ,or do you mean frequencies ,to enter frequencies press the program key enter the frequency you want to listen too and press enter you can select different banks for different communications ,such as emergency,air traffic,marine,rescue,etc hope this helps
Jan 08, 2011 | Uniden Bearcat Pro PC68XL 40-Channels Base...
I took out the rechargeable batteries (replaced with regular AAA)in my Uniden walkie talkies and now one is set for channel 19 and one for channel 6 so they cannot communicate. How do I set the channels...
Press the channel/scan up or down arrow key to change3 the channel on either radio. Need the operating instructions? You can download/print them here:
http://www.banoggle.com/Products/Uniden/manuals/GMR-325-2om.pdf
Bill B
Aug 06, 2010 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
Uniden/bearcat BC-100
If it's indeed a BC-100 and not a BC-100xlt, the 16 channels are easy to program and use.
1. Press MANUAL 3 MANUAL with 3 being the number of the channel you wish to program.
2. Enter the frequency for that channel (e.g., 162.55) followed by ENTER.
3. Follow the same sequence for each channel you wish to program, except that pressing MANUAL after you program a channel will advance the scanner to the next channel.
To scan, simply press the SCAN button after your frequencies are programmed.
Bill B.
San Antonio
Jul 15, 2008 | Uniden BC248CLT Base Scanner
Uniden BC72XLT compact scanner
Hi, this is from the manual,
Locking Out Channels
You can increase the scanning speed by locking out channels that have a continuous transmission, such as a weather channel. To lock out a channel,
manually select the channel, then press Func +L/O.
L/O appears.
Note: You can still manually select locked-out channels.
To remove the lockout from a channel, manually
select the channel, then press Func + L/O.
L/O disappears.
I hope this helps you out,,, Mechanic
If you need a manual, go here.
http://www.uniden.com/pdf/BC72XLTom.pdf
Jan 22, 2008 | Uniden BC72XLT Handheld Scanner
Uniden GMR638-2CK (22 Channels) 2-Way Radio Logo
140 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
