Question about Garden
Have a Cub cadet self-propelled Mower. It does fine when going forward and it pulls put when you take it out of gear and put in "nuetral" the wheels lock up. When I changed the oil I cleaned the grass debris out by hand and air hose. I've checked the owners manual and tighten the cable. The mower will still lock up it's rear wheels.
  • 1 more comment
  • dkcox1957 Sep 08, 2009
    The mower is actually a friend who asked me to change the oil for her and she told me that it just started locking to wheels up when you pull the mower back. When I changed the oil I noticed that there was alot of debris underneath the deck. I cleaned that off and blowed air to get the rest of the debris out of the transmission area. I use 3in1 oil to oil the cables. That seemed to help in moving the cables. I was hoping in cleaning the debris out from underneath the mower deck would fix the problem but the rear wheels still lock up
  • dkcox1957 Sep 10, 2009
    Selfpropelled Cub cadet, works fine going forward
    Back wheels lock up when you pull it backwards.
    Have cleaned out the debris (dead grass) underneath but still has problems
  • dkcox1957 Sep 12, 2009
    I need to clarify the problem.
    There are 3 levers on the handle, One course is to keep the mower going as well as starting.
    One small lever is the speeds 6 of them and then there's this large lever with forward and nuetral.
    I've check and even in nuetral the wheels still spends even in the lowest speed,
    I followed the cable to the transmission, Is there any type of adjustment for this cable? There is one for the speeds both on the side of the deck and one at the handle. But I don't see one for the other handle the one that has forward and Nuetral. I hope this explains the problem. If you need me to take pictures I can do that.
    Thanks
    President:
  • 2,976 Answers
There should be a threaded rod connected to the shift linkage. Adjust it so that neutral is dead center in the neutral range. This should align forward & reverse to their proper locations.
Posted on Sep 10, 2009
  • David Shaub Sep 12, 2009
    When you put it into neutral, it should be just that, neutral. There is a latching mechanism connected to the drive gear that isn't releasing. Depanding on the year and even month it was built, it will be slightly different. Look for a sliding link, or bar, that moves when you put it into neutral. The cable or linkage should never be loose. If it doesn't go into neutral freely, without slack, the cable is slightly stretched. There is a device that can take up the slack. It looks like a 'u-bolt' with a hook in the middle. The cable lays in grooves on the 'U' and the hoo goes over the cable. When you tighten the nut on the screw, it pulls the cable down and basically puts a kink in it, thereby shortening the overall length of the cable. The clamp is left on the cable. There are used the tighten parking brake cables on older cars,
  • 574 Answers
The self propelled front wheels have nothing to do with the rear wheels. If the rear wheels are locking up it may be that the nuts or bolts are to tight. Did you just purchase this mower? There should be a spacer between the wheels and frame so when you tighten up the bolts or nuts they dont compress the wheels againt the frame. Hope this helps
Posted on Sep 08, 2009
  • roberta3fan Sep 08, 2009
    They lock up forwards and backwards when not using self propel? I would pick the mower up and see if wheels spin freely.
Self propelled cadet mower locked up how to unlock
Check engine oil level first for proper level.If it has oil in it PULL SPARK PLUG WIRE OFF SPARK PLUG IF MORE THAN A SINGLE CYLINDER PULL ALL PLUG WIRES OFF. Put unit on its side and grab the blade and see if you can move it in either direction or if the engine is locked up.
Jun 11, 2014 | Cub Cadet Lawn Mower Deck Drive Belt...
Lawn boy self propelled mower won't move backwards
is it belt driven can you pull it back when it not running
Apr 11, 2013 | Garden
CC 989 quit pulling after replacing rear wheels
on my snow blower there was two positions to put the drive wheels back on, locked and unlocked. need to put the pin in the locked position thru the wheels and axles.
Aug 10, 2012 | Cub Cadet Garden
Wont drive right rear wheel it just draggs along
My name is Dane and I am going to assist you in answering your questions. I'm sorry to say that I don't have any good news for you. If one of your rear wheel is pulling correctly, and the other drags, you definitely have something broken inside of your transaxle. This will be something you will need to refer to a repair facility to fix. It could be anything from a broken axle to a gear. Be prepared to spend some major money. Probably anywhere from $350.- to have a used transmission installed/repairing the old one, up to maybe $900.- for a new installation. Depending on how old your mower is, it may not even be feasable.
Sorry for the bad news, but if you find the information useful, please give me some thumbs up. Thanks! Dane
Dec 08, 2010 | Cub Cadet Street Sign- tractor lawn riding...
How do you remove the gears on a front wheel self propelled troy bilt push mower?
Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
Apr 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
What is causing slipping of rear right wheel on
most likely the gears that are inside the wheel hubs.
Jul 09, 2009 | Garden
Honda Harmony mower, self propelled hydrostatic, wheels lock up when pulled backward. Going forward no problem.
If i remember correctly, under each drive wheel, there is a small gear, and under each gear there is a small metal rod that is what the transmission uses to propel the mower...it sounds like the rods either have dirt on them or they are just stuck and can not move to allow you to pull it backwards
Apr 25, 2009 | Garden
Garden Logo
619 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
