Question about Hoover HDC7FM Dryer
Dryer humming but not starting
Humming noise and 'on' light activated, but no rotation of dryer
  • 2 more comments
  • muslfc Dec 10, 2007
    i can turn the drum by hand. do you suggest replacing the condensur for motor start as the solution?
  • Anonymous Feb 03, 2008
    We have the same problem- humming noise but drum does not rotate. How did you resolve your problem? Which part did you have to buy and was it expensive?
  • Micofmag7 May 26, 2008
    G'day my dryer hums and will start if i manually rotate the drum then quickly shut the door. Do I need a new motor? I have taken access panel off and checked belt and it seems tight. Any suggestion appreciated.
  • becks0709 Aug 16, 2008
    just got a condenser dryer model hnc 375, it`s only been used a few times before i got it and the on light comes on, it sounds like it wants to start but the drum doesn`t rotate. Also the filter care light is flashing but the filter has been pressure cleaned and is spotless!
  • 249 Answers
Can you rotate the drum by hand? the humming noise is the motor trying to turn,you should be able to turn drum by hand, it could a faulty 'condensur' for motor start up,get back if you can't sort it.good luck eire
Posted on Dec 09, 2007
Yes I agree I had this on a similar model, it's the motor start condender/ capacitor. Note down the voltage and capacitance from the side of the condenser, and go to Maplin (or order from them on line), they are only a few quid. One other symptom: the side of the capacitor was slightly bulged out, indicating internal breakdown of the component.
Posted on Feb 06, 2008
Sounds like the capacitor on the motor is faulty
Mar 21, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
Whirlpool Dryer made loud humming noise and quit
Something caused the motor to lock up. The humming noise was the start winding in the motor trying to start rotation, but could not because of lockup. The humming noise stopped when the start winding burned out ( will only last 6 or 7 seconds). It will require a new motor, plus repair to whatever caused it to lock up in the first place.
Dec 22, 2013 | Dryers
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 18, 2011 | Kenmore Dryers
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Sep 25, 2010 | Maytag Dryers
Dryer makes humming noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
May 15, 2010 | LG DLE2512W Electric Dryer
Humming Noise When Start Button Pressed
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
Dryer Repair ? The dryer will not start
May 10, 2010 | Dryers
Dryer will not work1
Squeaking noise often indicates problem with drive belt. If belt broke, drum will no longer rotate. Belt is similar to fan belts used in autos. Ck Sear's website for parts diagram of yr dryer. If it shows a drive belt, I would start there.
Jun 05, 2009 | Kenmore 659 Electric Dryer
Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Mar 15, 2009 | Kenmore 84052 Dryer
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Hoover HDC7FM Dryer Logo
890 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
