Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp 6110 won't accept new cartridges.
"check cartridge blink" put in new color and black. Won't come up. Removed each several times, no help. Is it permantly shot /
HP 6110 all in one.
Thanks
Jack
    President:
  • HP Master
  • 566 Answers
Check these HP FAQs for your printer:
Also see, at the end of each one, the links to related printing problems.
Posted on Sep 08, 2009
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
HP Officejet 4500 Incompatible Black Cartridge
I have an HP officejet 4500. When I replace cartridge the printer reported Incompatible print cartridge. How can I get the printer to accept the cartridge and start printing again? The color cartridge is original to the printer and the black cartridge is the "new" one.
Feb 26, 2011 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 won,t print. After initializing, I get error messaage to REMOVE AND CHECK CARTRIDGE. and AFTER CHANGING 56 AND 57 CARTRIDGES many times, still doesn't print.. I ve spent 3 hours trying to navigate...
Hi
your cartridges are not good any more
and need to be replaced
Remove and replace your cartridges
try old ones to see if color or black has the problem
Hope I help you
if i did pls vote me
Oct 13, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My hp 6110 has a flashing exclamation mark and says "Remove and check cartridge". I have removed and replaced both cartridges several times but the light stays on and the message still appears. HELP!
Hi
remove cartridges
get a peper towel
and clean metal contacts of cartridges
and the metal contact of cartridge carrier
if the error insist
you need to replace with new ones
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Hp officejet 6110 not printing with black ink
Hi lilacky-
Here are some HP support links that might be helpful... and a couple questions to consider.
Q: Is your new cartridge one of these listed below?
"The HP Officejet 6100 series and HP Digital Copier Printer 410 products use the print cartridges listed below:
* HP 56 black print cartridge
* HP 57 tri-color print cartridge
* HP 58 photo cartridge (replaces the HP 56 black print cartridge for six-ink photo printing)" info from: Installing a Print Cartridge
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&lang=en&rule=12548&product=79477 Is your new cartridge a refilled cartridge? Some times those have special challenges. Has your cartridge been sitting a while in the box, maybe in a warm spot? Some times even new cartridges dry out a little. Was your old cartridge low or completely gone? Just as a test, if you put it back in your printer does the old cartridge work? Any printer error messages? Can you print a test page or an alignment page for your black cartridge? These might be too many questions but here are some HP support links with some How To information for getting more answers. Please let me know if any of these are helpful. see also: Slow or No Response from Printer
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=11882&lc=en&dlc=en&cc=us&lang=en&product=79477 -JW
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Message: Remove and check ink cartridge
hi just fixed my 6110 hp by pulling out spring wire that is on right hand side where black ink cartridge gets inserted i think it was preventing a good contact
i did this after following all other help hints including cleaning heads etc and replacing with new ink now it works perfect hope this works for you too
Oct 14, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
155 people viewed this question
Seeker5211
Seeker5211
