Question about Refrigerators
My icemaker leaks from underneath and I can't tell where it is leakein from
  • 115 Answers
Check if all your tubes are connected first ,then dry the area and look where its leaking from and from that area you will see where it is leaking from .could be the gaskets on compressor,compressor bad ,if my info was of any help to you please leave a comment ,note,vote.thankyou
Posted on Sep 08, 2009
Hotpoint refrigerator leaking water from hose underneath
It sounds like this may be coming from the icemaker water valve. If the refrigerator is an older one the tubing gets brittle and cracks. Check this first. But the water valve is usually on the left side in the back.
Apr 09, 2014 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Whirlpool Ice maker leaked water inside freezer
Icemaker Valve underneath the fridge needs replaced. Its not shutting off at the measured amt
and causing overflow in the icemaker.
Thanks for using fixya
Leo Ponder
Please rate me if this helped
Jul 17, 2011 | Refrigerators
Hello! I have a Kenmore refrigerator model #10656576400. It stopped making ice for a while but then started up again. Now it is leaking water and filling up the tray underneath the ice cube mold. Is it...
The first thing to check would be the water fill valve located usually on the back outside of the unit where the water line comes in, these can start leaking water slowy into the icemaker. The icemaker itself tells the valve how long tostay opened, that can be adjusted by a tech or you may need to replace the icemaker
Jun 24, 2011 | Refrigerators
Refrigerator leaks water on the inside underneath the freezer
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 09, 2010 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
My refrigerator started leaking underneath on the right back side. Can you tell me what is wrong and what needs to be done?
If you have icemaker in your fridge - remove cover on the back and down and check the plastic water tubing for cracks and loose connections.
If nothing found or you don't have icemaker - there is a drain pan on the bottom, behind the same back cover. Check if it has any cracks or tilted. Check if the drain tube is routed to the drain pan and is securely attached to the drain port on the bottom of the fridge.
Oct 12, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
Leaking water on the front corner of the freezer side. We have turned off the water to the icemaker and have turned off the icemaker. Still leaking, not fast, but each day I clean up a puddle.
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket. Look in your freezer floor for ice build up. If you don't see anything like that or if you think the water is coming from underneath the fridge, then it is your condensate pan underneath. They crack sometimes.
Sep 06, 2009 | Frigidaire Refrigerators
Kenmore Refrig 51562 Side By Side; Icemaker leaks water underneat
you are going to have to replacwe the solinoid valve for the icemaker mbecause its leaking by
Feb 25, 2009 | Kenmore 51562 / 51564 / 51569
Water leaking underneath icemaker, dripping into ice tray
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the first one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Feb 20, 2009 | Amana DRS2462B Side by Side Refrigerator
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
