Question about Wega Mininova EPU Espresso Machine
Leaks when filling with water
Water leaks around the opening to the water reservoir..where can you
get new seal.
    President:
  • 1,618 Answers
Check with espressopartsnw, they have a large selection of parts, if you cannot find it under wega look under astoria or rio same machine.
Posted on Sep 17, 2009
1994 chevy 1/2 ton brake fluid is leaking from the bottom of the plastic fluid reservior
You need to replace the reservoir, fill the new reservoir, and bleed the brakes. Either the o-rings and seals have failed, or there is a timy crack or series of them at the bottom of the reservoir around the outlet from the reservoir to the master cyclinder. A '94 model anything has been through thousands of heat cycles and the reservoir sits right above the driver's side exhaust manifold.
Oct 21, 2016 | Cars & Trucks
Replace washer fluid reservoir
Usually remove the tire, remove the inner fender well, remove the bottom splash guard. This gives you access to the reservoir. Before you take it out, fill it with water. Make sure it is the reservoir and not a rubber seal around the pump. Yours is to new to be a reservoir. But it happens.
May 17, 2016 | 2011 GMC Terrain
When water reservoir is filled up and placed on the base, water leaks out into the tray from inside
Sounds like the "o ring" that seals around the bottom of the reservoir is worn out. It should be replaceable.
Jun 04, 2015 | Coffee Makers & Espresso Machines
How do I stop water leak
If you're talking about the model shown in your picture, the leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Oct 03, 2014 | Bunn 10 Cup Home Coffee Brewer
Bunn coffee pot leaking bottom
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
Oct 02, 2014 | Bunn Coffee Makers & Espresso Machines
How to fix a leak on a bunn NHBX coffee maker
Aug 09, 2014 | Bunn NHB Coffee Maker
How do i remove engine coolant cap on 2001 cadillac dhs
WAIT UNTIL YOUR ENGINE IS COLD,YOUR RADIATOR PRESSURE CAP IS LOCATED ON THE COOLANT OVER FLOW RESERVOIR, THATS WHERE YOU ADD COOLANT WHEN COOLANT LOW,YOU POUR COOLANT IN THE OVER FLOW RESERVOIR UNTIL COOLANT LEVEL REMAIN AT FULL COLD MARK DONT OVER FILL OVER FLOW RESERVOIR, WHEN COOLANT LEVEL STOP DROPPING WHEN ADDING COOLANT AND COOLANT LEVEL STAY AT COLD MARK ON THE RESERVOIR YOU RADIATOR HAS THE CORRECT COOLANT LEVEL IF COOLANT LEVEL KEEP DROPPING CHECK FOR COOLANT LEAKS AROUND RADIATOR AND THE TOP AND BOTTOM RADIATOR HOSES, LOOK FOR COOLANT LEAK AT WATER PUMP GASKET OR SEAL OR LEAK AT WATER PUMP WEEP HOLE IF YES REPLACE WATER PUMP.
Oct 23, 2011 | 2001 Cadillac DeVille
My Keurig Platinum B70 is leaking. When I put the water reservoir on to the coffee maker, water seeps out the bottom where the reservoir sits into...almost like the little valve in the reservoir stays...
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Apr 23, 2010 | Keurig Platinum B70 Coffee Maker
The water is leaking from reservoir ...
Hi
There is a seal on top of the machine under the water tank. To get to it, remove the water tank, and set aside. There is a large doughnut shaped cap on top of the machine. Slip a screwdriver on the outside edge of the cap and pry up gently. When it snaps up, go to the other side of the cap and do the same. There is a black seal in the center and if you stick your finger in the center and it lifts out, it need to be replaced. Clean any residue inside the opening with a Q-tip.
When you get the new seal, it won’t slip in. Insert it at a slight angle (double lips down), then take your finger nail and run it around the bottom edge of the seal until it slips in, then push down. Snap the cap back on and your set to go.
Dec 21, 2009 | Spidem Trevi 'Exclusive' Espresso Machine
Leaking
i got a vienna digital when i take the water container of to clean it 1 time out of 2 im gonna have water all over the floor what i do now clean the container put it back fill the water container with big glass and no more leak it probably have to do warp water container when it empty it seat perfectly when you have it in our hand it warp a little bit were not the only one with that me when i dont remove the container to fill it up i have no problem since then thanks for using fixya pierre
Feb 25, 2008 | Solis Master 5000 Espresso Machine
Wega Mininova EPU Espresso Machine Logo
85 people viewed this question
Top Wega Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
