Question about Samsung DV337 Electric Dryer
Samsung Dryer Model No. DV337AEG/XAA is showing an error message of L with a - in the middle of the L and an O and there is a burnt rubber smell coming from the dryer. Any ideas what might be wrong?
  • 1,531 Answers
Not sure of the fault caode never seen it before but i would check he belt and drive motor and make sure there is nothing seized up
Posted on Sep 27, 2009
I am receiving an error message of L5 for my Samsung Dryer DV328AEW/XAA
I have uploaded the manual for this dryer to Fixya.com and the link to same is below. The following error information is on page 26 of the manual. Good luck to you:
INFORMATION CODES
Information codes may be displayed to help you better understand what is occurring with your Dryer.
CODE SYMBOL ( L5 )
MEANING
- Heater temperature control problem.
SOLUTION
- Call for service. See below. (see contact info in manual.)
Please let us know if helpful by clicking the button below, thanks!
http://www.samsung.com/us/support/owners/product/DV328AEW/XAA
7 3 cu ft Large Capacity Stainless Drum Dryer Neat White Samsung DV328AEW...
Jul 29, 2016 | Samsung DV328AEW Front Load Electric Dryer
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Dryer heats for maybe 1 minute then stops. Samsung Model DV328AGW/XAA
In the rear of the dryer is a thermal limiter which will kick in when the exhaust temp is too high and can cause a fire. One link will show what the limiter looks like and the other will show how to commonly get to the limiter. Your mileage may vary.
Samsung Dryer Model DV328AGW XAA Fuse Thermal Fuse Breaker Parts Take Apart Samsung Dryer Samsung Dryer Repair Help
Jul 30, 2014 | Dryers
I have a samsung dv337aeg/xaa dryer that does not heat
could be thermistor but also may want to check the heating element, the hi-lo limit thermostat, and see if u are getting full power to the unit as if only getting 120 instead of 240 u have enough to run the motor but not the heater? thermistor located in the housing near the blower, sometimes in the drum or on the door
Jul 27, 2014 | Samsung Dryers
Our Ale 643 RAW Dryer emits a strong
Hello, Most likely the burnt rubber smell is that of the dryer belt trying to spin the dryer or the rubber rollers themselves on the tub of the dryer. These are the only rubber parts in a dryer and most of the time it is due to the belt needing to be replaced and having a worn area on the belt itself which then sometimes manages to become stuck on either the pulley or the pulley that is on the motor itself causing it to start to burn into the rubber. You would need to take apart the cabinet of the dryer and observe the dryer belt and if needed replace the belt on the unit. If you are in need of a diagram or step by step instructions please message me back your complete model number and I will locate your diagram and provide instructions on how to repair this issue your unit is having. I await your reply if you have any further questions as well.
Thank you,
Rick
Apr 11, 2012 | Amana Dryers
The dryer will not heat. I have no error codes and everything else works fine. I did order a heating element assuming that was the issue but now wonder if I would've had an error code and it could be...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 05, 2010 | Samsung DV337 Electric Dryer
My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Jun 07, 2010 | Samsung DV218AEW Electric Dryer
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
Samsung DV337 Electric Dryer Logo
610 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
