Question about Kitchen Appliances - Others
My garbage disposal just hums when i turn it on but won't turn. if i leave it on too long it kicks the reset button on the disposal. what can i do to fix it?
    Brigadier General:
  • 4,088 Answers
Pull the power plug and reach into the opening to turn the grinder in both directions--it's probably locked up. Shine a flashlight into the opening to see if tableware or something else is jamming it. At the worst, you may have remove the unit from the sink and dismantle it. It may have a frozen bearing as well. Hope this helps.
Posted on Sep 08, 2009
    Problem Solver:
  • 17 Answers
I had a similar problem last weekend. I have a tool that looks like a hollow hexagonal tube that I inserted into the drain and tried to turn the mechanism a little bit each way. I also have an allen wrench under the sink that I used to turn a bit each way from the bottom. Then, pressed the reset button and tried the switch. I tried this several times. (Don't leave it humming. If it isn't working right, turn the switch off immediately.) Eventually I got the right loosening action and it worked. I had a tiny piece of a wine glass charm that was jamming the gap between the blades and the housing, I think. It was only the size of a plastic pin head and it was ejected when the thing finally worked again!
Posted on Sep 09, 2009
Insinkerator model 55 hums
Copy following link for troubleshoot walk-thru:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Check that unit is receiving 80% rated voltage
Humming sound means start capacitor has gone bad.
Replace disposal.
Mar 23, 2013 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Garbage disposal won't work. It just makes a humming noise
might be something lodged in it, like a spoon or something. Turn it off and fish around in it with your hands.
May 01, 2012 | KitchenAid KCDB250G 1/2 HP Continuous-Feed...
My garbage disposal won't turn on, and i've felt down there and can't feel anything blocking it...what can i do now
Check circuit breaker.
Check red reset button on side of disposal and see if it's popped out. It's under sink, next to wire connection on disposal.
See if electric switch has gone bad. Listen if disposal makes humming sound. Humming means electric power is good.
Use vacuum cleaner hose instead of hand to check for stuff inside disposal
Use wood broomstick and see if cutter disk rotates freely.
If disk is stuck, wedge broomstick against side of sink opening until disk comes free, or use allan wrench on bottom of disposal.
If electric power to unit is good, and reset will not reset or reset is not tripped out, and if cutter disk rotates freely, then disposal has gone bad.
You can continue using sink as long as there is no leak that will damage cabinet underneath.
I wrote ex disposal replacement steps from my apartment maintenance days.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 15, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
When i turn on the disposal it hims but won't work. I used an allen wrench and turned the bottom. It turns freely. i pushed the red reset button and unplugged it but nothing seems to solve the...
If cutter plate turns freely and motor hums, then motor winding has gone bad.
Each time you turn it on, the motor is overheating and will stop humming.
I wrote ez replacement steps for disposals from days when I worked apartment maintenance.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I get power through the reset button. No humming, no nothing. Is it a bad motor?
If i understand correctly, you tested the wires where they connect to the garbage disposal.
Those wires connect before the garbage disposal reset button.
If the reset button is locked in, then the reset is not popped out.
If reset will not reset, then the popped-out reset will push in but not click down.
If the reset is clicked in, and you hve 120V on the line, and the garbage disposal doesn't make any noise, then the motor is bad.
There are no replacement parts for garbage disposal.
Oct 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The disposal only hums. I can turn the blades inside so there is no food stuck. I know there is a reset button but cant locate it.
I had the same problem, it was just humming, then after a few second the on board circuit breaker would cut out. After a little while I could hit the reset button and it would just hum again.
It turns out that the base of the disposal was jammed. There are 2 blades on the top that should spin freely, but the base plate that the blades are attached to also spins. In fact, that's what the motor drives. The two blades on top are not powered, they just flip back and forth as the base spins. So get a broom handle or a strong wooden spoon, stick it down in there, and try to pry the base plate free so it spins. That should do it.
Oct 28, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
When I turn on the garbage disposal unit it hums. I tried the Allen Key and hit the reset switch. It still does not work
I also am having the same problem. Tried the reset button as well as the jambuster. The allen wrench swivels with ease from the nudge of a finger. The motor turns on, but the disposal will not spin. Do I have to take it the garbage disposal apart?
Aug 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: Just hums and won't run, even after assuring that ...
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage disposal is not working. Making humming sound when turned on. I tried to press the red reset button but to no avail. Also tried to turn the little dosposal wrench in bottom hole of disposal but...
It is most likely plugged up there is a clap with a butterfly bolt that you turn counter clockwise remove the clamp and have a trash can under it and wiggle it to remove the lower half of the disposal, when it comes off dump it out and clean with fresh water. Then with hands free of the pump turn the disposal back on, it if still hums the motor is bad and you will have to replace..
Sep 13, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Kitchen Appliances - Others Logo
336 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
