Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
COMCAST REMOTE AND SAMSUNG TV
COMCAST REMOTE CODES FOR SAMSUNG LCD TV WILL NOT WORK.
SCAN FOR A CODE ALSO DOESNT WORK. IS THERE A FIX. IS THERE AN IR REPEATER THAT I CAN USE BETWEEN THE TWO?
  • 12 more comments
  • jsrco Jan 01, 2008
    having the same exact problem, cant find the answer anywhere on the net.
    on the reverse, i finally found the code to make the samsung remote control the comcast motorola cable box, it is 038
  • Anonymous Jan 06, 2008
    Same exact issue. Please advise.
  • Anonymous Jan 13, 2008
    No working code available for comcast remote to control a samsung 52" lCD
    No joy here either. I called comcarp and they had no clue
  • Anonymous Feb 19, 2008
    I have the same problem. The data activity LED on the TV is flashing indicating code must be correct, but the Samsung cannot decode.
  • Anonymous Dec 31, 2008
    I had the same problem with a new Samsung LN40A550. The Comcast website http://www.comcast.com/remotes/tvcodes.h... gave me 5 different codes for Samsung and all of them were 4 digit in length (e.g., 0060). The code that actually worked for me was 5 digits (e.g., 10060).
    Clearly something got missed by the Comcast QA dept.
  • Anonymous Jan 05, 2009
    The 10060 code worked for me !! You guys ROCK!!
  • Anonymous Jan 24, 2009
    want to play tv
  • Anonymous Feb 01, 2009
    10060 worked for my Samsung 32" LCD but you would have to press the volume repeatedly to go up, 10702 fixed the problem.
  • emailjb04 Feb 27, 2009
    10060 was the code for my LN46A500 Samsung LCD, THANKS!!!!
  • Anonymous May 10, 2009
    remote will not program with 4-digit code
    however it did program with the 5-digit code, all it took was the 1 in front of the provided 4-digit code to make it work.
  • Anonymous May 13, 2009
    10060 worked for my Samsung model number LN32B360. you guys are awesome cuz i was gettin pissed!!! lol
  • brarick
    brarick Sep 01, 2012
    10060 worked for me , thanks!! it's a 50 inch samsung LED
  • Kenny Sep 03, 2013
    Just found out that 10060 I know 5 numbers but it says 4 digit code.
I was having the same issue with a Samsung 4053 40"
Comcrap had no clue.
Their phone rep suggested I come in and trade out the remote. That seemed unlikely if others are having the same experience. It is also unlikely a phone rep would have any answer other than what on the web page.
I used 5 digit code "10060" and it worked got the double flag from the remote like Comcast's documentation says. It turns TV on and off and works volume. So far so good.
The key to figuring it out was getting the double flash on the remote 4 digits didn't 5 did.
The moral of our story? Comcast has no clue what they push out the door. I guess that isn't a surprise to anyone.
Posted on Jan 13, 2008
10812 works perfectly for ln-t4671f.
Posted on May 26, 2008
I just bought a Samsung 32" LCD and tried all the five digit codes listed in this thread, but none of them worked. I downloaded the PDF from Comcast for the 3-in-1 On Demand remote. The first code I entered was 0060. This worked, but like it was stated in previous posts the volume control had to repeated pressed to change the volume. The second and third codes didn't work, but the fourth code (0702) worked and the volume control operated smoothly after that.
Posted on Nov 26, 2008
  • Katana Threed
    Katana Threed Aug 27, 2015
    This code worked for my UHD7100. THANK YOU SO MUCH
Many thanks to "badshoe" for the Samsung fix. I was trying to help a neighbor with a new 50" plasma and none of the suggested codes nor the search method worked, and of course Comcast was zero help. Programmed 10060 and Hooray!
Posted on Jan 20, 2008
10060 fixed my samsung 46 Led,thank you
Posted on Apr 26, 2009
10702 worked for my Samsung 19" LCD.... I had the issue with the volume not going up or down fluidly... problem solved thanks to you folks!
Posted on Jan 26, 2010
I tried using the five digit code (10060) with no luck. Then I dropped the 1 and used 0060 and it worked.
Posted on Oct 29, 2010
I have a 32 inch samsung led and programmed the comcast remote and the channel change will work but the guide and volume wont work unless switching back and forth between tv and cable? Weird! Anyone else have this or have an idea
Posted on Jan 30, 2012
  • Kurt Andrew
    Kurt Andrew Nov 13, 2013
    I had the same issue... buzzkill
No codes worked for me and the search feature didn't work either. I found that the comcast remote expected 5 digits not 4 as it said in the directions. I added a 0 or 1 as the first digit and it now controls the TV.
Example comcast code was 0060
I used 10060 and it worked properly.
Give it a try.
Posted on Sep 27, 2008
    Problem Solver:
BadShoe is BadAce! Thanks, worked on my Samsung HPT-5054 50" Plasma
Posted on Apr 18, 2008
Too true... more than a bit unfortunate. Any chance there's a mailing list I could be added to in case a fix comes about someday?
Thanks,
bren384@hotmail.com
Posted on Jan 15, 2008
  • Samsung Master
  • 1,908 Answers
Http://www.superior-electronics.com/superior2_1.php
Superior Electronics i like this brand very much the 4:1 telecontrol for 1 remote to 4 different devices and very much differend brands , http://www.telecontrol.tv/ Its even not to expensive and good long lasting device . and the special programmer to program the remote for much brands
Posted on Dec 07, 2016
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 158 Answers
You have to scan and re set your cable box to sync your remote with the TV.
Posted on Sep 03, 2015
    New Friend:
  • 3 Answers
Thanks to Freddie Mac as the code 0702 worked for my 7100 65".
Posted on Aug 27, 2015
    Cheetah:
  • Samsung Expert
  • 74 Answers
Samsung remote control are only universal for samsung device only
Posted on Dec 28, 2014
As of July 2012, Comcast documentation lists 5-digit codes (e.g. "10814") but I found that only a 4-digit code ("0814") worked for my Samsung PN40C450 LCD television set. If nothing else works, you might want to try each code in the Comcast documentation without the leading "1".
Posted on Jul 24, 2012
    Problem Solver:
  • 9 Answers
10060 Worked for a Samsung LN32A550P3FXZA
Posted on Jun 22, 2010
Samsung 55" LED LCD UN55B7000 also works with this 5 digit code 10060
Thanks!
Posted on Sep 08, 2009
  • Guest577789 Sep 08, 2009
    Thanks!
0060 works with the Samsung PN42A400C2D Plasma - This is with the comcastcustom dvr 3 device remote. Many thanks!
Posted on Dec 18, 2008
Comcrap's remote wouldn't work for my new Samsung 52" LCD TV but I used the code 10060 and all is well, thanks for the help!
Posted on Oct 17, 2008
10060 worked for me on the Samsung HLT5076S with the Comcast remote. Thanks!
The only caveat is that if you want On Demand, you have to press the Cable button on the remote, then the On Demand button. If you forget to switch back to TV on the remote, powering off via remote will simply turn off the cable box. However, volume and channel control still work under Cable. This is strange as volume did not work on the Comcast remote before entering 10060.
Posted on Aug 05, 2008
10060 worked for me too. I have a TX S3082WH Slim Fit.
The comcast manual says it should be a 4-digit code, but it is not. The 5-digit worked like a charm. Took me hours to find this solution.
Posted on Jun 29, 2008
"i did notice however the volume only goes up by one every time i press it"
I had the same issue; I used the TV code 10702 to fix it.
Posted on Jun 02, 2008
  • Eliza Winters
    Eliza Winters Oct 17, 2011
    Thanks for the code. I love me led flat screen tv but I hate when I cannot figure out how to manipulate the remote. The code worked beautifully and I am back in business. Thanks for the help.http://directdealsoutlet.com
Thank you "badshoe." It seems as though no one really knows what they're talking about except for you. Much appreciated.
Posted on May 31, 2008
I went to the website listed below and followed the directions for "Searching For Your Code"
http://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Hope this helps. It worked great for me!
Posted on May 18, 2008
10060 does the trick for the new Samsung 550 series
Posted on May 10, 2008
0060 worked for me.
Have a Comcast DVR-3 remote, pressed TV, then hold Setup until TV blinks twice, then press 0060. TV will blink twice, and now can turn on/off and change volume.
Posted on Apr 19, 2008
  • 1 more comment
  • dianebandyk Dec 29, 2010
    used your info....worked great.thank you
  • ramkankanamp Mar 26, 2011
    COMCAST UNIVERSAL REMOTE + 0060 code worked for my SAMSUNG LCD.
  • Angel Castagnaro
    Angel Castagnaro Nov 12, 2011
    Thank you so very much! I have not been able to use my remote for my tv! Finally this worked. You are the best!!!!!
10060 worked for an LNT5271F, even though the manual for comcast says only 4 digit codes, i did notice however the volume only goes up by one every time i press it, whereas the Samsung remote if you hold it down goes up by itself.
Posted on Mar 02, 2008
060 worked for my 4042 on the Comcast/Motorola remote. 038 worked on the Samsung remote to run the  Comcast/Motorola cable box.
Posted on Feb 21, 2008
10060 worked for me also. Samsung 42" plasma MODEL SP-S4243
Posted on Jun 13, 2008
Need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Jun 04, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
AKAI 27"LCD SN:60683669 Have HDMI connect o
Universal remote controls (like the one for your comcast cable box in which it allows you to control other devices) have "the most popular" IR codes programmed inside of it. When you type in the numbers "10812,10702, etc" you are telling the remote to use that particular IR code within its "database"
The key thing to know is that universal remotes do not have every code, just the most popular. If you have tried all of the codes listed in the manual for you model TV there's not much you can do.
  • Try searching for a code. Some brand names, such as "Akai" may have other manufacturers parts inside of it, Searching usually is done by going through certain key-presses on the remote to try all of the codes available.
  • Buy another Universal remote, not all remotes are created equal as some have mode IR codes built in than others, if you have an odd brand TV, it may be more difficult to come across one that works.
  • Buy a learning universal remote, although usually more expensive these remotes will allow you to "learn" the IR codes from your old remote to the universal remote.
I hope this helps.
Mar 06, 2011 | Akai LCT2721AD 27 in. LCD Television
Direct tv remote code for Sylvania LC320SLX
Get the Direct TV RC65 and program in code 11864. It works I just programmed my LC320SLX.
Dec 19, 2009 | Sylvania LC320SLX 32 in. LCD TV
No Comcast remote code
http://www.comcast.com/corporate/customers/customer_support/remotes.html
If you look at the instruction sheet for your remote under 'searching for your code' you will see:
SEARCHING FOR YOUR CODE
If your home entertainment device does
not respond to the remote control after
trying all of the codes listed for your
brand, or if your brand is not listed at all,
try searching for your code.
For example, after trying all of the
codes for your TV, you still cannot get
the remote control to operate your TV,
then:
1. Turn on your TV.
2. On the remote control, press TV
once. Then press and hold Setup
until the TV key blinks twice, then
release Setup.
3. Enter 9 - 9 - 1. The TV key will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing Power and TV.
Stop when the TV turns off. A
working code has been found.
NOTE: In the search mode, the
remote control will send IR codes
from its library to the selected device,
starting with the most popular code
first.
5. Press Setup once to lock in the
code.The TV key will blink twice.
6. To search for the codes of another
device, repeat steps 1 to 5, but
substitute the AUX key for the auxiliary
device you are searching for
Nov 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Need codes for remote control access to go with Comcast hd adapter remote. Only 2 listed with remote from Comcast: #'s11723, 12066 Comcast remote will not control TV
If you look at the instruction under 'search for your codes' it will tell you how to scan all the code until you find the one that will work. Down load the manual here for your remote:
then:
1. Turn on your TV.
release Setup.
blink twice.
first.
Nov 02, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Sony tv comcast remote code the codes 0000,0111 dont work
if your remote has a red ok button then you need a five digit code. try 11100, 10000, 11317. if you have a remote with a gray ok button then 0000 should work. if this doesnt work, write me back telling me what color your ok button is and i will send you instructions on how to scan for your code.
Oct 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Jul 21, 2009 | Sylvania LC420SS8 LCD TV
Can My Comcast TV Remote Connect To A Sharp TV
the codes for Sharp LCD's are 10093 and 11602...follow the normal programming instructions but use these codes....newer remote manuals may have these codes but however the one i had didn't...hope this helps
Dec 31, 2008 | Sharp Remote Control
Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Dec 13, 2008 | Samsung LN32A330 32 in. LCD TV
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
31,714 people viewed this question
Jerry Greenberg
Jerry Greenberg
