New wireless Lexmark printer won't print
I recently purchased a wireless Acer computer and a wireless Lexmark printer came with it. I followed installation instructions. However, when I try to print a document, the printer seems to accept the command but does not print it, nor does it provide an error message indicating that the printer failed to print.
I have also connected the printer to my old computer - not wireless. The printer seems to work off the old computer. Both old and new computer operate on a local network in my home.
Any suggestions on how to fix the problem?
I have a new wireless password. My printer has a solid green light. I can't get it to print. How do I put my new password in?
From page five of the printer owner's manual:
(You may need to connect the printer with the USB cable during this process)
Changing wireless settings after installation To change wireless settings on the printer, such as the configured network, the security key, or other settings: Using Windows 1 Do one of the following: • In Windows Vista, click . • In Windows XP, click Start. 2 Click Programs or All Programs, and then select the printer program folder from the list. 5 3 Click Tools Œ Lexmark Wireless Setup Utility. Note: If the cable is not already connected, you may be prompted to connect the printer to the computer again using the installation cable as part of the setup process. 4 Follow the prompts on the computer screen to reinstall the software, and then make the changes that you want. Using Macintosh 1 From the Finder desktop, double-click the printer folder. 2 Double-click Lexmark Wireless Setup Assistant. 3 Follow the instructions on the computer screen
You can find the full owner's manual here:
http://www.lexmark.com/publications/pdfs/2007/2420/13L0828.pdf
Oct 05, 2015 | Lexmark Z2420 Printer
I recently purchased a Lenovo All in One wireless computer. I've plugged in the USB cable as per instructions but my X4650 printer will still not print.
Have you installed the printer drivers? Is the printer power turned on before plugging the USB cable into the computer? You could have a bad cable. Try a different cable.
Dec 13, 2014 | Lexmark X4690 Wireless InkJet Printer
My Lexmark s605's print queue won't clear, and so the printer has stopped working altogether
Please follow the steps below to clear the print queue and restart the print spooler of your computer.
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Jan 07, 2012 | Lexmark Interact S605 All-in-One Color...
I have a Lexmark S504 wireless multifunction printer. I can print a test page but a can't print anything from any application. The Windows print page window comes up and if you click OK it appears to...
It could be a printer driver issue. Please follow the steps below to fix the problem.
First, clear the print queue from any stuck print jobs. You can do the steps mention - going to Services and stop the print spooler, delete the files in the spooler folder and then restart the service.
Second, delete the existing Lexmark Interpret S405 printer driver. On your computer, go to Start menu > Programs > Lexmark > Uninstall. After the uninstall process, reboot your pc when prompted.
Third, visit the Lexmark website to download and reinstall the Lexmark Interpret S405 printer driver. Select the version of your Windows operating system. Download and execute the file. Follow the instructions on your computer screen.
After the reinstall process is successful, try to print again to verify that the problem is fixed.
Sep 07, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My lexmark printer will not print recently moved using new provider for internet computer is mac os x
If your printer was connected wireless to your system prior to changing internet provider, you may need to reset your printer's wireless network adapter first and then reconfigure it to reconnect to your new wireless network.
If you need the Lexmark printer driver for your Mac, please visit www.lexmark.com.
Sep 01, 2011 | Lexmark C533DN InkJet Printer
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
I recently purchased a new Mac Pro computer with OS 10.6.3. I installed the 4600 CD then discovered that It does not work with this OS. I downloaded the upgrade from Lexmark and installed it. Now I get...
I suggest you uninstall the Lexmark software first. To reinstall, click on this link to download: http://bit.ly/9xRlVn. Execute the file and follow the instructions on the software. Thanks.
Aug 05, 2010 | Lexmark X4650 InkJet Printer
I recently purchased an acer computer that has windows vista. I have a hp2200dn laser jet printer and I want to hook it up by ether net into a wireless router. Unless this printer is wireless. I have a...
All you should need to do is connect the HP printer to your wireless router via Ethernet cable (which should be included with the printer). Follow the instructions that came with your printer to set it up on your computer.
May 13, 2010 | HP LaserJet 2200dn Printer
Cannot print from laptop to printer using wireless print server
This is probably the Software Firewall on your laptop
you should probably tell your firewall software that you have an internal network (Laptop-desktop-printer) you should add the IP range of the wireless network as a trusted network.
May 25, 2009 | Lexmark X3550 ALL-IN-ONE InkJet Printer
jasbo
jasbo
