Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Initial setup on Bravia 26" won't come up
The initial setup function will not boot up when the tv is turned on. The tv is set to cable instead of antenna and i'm not able to change it via the initial setup - or anywhere else in the software.
  • 448 Answers
Try resetting the TV to the original factory settings. After resetting the TV to the original factory settings, you can get the initial setup screen to select Antenna. Make sure that the cable from the Antenna is connected to the TV.
Follow the steps given below to reset the TV to the original factory settings:
(i) Turn ON the TV.
(ii) While holding down the Up arrow button on the Remote control supplied with the TV, press the Power button on the TV set. The TV will turn itself off then back ON again.
(iii)Next, release the Up arrow.
Posted on Sep 08, 2009
MY tv that goes straight to the screensaver mode like it would on pc. sony bravia kdl32nl140 is the tv.
J, it sounds like it may not be getting any input from cable or satellite, try switching cable and inputs around, try VCR or DVD player. You may need a firmware or software update.
Some forums say to unplug and wait 10 min. then it resets.
Check links below.
Sony eSupport KDL 32NL140 Support
Stuck with initial setup screens on my Sony Bravia 4k Android TV
Feb 21, 2016 | Televison & Video
After initial set up and download, TV is displaying a hand on power plug picture with a red circle and line through it and a refresh symbol in light blue next to it, what does this mean?
Hi! and Welcome to Fixya!
What you have on the tv screen is a warning sign that your tv is currently updating its software. A hand holding a power plug with red circle on it says do not unplug the tv while its running the software update. The usual time for the update to finish is 60 minutes. It may took more than 60 minutes if you have a slow internet speed. This is normal especially if you are running the software update for the first time during the initial setup. The next time tv performs software updates it will take shorter time.
However, if the updates took more than two hours, the tv may be frozen. You can unplug and plug it back in and start from the initial setup again.
On some rare occasion, the tv may not proceed with the initial setup. You may have to turn off your modem to complete the initial setup. when initial setup is done, connect your tv to network and run software update again.
Let me know if you still have other questions.
Sep 07, 2015 | Sony BRAVIA KDL-55W802A 55" 3D 1080p...
Sony bravia tv problems
1. Turn off the TV and unplug all the HDMI connections to the TV.
2. Turn on the TV and while holding down the up arrow on the remote control, press the power button.
3. The TV will turn itself off, then back on again then release the up arrow button
4. Complete the initial TV setup wizard
5. Turn off the TV and plug back in all the HDMI cables.
6. Check to see if the inputs are working.
Hope this helps.
Dec 31, 2013 | Televison & Video
I ve Sony Bravia KDL55EX713 55" TV, it keep showing me input banner showing(Bravia,LED,presence sensor,Motion flow,Full HD, BE3, WIFI HDMI etc.) I have tried display button, and all settings on...
Your TV is in store demo mode.
To fix this, access the TV's menu and find the option to run initial setup. At the beginning of initial set-up, you'll be asked whether or not the TV should be put into Home or Retail mode. Choose Home.
Mar 15, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I can't turn off the demo mode on my sony bravia tv
Press Menu on tv remote, go to Settings and select Factory Reset and press enter button on remote, tv will reset to factory default settings and turn Off and On again itself, now select HOME mode instead of Shop mode to avoid demo mode and go by initial setup screen instructions.
Above are generic info about Sony bravia tv, let me know model number of your tv if you do not see factory reset option in settings menu.
Thanks.
Nov 08, 2010 | Sony Televison & Video
I HAVE A SONY BRAVIA MODEL KDL-40W4100 WHICH IS SUPPOSED TO HAVE tvgos but my tvgos does not work at all, no channel listings, nothing
Be sure to complete the INITIAL SETUP to use this service.
If you have an user manual you may check it out for help to complete the INITIAL SETUP. Or else, you can have the correct page of INITIAL SETUP here:
http://www.retrevo.com/pdf/23566bh638/21/Setting+Up+the+Channel+List+–+Initial+Setup#q=Sony+KDL-40W4100
This link refers you to the page 16 of the user manual of your model. Please check page 17 also to complete the INITIAL SETUP. To go to this link, just copy-paste it in your address bar.
Jul 09, 2010 | Televison & Video
I have a Sony Bravia BX300 Engine 3 and its Demo mode is always on (even if I press RETURN button to exit demo mode). How could I turn it off permanently???
you should restore the factory settings to do this
  • Turn on the TV.
  • While holding down <up arrow> button on the remote control, press POWER on the TV. (The TV will turn itself off, then back on again.)
    Release <up arrow>
  • IMPORTANT: The reset will clear all of your customized settings
    including the Parental Lock setting.
  • initial setup run automatically
  • if you have doubts on initial setup download this pdf
Jun 14, 2010 | Televison & Video
TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Apr 17, 2010 | Sony BRAVIA KDL-46V3000 Television
Vizio 320m. I set it up wrong. Instead of choosing
You should be able to use the input/source function on your remote to select which signal sources you want the TV to display, find out which input on the TV you have the cable box hook it up to then just select that input. Do you still have the user manual?
Oct 31, 2009 | Vizio VL320M 32 in. HDTV LCD TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
992 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
