Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
HUSKY 26 Gallon Shuts Down After <75PSI!?
I have the same problem! My 26 Gal HUSKY Vertical Compressor has a mind of it's own. It automatically shuts down just before reaching 75 PSI. I have emptied the drain and a small amount of water came out. Did that a couple more times to test it out. I still encounter the same problem. It's almost as if it is overheating or a circuit breaker is tripping within the unit itself. If anyone has resolved this, I'd really appreciate a helping hand! Thanks in advance!
    Brigadier General:
  • 4,088 Answers
Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
Posted on Sep 08, 2009
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
    Free Husky Air Compressor User Manuals ' ManualsOnline ...
    powertool.manualsonline.com > ... > Husky > Power Tools Husky
    Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
    Sep 04, 2015 | Air Tools & Compressors
    My husky 26 gal air compressor will not stop running
    Sounds like you have a faulty shut-off switch...
    Replace the shut-off switch with a new one...make sure it is of the same shut-off and turn on values
    Mar 30, 2013 | Air Tools & Compressors
    Compressor reaches 125 psi but does not shut down
    Depending on how old your compressor is, usually inside the pressure regulator cover are instructions on how to adjust the turn-on and shut-off pressures. If not, it usually invloves turning a nut or screw to lessen the pressure on the spring that keeps the contacts closed. Try adjusting the pressure down. If it won't come down to a safe level you will be better off replacing the pressure switch. The number you give above is the Campbell-Hausfeld (they are Husky) part number for the pump and motor assembly so I don't know which CH pressure regulator you need. They are easy to find and easy to replace.
    Jun 21, 2012 | Square D 9013FHG14J52M1X Air Compressor...
    CAN YOU STAND THE Husky WL651004AJ UPRIGHT?
    Your compressor will work in the vertical position however you will not be able to properly drain the water from the tank in this position.
    Feb 18, 2012 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    My husky air compressor model is WJ10064AJ. I got this compressor my brother in law. The compressor runs but the pressure is low. It shut off at 75 psi and 75 lbs on air. I have to shut it off for a while...
    All of your problems indicate the pressure switch is bad. I don't know which part number to recommend because Campbell Hausfeld (Husky) model numbers have six digits and there aren't any model numbers or part numbers I can find that start with WJ. You need to contact Campbell Hausfeld (1-800-543-6400) to see what part you have to order to fix your compressor.
    Mar 21, 2011 | Air Tools & Compressors
    My regulator broke and I just replaced it. Now the compressor doesn't act like it will automatically shut off when it reaches pressure (130 psi max). Last night it pressured up to right at 130 psi and...
    Hi, my name is John. Welcome to FixYa. Look on the pressure switch and see what the max. is. I have some notes here I will have to locate them and I will post them here if you still having problems, but it sounds like you need to replace the pressure switch. Thanks for choosing FixYa...John
    Nov 20, 2010 | Craftsman 33 gal Air Compressor 6 hp...
    I have a ch 28 gal (wl611700aj) air compressor,it pumps up to 80 psi.wont pump up any further but does keep running.whats your thoughts?
    Here are a couple of things to check. While the compressor is running spray soapy water on all airlines, fittings, bottom of pressure switch, regulator and drain valve to make sure that they are not leaking. A small leak will prevent the unit from reaching cutout limit. Repair as needed. Next unplug compressor and remove cover to expose cylinder and piston. Move piston to top of cylinder and check for scratches or wear neer top of cylinder. If scratched, air is bypassing piston ring and will not reach cutout pressure. If cylinder looks good and no leaks then problem most likely is valve plate/ reed valves or head gasket. Problems within head will cause low pressure and air line to tank will be very hot. Bad reed valves will also cause air to blow out of intake when it reaches 75 to 80 psi. Parts are available at www.chpower.com or at www.toolpartsdirect.com. Good luck
    Sep 11, 2010 | Campbell Hausfeld 26 - Gallon Air...
    Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
    1,032 people viewed this question
    Top Campbell Hausfeld Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
