Question about Samsung DVDR120 DVD Recorder
DVD-R120 hookup for recording
It seems as though I cannot hook my DVDR120 up to record, because all of my inputs/outputs are occupied. I've read through the forums, manual, and I still cannot find a solution to my problem.
All of my equipment goes through my receiver, which means that I have nowhere else to plug in to record...
Please help, or else I'm gonna just hook up the old dvd player....
  • buckeye77 Mar 19, 2008
    thanks alot zucktucker, I appreciate the help!!
You will have to hook up your recorder directly to your TV or use as a stand alone recorder.
Other possibility is to buy a 2 way video switch. This will allow you to hook up two video machines to the same input jacks on the RCVR. You just swith between the two devices manually.
Radio Shack usually have these input swithches under $30.
zucktucker
Posted on Mar 02, 2008
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Samsung DVD-R120, can I save what?s on a DVD-R that won?t play?
If it will not play either on the recorder it was recorded on or any other player, you need professional help retrieving the data. There are places where this can be done, but it will probably cost MANY times what the disc does.
Jan 21, 2009 | Samsung DVDR120 DVD Recorder
Dvd r120
try a new DVD-RAM disc but do not format it,just pop it in and record
May 28, 2008 | Samsung DVDR120 DVD Recorder
Background noise
Check the cables in the back If i remember the Component Red jack is right next to the audio out jacks (also a red jack) if the audio cable is hooked up to the component jacks this will cause a humming static noise
Apr 12, 2008 | Samsung DVDR120 DVD Recorder
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
DVD-R120 high def recording???
No, it will not. It is not a hi definition recorder.
Oct 18, 2007 | Samsung DVDR120 DVD Recorder
Samsung dvdr-120
try checking on the recording mode of the DVD. V recording mode produces more compatible DVD disc. Stay away from VR mode. You may refer to your manual.
Jul 26, 2007 | Samsung DVDR120 DVD Recorder
Samsung DVDR120 DVD Recorder Logo
95 people viewed this question
Jerry Greenberg
Jerry Greenberg
