The image of my projection tv keeps warping and spliting into three images one red one green and one blue whats wrong with it
  • 80 Answers
You either need new convergence chips or to resolder them, it is so much trouble to remove the board and get to the chips, i just change them anyway, they are the most common thing to fail in all rear projection crt tv's.
Posted on Sep 08, 2009
My tv had three screen, what do I do to get it off
Sounds like your convergence board went out. This board aligns the Blue image to impose over the Green image and also the Red to again impose over the Green. This will take a TV Technician to replace and to fine tune your TV's image.
Nov 06, 2014 | Televison & Video
I have a 63' projection TV. The picture is off. All of the lights are working, but the images are fuzzy, and you see the image tripled. The three images overlap each other in red, green, then blue. ...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 09, 2011 | Philips 55PP9363 55" Rear Projection...
The projection off my t.v. is off. Images over lap one another and I can see double of a single image. I this able to be fixed?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 07, 2011 | Hitachi 43F300 43" Rear Projection...
Image is off ... green red and blue not aligned
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 26, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I turned my tv on this morning and the colors were all out of wack. the tv was producing an image similer to what an old 3d movie with the red and blue images. i tried reseting the tv to factory default...
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
Rca hd52w59 tv has red, blue and green lines at the top and the images are doubled. What is wrong?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
My screen showes triple image with green and red siloettes like it should be 3D but it is not this just came on overnight What might be my problem
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | RCA R52WH76 Television
I 53" Hitachi Projection TV and I get double
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 10, 2011 | Hitachi Televison & Video
Image is green color............what is wrong with the tv?
It means that the blue and/or red picture tube (bulb) is not working properly. It could be the tube(s) or the circuits that drive the tube. My money is on the circuits.
Apr 22, 2010 | Philips Magnavox 51MP392H Rear Projection...
Images: three colors appears separates in the screen: red, green, blue
do they look like these:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
