Question about IBM ThinkPad T30 2366 Notebook
How do i replace a removed key from the keyboard
    President:
  • 2,600 Answers
These usually attach to a scissor like bracket that is secured above the sensor pad. Take a good look at the orientation of how the mount attaches to the keyboard. If the mount has stayed on the board itself and just the cap is off, then it is a matter of slipping the cap on one side and using gentle firm and consistent pressure roll your finger to the other side so tha cap snaps in place on the mount. Sometimes a little back and forth action will facilitate the attachment. If the mount came off too, then look at the board and you will see small attachment cutouts where the legs of the mount snap into. On one side there may be a slot where the mount anchors and the other side snaps into a raised groove. The trick here is to work from one side to the next, using small deliberate movements. The mounting points can take a lot of abuse from typing but not when detached from their mounting.
Posted on Sep 08, 2009
I want to safely remove, clean and replace all keys on the Dell 610 keyboard
HI michael so if you want to clean your keyboard so first you must take off the keyboard from you laptop .
Let's remove the keyboard. Insert a flat head screwdriver between the keyboard bezel and laptop case and carefully lift up the bezel. Remove the bezel.
You'll find two screws securing the keyboard. Remove both screws.
Now carefully lift up the keyboard. You'll see the default memory module under the keyboard, right above the touch pad buttons. It's possible to replace the memory module without disconnecting the keyboard.
Disconnect the keyboard . Simply grab the blue tag attached to the keyboard connector and pull it up. Now you can remove the keyboard.
So now with removed keyboard you can clean it .
Jan 22, 2013 | Dell Latitude D610 Laptop Computer -...
Keyboard won't work
When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
Jan 15, 2013 | Lenovo b560 Notebook
My keyboard wont type
Restore a Laptop Keyboard b> When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
b>
Jan 11, 2013 | Samsung N145 Plus 10.1 inch Netbook -...
Need to replace broken key on keybord. plastic appartus on key underside broke
Remove sticky tape securing the keyboard cable to back of the keyboard.Part of the keyboard cable is glued to the keyboard. Carefully separate the cable from the keyboard.Start peeling off the aluminum protective film Remove the protective film. After the protective film is removed it's really hard to attach it back to the keyboard because it's deformed.Most laptop keyboards have some kind of plastic separators.
These separators secured on the back of the keyboard.
Plastic pins are melted on the back of the keyboard and retain separators in place.Push all plastic pins though wholes on the keyboard.Start removing the separator.The plastic separator has been removed.
Now you'll have to remove all key caps.
Before you start removing key caps, make a picture or xerocopy of the keyboard so you know the order in which keys are attached to the keyboard.In order to remove the key cap carefully lift it up with your fingers.Remove the key cap so the hinge underneath stays connected to the keyboard.
Some big keys have a different design.
In addition to the hinge, some big keys (Back space or Space bar for example) might have an additional support bracket.Remove the key cap with the support bracket. As you see, the key hinge stays connected to the keyboard.Some laptop keyboards might have blank covers on the left and right sides from the up arrow key.Lift up and remove the blank cover.All keyboard key caps and plastic separators have been removed.Now you can start removing key hinges - key lifting mechanisms.Carefully separate the key hinge from the keyboard.
Each key hinge has two parts - external and internal pieces.
When you remove the hinge, try to keep these parts connected to each other the same way they are connected on the keyboard.If the external and internal pieces got separated, you can assemble them together.If you following this guide to repair the keyboard, I would recommend to keep all hinges in the right order.
The keyboard has two sheets laying one on the top of another.
Remove the sheet with silicone (or rubber) nipples.Remove the second sheet with traces.Both sheets have been separated from the keyboard base.The sheet with traces has two layers and all traces are running between these layers.In order to access and repair traces you'll have to separate to layers from each other.The keyboard has been disassemble.
As you see it's not easy to disassemble a laptop keyboard and even harder to put it back together.
Is it worth repairing? Probably not. These days you can find a new laptop keyboard very cheap.
Oct 17, 2010 | HP Pavilion ZD7140US Notebook
Keybd keys are sticking
Be prepared to buy a new keyboard... Remove AC and DC power before working on laptop. Many laptop keyboards come off with the removal of 1 to 5 screws from the bottom. Some, however, require the palm rest to be removed, then a couple of screws that hold in the keyboard. Be careful when removing and replacing cables.After removing keyboard, rinse with water and let dry thoroughly before re-attaching and powering up. You cannot remove individual keys, so don't try.
Apr 12, 2010 | Fujitsu LifeBook S6510 Notebook
The m and caps lock keys on my Toshiba satellite
Bad keyboard. This series have a higher frequency of keyboard problems because ... well .. the keyboard cable got folded by design. Just replace it. The A40's uses the same keyboard as a A10, A15, A55, A60, A64, 1400, 1405, 1410, 1415, 2400, 2405, 2410, 2415 ... and many others. A new replacement keyboard should run about $20 on eBay.
Replacing the KB is easy: lift up the power button board above the keyboard, remove the three screws holding the keyboard down, then remove the keyboard connector cover panel, and you'll be able to disconnect the keyboard.
Oct 11, 2009 | Toshiba Satellite A40 Notebook
Kid spilled soda now keyboard will not type
Hi There !!
Thank you for choosing Fixya. The chances are rare that it would work, because liquid may have done damage to the integrated circuit.
But we can give it a try:
What you will need:
  • lint free cloth.
  • dry cloth or duster.
  • suitable cleaning fluid (isopropyl alcohol).
  • cotton buds.
  • Can of compressed air or vacuum cleaner.
  • Flat tip screwdriver (optional for thorough clean).
Shutdown your PC and remove the mains plug, unplug the keyboard(remember where it was plugged in) and hold it upside down to releaseany debris from inbetween the keys.
This is where the patience comes in, make a note ofthe position of all the keys or you will have trouble putting them backcorrectly, alternatively just remove the letter keys A - Z from the keyboard (which is where the most of the dust/debris will be) and refer to fig 1.4 as a reference to put them back.
All the keys can be removed although the larger keys (space bar, enterkey, shift keys, backspace, caps lock, etc) can be difficult to putback so you might avoid removing them.
Remove the keys using the screwdriver, ease the screwdriver under the key and gently lift the key top off (see fig 1.3).
note: don't forget to make a note of their position !! remove-key-cap.jpg keyboard-layout.gifWhen you have removed all the keys (except any keys youwish to avoid) use the compressed air (or vacuum cleaner) to remove anydust and debris from inside the keyboard.
Now is a good time to give the keys a proper clean, for bestresults clean each one individually (the patience thing again) with thecloth and cleaning fluid, when clean, wipe them over with the drycloth.
Before replacing the keys, take your lint free cloth anddampen it with your cleaning fluid (don't put the liquid directly onthe keyboard), give the surface of the keyboard a good wipe overensuring to clean as much as possible any keys that you haven'tremoved.
When the keyboard is nice and clean replace the keys according to your notes or if you have just removed the letter keys use fig 1.4 as a guide, to put the keys back on position the key in place and press gently but firmly until it clicks home.
After replacing all the keys give the keyboard a quick wipe over with your dry cloth and you have a nice clean keyboard.
Hope this will help !
Regard's
Sep 03, 2009 | Computers & Internet
Laptop keyboard "dropping" key strokes
If this happens always with same key, then it is usually a bad key switch, and keyboard must be replaced.
If this happens randomly on a set of keys, then the keyboard flat ribbon cable is not well connected or is faulty, or the keyboard is faulty.
The laptop must be taken apart to check the keyboard connection.
The keyboard on dell is accessed removing determined screws underneath, then removing the upper cover that enclose pad and armrest.
If the keyboard is well connected, and fixing connector does not solve the problem, then the keyboard must be replaced.
Jul 31, 2009 | Logitech Wireless Access Duo Optical...
Sticking keyboard keys on toshiba satellite L10
you could remove the keyboard but it probably wont do any good. They keyboard on a laptop is typically a solid slate with individualy key slots that can be individualy removed and replaced. simply pop the key off, use a alcohol swab and press firmly to replace....its just that easy,...and no tools needed!!!
it wil probably take an hr or so to finish all the keys.
Good Luck!!!
Mar 11, 2009 | Computers & Internet
IBM ThinkPad T30 2366 Notebook Logo
51 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
