Question about E-Machines T6528 PC Desktop
Have emachines T6528 graphics problem
Computer turns on but fan just runs and screen says check connection cable. have tripled checked everything even installed new nvidia geforce 8400 for PCI. computer still won't boot, screen still says to check cable. Can't get into bios. Please Help.
  • E-Machines Master
  • 4,924 Answers
If it doesn't boot at all .( this is the reason that you see that message on the screen it means that no video signal came out from the computer ) ..try to change the cable that leads from the pc to the monitor first ...and if the problem its still on ...it have to be something related with the Ram memory or the CPU ....cause these 2 are the only things that can make a system to do not boot at all ...if any other device will not work ..the pc will still boot to bios ..or will still show the devices it finds on start ...even if is not able to succeed with the operating system boot...
so ...either it boots and you can not see anything cause the cable its damaged...( very possible cause this is the case it shows that message ...when the cable its shorted ..or unplugged ) or it doesn't starts at all cause of the memory or CPU ...
Posted on Sep 08, 2009
No display but the computer turns on.
could be an issue with the graphics controller or with the monitor. first, verify if the monitor is actually working. try it on another computer or video source. if it works, make sure that you have a working video cable and check to make sure the video input source (dvi, vga, rgb, hdmi.. etc) selected on your monitor is the correct one that you are using. if you have ruled out the monitor, video source and cables, you can then test if another monitor will work with the computer. if same thing happens, meaning nothing on display even the manufacturer or BIOS screen does not show up when you turn on the computer, it is most likely the video controller. you may either get the motherboard replaced or install an add-in video card if the integrated video controller only has one video connector.
Jul 17, 2013 | eMachines MS-7145 Motherboard 103777
How to fix 'no signal' when turn on PC?
it is something about your monitor not connecting well with pc, check graphics card
Mar 25, 2013 | E-Machines eMachines Desktop PC
Emachine ET1850 model when turn on no display picture.
Check ALL monitor cables, reseat connections. Have you done any hardware or software updates? Graphics Updates? Do you get anything at boot? Just no signal? It sound like a hardware issue, Graphics. Support for your machine can be found here: http://support.gateway.com/us/en/emac/product/default.aspx?modelId=2064 You could buy a PCI e x16 Graphic Card . Better ,faster Graphics. First, check VGA connections, reseat, check for bent pins. Try another cable and monitor, to verify.
Jan 02, 2013 | E-Machines eMachines Desktop PC
My computer starts up but the screen sa ys no signal
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
If its a 40 pin flat ribbon type it will be the first to fail.
Even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free.
Restart your computer then reinstall it this should activate found new hardware wizard
Check the VGA cable connection running from the computer to the monitor.
This cable must be completely inserted into both VGA connection ports, otherwise the video signal is not going to reach the display.
Disconnect the VGA cable from the computer and monitor, then look at the metal connectors on both ends.
If you are missing connection pins, the video signal is not going to transfer between hardware correctly.
To fix this problem, you must obtain a new VGA cable (at any computer or electronics store) to send the video signal.
Examine the power connection on the monitor.
If the monitor is not receiving power, it is not going to turn on.
Turn off the monitor for a few minutes, then power it back on.
Like other computer hardware, the monitor may not initially turn on correctly.
Move the mouse and press the "Enter" key on the computer keyboard.
If the computer is in sleep mode, the monitor is going to appear as if it does not have any display.
Hope this helps.
Nov 22, 2012 | E-Machines eMachines Desktop PC
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
Aug 19, 2012 | E-Machines T6528 PC Desktop
T6528 has no video. Using a working monitor, tried differnet video cards but still no video.
1) So you tested the monitor on a working computer? Reason I ask, is that you will be testing the monitor cable also.
If it is a monitor with a detachable monitor cable, suggest you test the cable also.
2) Each graphics (Video) adapter card has it's own specific driver.
The driver should be installed Before, the graphics card is installed.
Otherwise Windows will 'break it's neck', to find a compatible driver, from it's thousands of generic drivers.
Won't do. You will get a driver conflict.
Windows: 'Which driver do I use? These or THESE?"
Kinda' hard to do, since you can't see graphics on the monitor.
I would like to suggest you diagnose the Power Supply to start with. (After checking the monitor cable)
It may seem that the Power Supply is okay, but it could have a weak Voltage power rail.
Enough power to light LED lights, and spin fan's, but not enough power to turn the Processor on.
1) ALL the LED's use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use 51 to 125 Watts.
(Lower for older Processors)
The eMachines T6528 comes with an AMD Athlon 64 3500+, processor, that fits in a Socket 939 processor socket,
1) eMachines Support > T6528 > Specifications,
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6528
2) Information on the AMD Athlon 64 3500+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#Athlon_64
Can use up to 67 Watts, or up to 89 Watts. Depends on what Core it is.
(Clawhammer Core, Newcastle Core, Winchester Core, Venice Core, Manchester Core, or San Diego Core)
(Also uses an MSI K8NGM-L motherboard. Below for specifications only,
http://www.newegg.com/product/product.aspx?Item=N82E16813130041 )
A) Not to down eMachines, (I have an old T1090 in my shop that works great), but they are budget computers, and use budget parts.
One being the generic Power Supply that is used.
B) The computer could be dirty inside, as well as inside the Power Supply.
The cooling components for the SMPS, (Switched-Mode Power Supply,) are it's Fan, and Heatsink's used inside.
Once a layer of 'Gunk' covers these cooling components, the cooling capacity drops tremendously.
Heat = Wasted Energy
The more heat, the more the Power Supply strains to keep up with the call for power.
Eventually hardware components inside the Power Supply fail, and the Power Supply is toast.
You can test the Power Supply voltages.
You can use a multimeter if available, or an economical unit can be purchased for around $5 to $12, that will suffice for testing.
You can also use a power supply tester.
One example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471
Voltages produced by the SMPS used in a T6528 are,
A) 3.3 Volts (DC)
B) 5 Volts (DC)
C) 12 Volts (DC)
Testing should be done on the 12 Volt power rail.
11 to 13 Volts indicates a good Power Supply.
Less than 11 Volts means it's time to replace.
Orange wires are 3.3 Volts
Red wires are 5 Volts
Yellow wires are 12 Volts.
All the color coded Voltage wires, lead back to one individual power rail, for each Voltage produced by the Power Supply.
You can test any Yellow wire to test the 12 Volt power rail.
With a multimeter, the Positive (Red) probe lead connects to the power wire to be tested.
The Negative (Black) lead connects to ANY Ground wire.
ALL Black wires are Ground wires.
They all go back to one central Ground source inside the Power Supply.
[Power Supply unplugged from power before attaching probe leads. After connecting, the power supply is plugged back into power, and the Power On button is pushed ]
(Two C cell flashlight batteries produce 3 Volts DC)
Jun 20, 2010 | E-Machines T6528 PC Desktop
My emachine has power but is not working
Hi friend,
Power is coming in system thats means your system motherboard & SMPS is working fine,There was a problem with RAM,RAM is faulty,please change it,it is fix under your system motherboard,this is esly removeable,
Thanks
Jan 30, 2010 | E-Machines eMachines Desktop PC
Emachine T6528 problem: My monitor wont boot up went i start the computer!
Easiest solution is to connect your monitor to another PC, if still nothing, then your monitor is toast.
If you are getting no display at all, and you tried a PCI video card and the onboard, most likely it is your monitor.
This is going to sound really dumb, but just incase, check to make sure both cables are snug in the monitor, I get calls daily at work with people telling me their monitor has died, only to find out that the power cord in the rear or the monitor is not completely snug.
Jan 22, 2009 | E-Machines T6528 PC Desktop
Computer won't boot up
Make sure that your power switch is connected to the correct pins on the motherboard. The LED you see lit may be the stand-by power indicator saying it has power and is waiting for the signal from the power switch.
May 06, 2008 | ASUS CROSSHAIR Motherboard
E-Machines T6528 PC Desktop Logo
284 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
