Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
John Deere 3020 1961 gas engine started backfire missing on
D1961 gas engine started backfire missing on acceleration. Put in new plugs, rebilt carb, new points and condensor. Started but sometimes dies out. If you accelerate it misses and backfires. Don't know what to do. Adjusting timing with distributor does nothing.escribe your john deere 3020 engine problems Problem
4 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
nova2nv
  • 197 Answers
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Posted on Nov 14, 2009
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
spiegela
  • 3 Answers
SOURCE: John Deere Model 445 garden
Do you know anything about the JD 445 engine?
Posted on Aug 06, 2010
My john deere is smoking and i can here it missing when it smoke all i smell is gas someone told me its the carb
well without the model number im guessing its a gas engine model , the condition your describing is a condition called "enriched" now in first start mode this is normal as a "choke" is placed on the inlet to carb to "enrich" the gas to allow it to start , after you place it to run mode then it should remove the choke and engine will increase in its speed and stop smoking and allows you to use it , if your engine isn't doing these things properly then its probable that your carb isn't preforming as it should and requires service (this doesn't allways mean replacement )
Sep 29, 2016 | John Deere Garden
TRY TO START BUT BACKFIRE THRU CARB AND WONT START AT ALL
roger, try a new spark plug, i just fixed a John Deere that took two days only to find out that the new plug out of the box was a bad plug. also check the fly wheel key , it may have sheered off.
Sep 24, 2015 | John Deere Garden
I have a John Deere 425 riding tractor that sounds like it wants to start but wont actually fire
Is the engine being cranked by the starter but it won't fire? You say you're getting spark? You need air, fuel, spark, and compression to start so...
Pull the air filter and see if it is blocked.
Inspect the choke plate to see if it is working properly.
Are the plugs getting wet when you try to start?
Take the gas cap off the fuel tank and try to start.
Take the plugs out and move the wires where they can't ground. Stick your finger (thumb) in one plug hole and with the throttle wide open and no choke crank the engine. Is there compression? Try the other plug hole. A compression tester would be better than a finger or thumb.
No compression can be popped push rods or a cam problem among other things.
Aug 26, 2017 | John Deere Garden
I have a John Deer riding lawn mower SX95 with a fb460v kawasaki engine that only starts with fuel dropped into carburetor I have a good spark , I had changed the oil and filter , I also took the carb...
in the carb did any of the screws have any micro bored holes for gas to go through like in many small engine iv found . clogged with goop. does it have a gas bowl an a screw on bottom take it out if does an look it over close.
Jul 25, 2014 | John Deere Garden
1988 vt1100 is backfiring and won't run, how come?
You have to clean the carbs and sync them. Before you take them off, drain the fuel from carbs bowl.
If the carbs do not have the same amount of air and fuel, then you have back firing and popping, and one of the cylinders will over heat, that is not good for the engine . If you changed the pipes to a custom ones, then just sync the carbs, if you can not sync them, then you have to change the 2 jets (slow and main) in the carbs.
Jul 20, 2014 | 1988 Honda VT 1100 C Shadow
155c john deere lawn tractor
Take the spark plug out and see what it looks like. If it's dark, sooty or wet smelling like gas, then you have a spark problem. Might need new plugs, a new coil or charging the battery up.
If the spark plug is dry and is a light tannish, brownish color than your problem is not getting gas. If that's the case, take off the fuel supply line to make sure you have gas to the carb. If that is fine, then you might need to take the carb a part to make sure you don't have plugged jets or passageways in the carb itself. If you want to find out quick, you can squirt a little gas into the carb intake and see if the the engine pops off. That will tell you as well.
Good luck
Jul 15, 2013 | Garden
John deere tractor wont take up throttle
try some lucas gas treatment. may have something to do with the float in carb. Might replace it and try.
Jun 20, 2013 | Garden
86 el camino stalls under load
As mentioned above, engine could be starving for fuel; but
also consider ignition system - as engine makes more power, maximum cylinder pressures increase. A higher spark voltage is then needed to ignite mixture (at a few degrees before top dead center... top of piston travel).
If coil is weak, plugs fouled, or plug gap too wide, adequate spark may not occur. This may cause missing,
loss of power, sometimes backfiring (backfiring may occur if timing is off, or intake valve leaky, also). If you replace the fuel filter, 'kit' the carb, but problem remains,
look to ignition system.
Diagnostic process - put a fuel pressure gauge in line, where fuel line enters carb. Rig so can see gauge, while driving. Have a passenger watch fuel pressure as you drive; especially while accelerating. If fuel pressure drops during acceleration, then its either fuel pump or filter. If pressure remains stable, consider carb issue.
If possible, test with exhaust gas analyzer, while engine
under load (possibly at an emissions test place). If lean under acceleration, its a carb problem. If not, look at
ignition system (emission test diagnostics should help here, also). Oh, and one thing I did once.... forgot to release parking brake..... duh.
Best of luck !
Dec 28, 2012 | 1986 Chevrolet El Camino
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
679 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
