Physics A female skater is spinning at 1 rev/s with her arms outstretched so that her moment of inertia is 3.6 kg by m squared. She then pulls her arms to her sides, which reduces her moment of inertia to 1.2 kg by m squared. What is her angular velocity?
  • 138 Answers
Lol you can ask Technical Support, User Guides and Repair Service only not your HOME WORK.
Posted on Dec 09, 2007
Ounces to grams 1ounce to grams
How to convert Ounces to Grams How to convert Ounces (oz) to Grams (g).
Ounces to Grams ? Ounces to Grams conversion table Ounces (oz) Grams (g) Kilograms+Grams (kg+g) 0 oz 0 g 0 kg 0 g 0.1 oz 2.835 g 0 kg 2.835 g 1 oz 28.35 g 0 kg 28.35 g 2 oz 56.70 g 0 kg 56.70 g 3 oz 85.05 g 0 kg 85.05 g 4 oz 113.40 g 0 kg 113.40 g 5 oz 141.75 g 0 kg 141.75 g 6 oz 170.10 g 0 kg 170.10 g 7 oz 198.45 g 0 kg 198.45 g 8 oz 226.80 g 0 kg 226.80 g 9 oz 225.15 g 0 kg 225.15 g 10 oz 283.50 g 0 kg 283.50 g 20 oz 566.99 g 0 kg 566.99 g 30 oz 850.49 g 0 kg 850.49 g 40 oz 1133.98 g 1 kg 133.98 g 50 oz 1417.48 g 1 kg 417.48 g 60 oz 1700.97 g 1 kg 700.97 g 70 oz 1984.47 g 1 kg 984.47 g 80 oz 2267.96 g 2 kg 267.96 g 90 oz 2551.46 g 2 kg 551.46 g 100 oz 2834.95 g 2 kg 834.95 g 1000 oz 28349.52 g 28 kg 349.52 g
Jul 20, 2018 | Office Equipment & Supplies
Discuss the term power
In physics, power is the rate of doing work, the amount of energy transferred per unit time. Having no direction, it is a scalar quantity.
In SI base units: kg?m2?s?3
Derivations from other quantities: P = E/t; P = F·v; P = V·I
SI unit: Megawatt
Reference - Physics Tutor
Feb 22, 2018 | Homework
Why do planets orbit the sun
In a word, gravity. The solar system is thought to have formed from a rotating disk of dust and gas with clumps in it. As these contracted the whirling sped up, like a skater drawing in her arms.
There is a law called the conservation of momentum which meant that when planets eventually pulled together in lumps, due to gravity, the spinning of each, and the spinning around the Sun, stayed on.
The Sun has held all this activity to itself in orbit by its massive gravity, which is still felt way out past Pluto.
Jun 11, 2014 | Computers & Internet
What is form?
Form is the stance of an archer when they shoot. The ideal form is for an outstretched and slightly flexed bow arm and a flexed horizontal and flexed bowstring arm at full draw. You should resemble the letter T.
Aug 26, 2012 | Betsey Johnson Archery
I have a 2000 gmc Jimmy . I'm going to change the
Locate the idler pulley to the left of the crankshaft pulley. The idler pulley bolts to the idler arm. The idler pulley is replaced with the arm because they are sold as one unit.
  • 2 Place a 3/8-inch ratchet driver into the square hole on the face of the idler pulley and pull up on the handle. This releases tension on the Sonoma's serpentine belt. Pull the belt off the idler pulley, lower and remove the ratchet handle.
  • 3 Remove the two bolts that secure the idler arm to the engine block using a socket and ratchet, and discard the old idler arm.
  • 4 Place the new idler arm against the engine block and secure it using the socket and ratchet.
  • 5 Put the ratchet driver into the square hole on the new idler pulley, pull up on the handle and place the serpentine belt over the pulley.
  • 6 Lower and remove the ratchet handle.
  • Oct 15, 2011 | 2000 GMC Jimmy
    Doing a physics problem and when dividing i am getting wrong exponents coming up as E16 when should be E4
    In scientific problems the powers of 10 are the easiest thing to handle if you keep in mind two or three rules.
    1. 1/10^(a) = 10^(-a)
    2. (10^a)*(10^b) = 10^(a+b)
    3. (10^a)/(10^b) = 10^(a-b)
    4. (10^a)^b=10^(a*b)
    Example : suppose you want to calculate the charge to mass ratio of the electon
    m_e= 9.109534 E-31 kg
    q_e=1.6021892 E-19 C
    q_e/m_e= (1.6021892/9.109534)* (E-19)*(E 31) C/kg
    q_e/m_e= (1.6021892/9.109534)* (E 31-19) C/kg
    q_e/m_e= (1.758804786 E-1)* (E 12) C/kg
    q_e/m_e= 1.7588048 E 11 C/kg
    If you just use your calculator to operate on the mantissas (multiplications and divisions) and handle the powers of 10 by hand, you will make fewer errors, especially if you are not confident in your mastery of the calculator as regards exponents.
    Anyway, if you could give us a sample of the divisions you are performing, we might be able to help you. Post a comment to this thread and we will take it from there.
    Feb 18, 2010 | Texas Instruments TI-84 Plus Calculator
    Sir, i want to design a flywheel,so what r
    you sure about this?? do you know about heat treatment ,dynamic balance ??centre line boring ---
    Sep 08, 2009 | 1997 Jaguar XJ6
    The tony hawk's downhill game at my ps2
    Enter these cheats at the cheats password option. Note the final 4 cheats cannot be saved.
    Code Effect PointHogger Always Special EvilChimneySweep Demon Skater DisplayCoordinates Display Coordinates IMissManuals Enable Manuals FirstPersonJam First Person Skater OotbaghForever Full Boost IWannaBeTallTall Giganto-Skater NowYouSeeMe Invisible Skater BirdBirdBirdBird Large Birds DownTheRabbitHole Mini Skater TightRopeWalker Perfect Manual LikeTiltingAPlate Perfect Rail IAmBob Perfect Stats FourLights Picasso Skater BirdBirdBirdBirdBird Really Large Birds ChimneySweep Shadow Skater ShrinkThePeople Tiny People RaidTheWoodshed Unlock All Boards & Outfits AdventuresOfKwang Unlock All Events FreeBozzler Unlock All Movies ImInterfacing Unlock All Skaters
    Mar 14, 2009 | Sony PlayStation 2 (PS2) Console
    Tensioner pulley
    This doesn't sound like a problem with your idler pulley to me, more like an axle or wheel bearing? But to check your pully just pull it back with the correct tool, some use a square 3/8 or 1/2 regular socket drive and a breakover works great. some you can just get the correct size boxend wrench on it and pull it back, after you have the tension off the belt remove the belt, spin idler pully and see if it is bad, try and wiggle the arm back and forth with a pry bar. it should have very little play in it. I hope this helps you Isolate your problem and Merry Christmas!
    Oct 24, 2008 | 2001 Buick Century
    Computers & Internet Logo
    113 people viewed this question
    Alun Cox
    David Payne
    David Payne
