Question about Cannon Canon i960 Photo Printer
PIXMA IP4200 won't 'accept' Pigment black--vent blocked?
Things were working fine until I had to replace my larger pigment black Canon ink tank. It seems capable of printing in all the dye based inks but the full pigment black won't seem to budge. Red light keeps flashing. My impression is that removing the tape did not succeed in exposing the tank's L-shaped vent on the top.
I have carefully used a razor blade and removed a tiny bit of tape that still remained...[to no advantage] ...yet my sense is that the tank has a faulty vent that is blocked by the actual plastic of the ink tank. Yet I can see the shape of the thing there. Should I pierce the vent area carefully? If so, how large does the vent need to be? Suggestions? >8^|
hjr.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 92 Answers
If you still have the old tank load it in. an than try the new one again. or tank could be bad.
Posted on Mar 27, 2017
informatica
  • 1114 Answers
SOURCE: canon muti-pass MP360 INK TANK FULL
I believe what you are seeing is "WASTE INK TANK FULL"? This means that the tank that collects the waste ink from cleaning the head is full. You can read more than you ever want to know on this subject on the following link: http://www.fixyourownprinter.com/forums/printer/38697#1 These are the steps to clear the message by reseting the counter: 1)Printer on, press Additional Functions, Scan, Copy, Scan Now you should be in service mode from there for waste ink tank reset 2)Select Test mode which is like the last available selection 3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other options this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button The menu will now say EEPROM Clear Select Ink count which is option (0) and press set Your done!
Posted on Aug 03, 2007
SOURCE: Canon Pixma ip1000 dismantle
Depress power button while plugging the canon pixma ip1000. When you depress the power button, the printer can be used even if the in waste absorber hasn't been replaced.
Posted on Jan 20, 2008
  • 399 Answers
SOURCE: Gentlemen, I bought 3 months ago
insert orignal canon black ink tank it will work .return that ink tank as the chip in that ink tank is not detected by the printer so you are facing this problem.
thanks.
Posted on Sep 15, 2008
nefaj
  • 27 Answers
SOURCE: when (printer modell / year) did epson change vom
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
apppp11
Posted on Sep 04, 2009
SOURCE: I have a Epson 9600 pigment printer,I am using
It probably has to do with the chip embedded in your cartridges. This tells the printer what kind of ink you're using. Your cartridges could have the wrong chip.
Posted on Nov 18, 2009
I have a Canon pixma mp990 Recently it has stopped printing with the larger black ink cartridge that is meant for printing text (PGI-220BK) All the other cartridges print fine I was using a non-canon...
It looks to me that your non Canon cartridge has blocked the print head. I see this all the time. Remember the compatables are not pigment based but just watered down ink so you can get it to flow through a syringe into the cartridge. This however is the classic outcome of trying to save a few pennies on an expensive bit of kit!
Jul 30, 2011 | Canon Office Equipment & Supplies
My canon iP4500 will not use black ink on photopaper. If I tell it the paper is plain then it prints fine. If I tell it the paper is any type of photopaper the colours are great but there is no black ink...
If you set Plain paper with Greyscale printing, only the black Pigment tank is used.
If you set any other paper type, only the 4 Dye tanks are used - even if set to Greyscale.
Dec 09, 2010 | Canon Pixma iP4500 InkJet Printer
I haven't used my canon pixma for a few weeks, came to use it again and the 3e black cartridge won't work, (tried printing from computer and copying) have done a clean, deep clean and nozzle check, even...
The black print head is clogged. The reason why the black is clogged and not the photo black or any colors is that the black is pigment ink and the photo black and colors are dye based ink. The pigment ink is a particulate formulation that binds up when water is evaporated out of the ink. You need to buy a new print head the fix the problem. You can buy a new print head for $75 from precision roller.com.
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma ip4300 black ink refill. BK and PB
The correct order of install a ink tank (From Left to Right):-
1. CLI-8 Black
2. PGI-5 Black (pigment)
3. CLI-8 Yellow
4. CLI-8 Magenta
5. CLI-8 Cyan
Else you can visit this link and type "correct order of ink tank" in enter your question space.
Good luck...don't forget to rate the solution.
Feb 22, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
What is the purpose of the small black in cartridge
They are both described as black but the larger one is "pigment" black. So the answer is they will not switch over because they are different inks and different sizes.
Jan 10, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Why does canon 860 pixma printer have 2 black ink tanks? only one seems to be used,
The big black tank is pigment based ink used mainly for printing text documents and copies and the smaller black is dye based ink used along with the color inks during photo printing.
Dec 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Is MP210 and MP240 the same? can i use the same cartridge?
no both are different
Here are the list of cartridges u can use
MP210
PG-30 Pigment Black
PG-30 Pigment Black Ink Cartridge
PG-40 BLACK
CL-31 Color FINE Ink Cartridge
CL-41 Color
MP240
PG-210 Black Cartridge
CL-211XL Color Cartridge
CL-211 Color Cartridge
PG-210 XL Black Cartridge
Nov 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Need to replace ink cartridge
http://reviews.cnet.com/multifunction-devices/pixma-mp830-office-all/4505-3181_7-31785803.html
Replacing the five ink tanks (cyan, yellow, magenta, black dye, and black pigment) is a simple task. The top of the printer flips up to reveal the ink tanks and the printheads, and by flipping a lever, you can pull out each tank individually. Being able to replace individual tanks is a boon, as you won't waste colors you use less frequently. Also, you won't need separate photo ink to print photos, which we appreciate. Canon ships the Pixma MP830 with full ink tanks. Replacement color and dye-based black ink tanks cost $14.25 apiece, while the pigment-based black ink tank costs $16.25. Canon estimates the cost per page for both black text and color text to be an inexpensive 2 cents.
May 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ink cartridge running low will it default small cartridge
It won't default to the small one...I emailed Canon support; this is the response I got.
The reason for the two different black ink tanks is for the different types of printing your unit is capable of. They are not intended as backups to each other. The larger black tank is pigment based, and is primarily used for standard black text printing or output. The smaller black ink tank is dye based like the color inks, and is used for photo and graphics output. They are designed to complement each other, allowing the printer to produce the best possible black text output or photo quality as appropriate.
Feb 25, 2009 | Canon PIXMA MP610 InkJet Printer
I have error U071. I have been refilling the
You will need to get a new(er) print cartridge and replace the old one to eliminate the problem.
Feb 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Cannon Canon i960 Photo Printer Logo
Top Cannon Office Equipment & Supplies Experts
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
