Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't get the tv back on the channels properly after watching a m
I just watched a movie on vhs and now I can't get the Tv back on.
    President:
  • 778 Answers
Change the input, look for the button on the remote or on the TV itself. Just changing the channel on the TV after powering down the VCR should also work.
Posted on Sep 08, 2009
  • 448 Answers
Disconnect all the cables from the TV then reconnect them after a few minutes.
Ensure that the power cable from the TV is directly connected to a functional wall outlet.
Try pressing and holding the power button on the TV for 30 seconds then check if the TV is turning ON.
Why can't I see the picture when watching VHS movie?
Check the interconnection cable. Try a new one. Check whether proper source i selected with TV. Check whether both VHS and TV powered ON. Gopakumar Gopalan Google
Aug 09, 2014 | Zenith Televison & Video
We were just watching a vhs movie on our tv/vcr combo unit and the picture went to fuzz however, the sound was still working. any suggestions or are we in need of a new unit.
Some VHS have a tracking button that allows the user to tune to the best signal. Usually that tracking function is used as follows.
While movie is playing on the VHS unit and signal gets fuzzy, press the channel key repeatedly (for example >> to increase the channel number). f after awhile pressing the same channel change button does not find a better picture, you should press the other channel change button (to decrease the channel number <<) to see if the picture improves.
If that does not work, IT DOES NOT MEAN that you tv/vcr combo unit is defective. It could just be the movie. The tape is magnetic and it might have been accidentally demagnetized.
If picture is better with another movie/tape, your unit is definitely OK.
Jun 23, 2010 | Memorex MVT2135 13 in. TV/VCR Combo
Connecting digital converter,Emerson VCR/DVD Combo,Sony SDTV
I think you may need an RF Modulator. This device will have connections for the DVD and TV and will have a channel 3/4 switch. Good luck to you.
May 15, 2009 | Emerson EWR20V4 DVD Recorder/VCR
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Connections
Without the manual !!
1)VCR INPUT:: [Cable_antenna In] the coxial screws on from "output" of cable box or ( airwave )antenna.
2) VCR output:: connect another coxial into input of TV. You should be able to keep all the other wires connected from SONY theater system.
note:: your VCR has a switch for VCR\TV. When u have a VHS tape playing a movie & switch from VCR to TV, you will see the channel that is on the VCR not the cable box\ antenna input.
example:Cable channel is on Ch.122, & your TV must be set to Ch.3 to view cable.If your VCR is set to Ch/5 you may not see that Ch.122.You will still be able to see your VHS tape when u place the VCR\TV switch back to VCR.
I am going to share wt.u a $100,000,000.00 trick:put any ch.on cable box.Switch VCR\TV to TV,change channel ON VHS tuner.When u come to the [picture] that the cable box is on,Then that is the Ch.u can see cable ON the VHS.
U owe me!!
Jun 08, 2008 | LG 42LC2D 42 in. LCD HDTV
RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 23, 2007 | Rio Go Video DDV9475 Dual Deck VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
