Question about Samsung LN-S4095D 40 in. LCD HDTV
Our 40 inch Samsung 1080 TV has white lines running across the bottom of the set. This started with the TV set at 1080. The cable guy suggested setting the TV to 780 which worked for a while. Then, we had to set it to 480 and the problem continues. The cable guy says that it's the TV problem
  • 92 Answers
I think the Cable Guy is correct.
Posted on Sep 08, 2009
Why wont my samsung dvd-vr357 play blu ray disks
Educated guess is you need a blu ray player. I have several very expensive Pioneer Elite DVD players and they cannot play blu ray. Blu ray is a multi level glorified DVD which you need at least a blu ray player to play in almost all cases.
You can play dvds on a blue ray but not the reverse in most cases. If you play a dvd on a blu ray player it kicks the video up to HD for the DVD.
Apr 14, 2014 | Televison & Video
My tv has white lines that run up and down across whole screen. it has like 4 lines then a inch space then 4 lines and a 3 inch space My tv is a SAMSUNG HL R5667W
Power supply board, Look for bad capacitors they will be vented or puffed up on Top.
Encompass parts has whatever you need for this model
1-800-638-3328
Mar 02, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
Horizontal Lines scrolling on screen
I had a similar issue with my Mitsubishi HD 1080. My power supply went out, I had it replaced and it works like new. However, just today I had AT&T U-Verse installed. When the cable guy was showing me the new HD channels all seemed good. This evening (about 5 hours after being installed) I started seeing these horizontal lines across my screen. The picture was still HD quality, but those annoying lines just wouldn't go away. Anyway, after reading a few blogs on-line suggesting interference or bad grounding, it hit me!!! The AT&T guy who installed my U-Verse (cable, internet and phone) had set the modem on top of my TV!!! It was just starring at me this whole time. So I removed the modem off the top of my TV and put it on a side table just to see what would happen and sure enough the lines were gone!!! You may not have the exact same problem, but it may be some type of interference (cell phone, modem, etc, either on top or around your TV that is causing the issue... Hope this helps. Thanks.
Oct 31, 2008 | Televison & Video
Horizontal scan lines from bottom to top of my HDTV.
Hi There,
I stumbled across this when i was searching for a fix for the same problem, you're top hit on google for "LCD Horiztonal scan lines" :-)
Anyways, i had the exact same issue, didn't turn up any solutions on the web so i started troubleshooting, and i've fixed it!
My signal cable was running for approx 1metre right along side the 240v / 50hz (Scotland) power cable for the screen. When i moved the signal cable away from the power cable, the lines faded a lot.
Now i've routed the two cables seperately, and i have no more issues! Hope this helps you!
-c
Oct 17, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Open Questions:
See all Samsung LN-S4095D 40 in. LCD HDTV Questions
Samsung LN-S4095D 40 in. LCD HDTV Logo
283 people viewed this question
Jerry Greenberg
Jerry Greenberg
