Question about Dewalt Saws
Noise inside of the motor - Dewalt Saws
  • 305 Answers
Definatley sounds like the carbon brushes are wearing out
Posted on Sep 09, 2009
My whirlpool side by side fridge/freezer is making a loud noise while running.
If the noise is coming from inside, the evaporator fan motor (the fan motor that circulates cool air located in the freezer section) may be the culprit. If noise is on the outside, the condenser fan motor may be the problem. This is the fan motor that removes the heat from the refrigerator to the room.
Jun 14, 2015 | Whirlpool Refrigerators
Tip
My refrigerator makes a lond noise when it shuts off.
The noise that you are hearing is in the compressor. The motor has rubber mounts that hold the motor inside the compressor. One of these mounts are broke and what you are hearing is the motor hitting against the inside of the compressor. If the unit is cooling just leave it alone if it bothers you change the compressor. please rate my tip.
on Feb 28, 2011 | Refrigerators
Inducer motor noise
Replace the motor.
Jun 29, 2017 | Water Heaters
Honda pilot 2007 blower fan making noise blower fan was replaced once still making noise
Either its developed the same fault or the fan motor bearing has failed, needs greasing or, if there's a belt, the belt is slipping.
Feb 22, 2012 | 2008 Honda Pilot
I have 2000 silverado and the motor start making noise like something is breaking inside the motor, The motor is done? or any idea thanks
I hate to say it sounds like a rod, but.......... If its low in the motor, it may be broken flex plate or spun harmonic balancer. Top of motor, its probably rocker arm noise(valvetrain wear?) If its inside motor, only gonna get worse.
Feb 01, 2011 | 2000 Chevrolet Silverado 1500
U-line 75 WC makes a screeching noise on and off during the day. What can I do to make it stop?
You may have one or two fans on the unit. One normally next to the compressor and one in the evaporator With the unit running listen if the noise is comming from inside or outside. Outside is easy, spray Q20 onto the motor and run untill you are able to buy a new one and replace. If inside, defrost a few hours then remove inside panel and locate the evaporator motor. Spray motor shaft liberally then motor will quieten down. Replace when possible.
Sep 15, 2010 | Refrigerators
MOTOR NOISE and noise stopped after closing the fridge door
Hello
Is the noise on the inside or the outside? Most often noise is caused by one of the fan motors going bad.That being said. If the noise is on the inside it's the evaporator fan motor. If it's on the outside in the back then it's the condenser fan motor.
I hope this helps you. Please leave feedback.
Thank you.
Aug 24, 2010 | Refrigerators
Noisy Aga fridge
where is the noise? inside or outside? inside maybe the evaporator fan motor. hitting somethig> wire . get a tech to double check not dangerous. outside. noise compressor dont replace. have to live like that or replace the whole fridge. or condenser fan motor. call atech for replaced
Mar 30, 2010 | Refrigerators
I have Xerox XD100. Machine is very noise. The noise is coming from back of machine. Sand like motor is turning but something is stock (can not moveThis motor look like suppose to move)
There is a small helix gear attached to the shaft of the main drive motor. It cracks or shreads on the inside. You will have to replace the main motor. Not real expensive or difficult to replace.
May 28, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Saws Logo
145 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
