SOURCE: whirl pool dryer
L1 Hot= Left terminal (Red Wire) ...... L2 Hot= Right side terminal (Black Wire) .......... Netural = Center terminal (White Wire) .................. Ground is Green connect to the cabniet of the unit and remove the connection strap from the center terminal on thje dryer wiring block..
SOURCE: Whirl Pool Dryer Model # LGR7646DQO
If your dryer doesn't heat, check these:
Power from the house
Check
to see whether there's power getting to the dryer. Is it plugged in?
Check for blown fuses or tripped circuit breakers--your dryer uses two
fuses or circuit breakers. The dryer could tumble but not heat if only
one of the two fuses is blown. If you have circuit breakers, one of the
two circuit breakers can trip, even if the two for the dryer are
connected.
Heating element
Often
a dryer heating element burns out, but doesn't trip the circuit breaker
or blow a fuse. The heating element is simply a long coil of special
wire. You can check it for continuity with an ohm meter. No continuity
means the element is bad and you need to replace it--electric heating
elements aren't repairable.
Thermal fuse
On
many dryers, there's a thermal fuse mounted to the exhaust duct inside
the back cover panel. The fuse--which is about an inch long--is usually
embedded in black resin and mounted in a white plastic housing. If the
fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A
common problem is for the main wiring connection from the house, at the
dryer, to burn and break its connection. Because the dryer can still
tumble with partial power, the connection may be only partially
defective. You may need to replace both the power cord to the dryer and
the terminal block inside the dryer that the wire is attached to.
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: Maytag Bravos Steam dryer that reads service error code F1
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: My bravo steam dryer is
this is a control board issue, you may be able to clear the fault using these steps:
1) Unplug or turn the circuit breaker off for 30 seconds.
2) Plug the dryer back in or turn the breaker back on.
3) Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
4) Start a short cycle to check the operation of the machine by
machine starts.
If it will not clear then you will need to replace the control board, Good Luck Tim
SOURCE: need to find schematic for
Hello. W/D here.
Here's something better; exploded diagrams, parts lists, and manuals. Enjoy.
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dryer-Parts/Model-LER7620LW0/1198/0151200?searchedModel=LER7620LWo&blt=11
Best regards, --W/D--
