Question about HP Officejet 6310 All-In-One InkJet Printer
I had my printer working fine, then moved, plugged everything in the exact same way and now it is not working?
  • leogupta May 11, 2010
    what is the exact error message? Please explain???
I have an HP Laserjet P2035N that worked just fine until I moved it from home to my office. When I hooked it up to my laptop, which it has been before, it said the printer was offline. I've tried...
network printer is connected to check network connection. (cable, plug, etc.), if everything is ok not a problem to the network printer port on ferl can happen and if it is installed USB port, possibly connected to a another USB port
May 25, 2011 | HP P2035N LaserJet Monochrome Printer
My printer was working fine until I moved. Once I
check the rating is correct. if the plug has a fuse check that. try a different wall socket
May 09, 2010 | Office Equipment & Supplies
Error light stays on
Clear the Error Log: a. Turn the printer off. b. Open the front cover. c. Hold down both buttons while powering on. d. Release the buttons when the error light stays on solid. e. Close the front cover.
Mar 20, 2009 | Dell 1700n Laser Printer
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Beeping noise
I've had the Dell 1720dn at my desk for years. Worked flawlessly. Moved it to a different workstation and it began beeping immediately while printing. Another site said to plug it directly into the wall, instead of a battery backup. I unplugged it from the battery backup outlet, and plugged into a surge protector only outlet on the same battery backup unit.... NO MORE BEEPING. Hope this helps someone else.
Apr 01, 2008 | Dell 1720dn Laser Printer
Paper keeps jaming
I have the same exact problem -
Dec 03, 2007 | Canon PIXMA MP160 All-In-One InkJet...
No power, power supply & motherboard green light blinking
I had the same exact problem for the same exact reason. Plug the power cable into the back. Open up the side of the case and unplug all the wires that the power supply plugs into. The motherboard, harddrive, cd & dvd drives, everything. wait about 10 minutes and plug them back in, plugging the BIG cable that connects to the motherboard back in LAST. This will make the light go from blinking to solid. I think it is a safety? to protect the motherboard from damage.
Nov 01, 2007 | Sony VAIO VGC-RB42G PC Desktop
Devise won't work at all
I had the same problem but found the solution. Follow exactly: (1)With the power on unplug the printer (2)Open up the printer pull the ink carrier to the middle.Then raise the gray bar from the cartridges and remove the printer head (3) Lower the gray bar, with the head out, and close the printer (4) Restore the power, wait til the printer wakes up (5) The printer should then tell you to put in the cartridges (6) Restore the print head and everything should be fine.
Apr 30, 2007 | Canon PIXMA MP130 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
