Question about Whirlpool LSR5132PQ Top Load Washer
Will not aggitate or spin - Whirlpool LSR5132PQ Top Load Washer
  • cmttmh2007 Sep 08, 2009
    we had a repair man hear a few weeks ago and he bypassed the lid safety switch and it did spin after that but i had to sometimes start the drum to spin by hand. I will check for material jamming pump now though
  • ingrams May 11, 2010
    most likely motor coupler ,if you hear whirling noise.could be sock or other small piece of material jamming pump (easy fix generally)
  • 4 Answers
Check the belts. They should be in the bottom of the unit.
Posted on Sep 08, 2009
Why agitator not trning in kenmore washing machine?
If the spin cycle works, but the unit only fails to aggitate......the problem is most likely a clutch or transmission problem. If the unit neither spins or aggitates, you could have a broken belt or even a defective lid switch. Sometimes a model will have broken dogs, or cogs in the aggitator base. To check this, with the machine off..reach into the machine tub..grab the aggitaror and try to turn it manually by hand. If you can turn it and also feel a sensation such as a gear slipping or teeth not properly taking hold or meshing, the cogs or dogs may need to be replaced that are under the aggitator itself. Best Wishes
Sep 01, 2014 | Washing Machines
Aggitator does not spin
You will need to replace the top portion. Here is the part to order.
Nov 18, 2012 | Maytag Performa PAV2200
Kenmore top loader washer aggitates but does not spin out the water it drains but no spining any ideas?
The spinning coil might be not received power supply properly please check it then check spinning coil if it faulty means kindly change the motor
May 18, 2010 | Washing Machines
Will not aggitate or spin,
lid switch remove back panel switch on rt rear corner could have microswitch or fuse depends on mdl #
Feb 04, 2010 | Maytag Washing Machines
My washer won't spin or aggitate. I have a GE
Check the belt and clutch in the front under the lid run a butter knife under the lid and pop the front off and take a look.Have a great Thanksgiving.
Nov 25, 2009 | General Electric WHDSR209DWW Top Load...
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Washing machine will spin on the spin cycle
aggitator? Does it sound like it is? I would put a flat head in the door switch in activiate the cycle "as if it is running" put some weight on the aggitator, see if you can feel it moving while your weight is on it.
Nov 23, 2008 | Maytag Ensignia MAV2757AWW Top Load Washer
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
