Question about ViewSonic Computers & Internet
My viewsonic va902b screen went out. the power indicator light is flashing. What went wrong?
5 Suggested Answers
  • 11 Answers
SOURCE: viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Posted on Dec 06, 2007
  • 1684 Answers
SOURCE: Hi have a Viewsonic 22 VX2245wm. When it was
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 03, 2010
budmrtn
  • 11361 Answers
SOURCE: When I turn on my ViewSonic VA902b it flashes the
The problem can be in the backlight inverter circuits, look fo bad caps with bulging tops, look to see if you do have 12vdc feeding the inverter circuits. See some examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 07, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a viewsonic va902b screen when I turn it on
More likely to have bad caps in the power supply, that is the first place to check for bad caps with bulging top, it can also be bad inverter circuits, or bad lamps, open it up and post back what you see so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 23, 2010
VA902b monitor will flash on for half a second and then go black even though the light shows green. Didn't have any problems with the monitor until updates were automatically installed for windows....
The "sleep mode" is probably set too low.. or a "power saving" mode is set too cut off too quick..(sorry for the low information) .. I am at work on an Apple.. geeezzzz :(
Jun 06, 2017 | ViewSonic VA902B 19" LCD Monitor
VA902b Viewsonic monitor just went black this morning while working. Tried updating driver. Reboot. Does display during startup and goes black again. Monitor problem or hardware? I have 2 monitors.
The best thing to do to isolate the problem is to connect the problem monitor into a known working CPU. If the same problem occur, then the problem is the monitor. You may need to check if the power light (LED) is blinking or no light at all.
If there's no light, you may start replacing the power cable if the cable is detachable. But if it's built-in to the monitor, then send it to the authorized repair shop. They need to check if the panel is shot.
Thank you and good luck!
Nov 01, 2010 | ViewSonic VA902b 19" Monitor
My Viewsonic VA902b monitor screen turns black anddoesnotrespone
That is a problem of inbuilt display card it does not support to games. You have to open the system case and install AGP card in the AGP slot AGP card is available in any shop of computer your other problems will also solve
Mar 09, 2010 | ViewSonic VA902b 19" Monitor
I have a viewsonic va902b screen when I turn it on the picture flashes and wont stay on the screen, how do I fix it?
Feb 23, 2010 | ViewSonic VA902b 19" Monitor
Jan 06, 2010 | ViewSonic VA902b 19" Monitor
I have a ViewSonic VA902b that will flash a good screen if I turn if off and on but otherwise just black. I traded it out with the monitor from another computer and it does the same thing on the other...
Hi.
To start test the problem on a different main outlet, if the socket or the network in the house is not well earthed you may get this problem.
The problem is given by an internal faulty component, probably a faulty capacitor.
When you unplug and plug back, the electrostatic charges in internal circuit will get drained, and this will compensate the fault.
The monitor must be tested at component level to find the fault.
Dec 09, 2009 | ViewSonic VA902b 19" Monitor
ViewSonic Monitor Flickers
Check your MAC's standby, power and screen saver settings
Nov 13, 2008 | ViewSonic VA902b 19" Monitor
Picture problem
Having the same problem, storm the night before? Mabye lighting
Jan 09, 2008 | ViewSonic VA902b 19" Monitor
Computers & Internet Logo
124 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
