Question about Estate TT18TKXKQ Top Freezer Refrigerator
DRAINS OUT WATER ALOT - Estate TT18TKXKQ Top Freezer Refrigerator
  • 22 Answers
Generally means defrost drain is clogged. take out back panel and bottom tray in freezer check to see if there is ice build up ,if so drain is clogged remove ice and run hot water over drain hole carefully run a clothes hanger into hole until water runs through.
Posted on Sep 08, 2009
2002 malibu 3.1 leaks alot of water next to
If it is clear water, yes.
The ac pulls moisture out of the cabin air and drains it to the ground.
Sep 05, 2014 | Cars & Trucks
Tip
Fix leaking faucets yourself
always rember , anyone having problem with leaking water faucets,for example a bathroom sink faucet is leaking,you don't have to go and buy a new one.save youself some money,buy putting new washers in,and if that don't stop it you will need to change the set that the washer seat agains't.<br /> the way to do this first,you would need a screw driver and take off<br /> off the knobs off the faucets,then you will see the washer you would <br /> replace ,but the water has leaked so long you would need to change the<br /> copper set to do this you need a wrench that you can remove the copper<br /> seat then reassemble the faucet and to make this fix last.<br /> always rember don't tighting the knob just enough to stop the water<br /> from leaking and the washer will last alot longer.doing this yourself<br /> you have saved alot of money.
on Mar 09, 2011 | Plumbing
I have to replace my well pressure switch alot
Replace with a heavier duty switch. Make sure expantion air tank has air and nt water in it. If water logged drain and repressurize it.
Feb 10, 2014 | Plumbing
I have a 3 yr old Simpson Eziset 550 Washing machine top loader and it is getting stuck after the first wash cycle. It washes and drains but doesnt switch over to the rinse and spin cycle. Can anyone help...
Hi just read your posting.After the 1st wash cycle the machine drains the water,Is the machine continuous draining?Or does the machine stop the draining and sit there silently?Please reply with additional information and I am sure I can help you.I have worked on this machine alot so if you reply back we can rectify the problem.Looking forward to your reply.
May 14, 2011 | Washing Machines
Bought an antique bronze shower with single handle control, it works fine. The problem is the drain is now covered with a white scale that keeps forming.
The protective finish has worn off of the brass drain assembly and there is alot of chemicals in your water. Only thing to suggest is a water softner for your home.
Sep 02, 2010 | Pegasus Technologies Plumbing
Model lat9306aae drains water but will not spin
I would check the lid switch as alot of times washing machines will fill and drain just fine with the lid open but the motor will not engadge to agitat or spin unless the lid switch is made or down.
Jan 16, 2010 | Washing Machines
Freezer leaks into the refrigerator every couple of days
YOUR DRAIN IS PLUGGED. DEPENDING ON THE MODEL ALOT OF THEM HAD A DRAIN CUP IN THE BACK TOP OF THE FRESH FOOD SECTION. YOU COULD REMOVE IT TO CLEAN LOOK FOR A OPENING FROM THE FREEZER FLOOR TO THE FRESH FOOD TOP THAT IS WHERE YOUR DRAIN CUP SHOULD BE ALLWAYS UNPLUG IT FIRST
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 12, 2010 | Refrigerators
Dishwasher water keeps backing up into kitchen sink then taking a long time to drain from sink
Yes, your sink drain needs cleaning -- it's clogged. Pour some bleach into the sink drains and let it sit for a couple of hours. Flush out with boiling hot water.
If this improves the situation but not completely solving the drain problem, try it again.
If that doesn't solve the problem, remove the P-traps on the sink drains under the sink and clean them out.
If that doesn't work, let me know -- we'll try something else.
May 05, 2009 | Dishwashers
Water in bottom of dishwasher, can't get it to drain
pull your water drain line out and place in a bucket on the floor. then try to drain it again. alot of time the hose get an air gap or blocked with gunk.
Feb 16, 2009 | General Electric Adora GHDA670N Built-in...
Whirlpool duet ht washer leaks
MY ROPER WASHER LEAKS ALOT OF WATER OUT OF THE SIDE OF IT WHEN WHEN IT DRAINS. HOW DO I FIX IT?
May 21, 2008 | Whirlpool Washing Machines
Estate TT18TKXKQ Top Freezer Refrigerator Logo
71 people viewed this question
Top Estate Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
