My screen is shaking every second or two second! Even though I restart it, my problem persist on and was not solved.
    President:
  • 2,600 Answers
You either have a graphics card going south or a corrupt driver or an incompatible resolution setting.
Posted on Sep 08, 2009
A minute or 2 after starting the machine and on any setting the machine starts to stutter, lights flashing and making a fast rhythmic noise
It sounds as though power is only struggling through to the motor intermittently.
Ignoring the possibilities of loose or bad connections or expensive circuit boards the motor could need new brushes.
I have had my machine nearly ten years and it is on its fourth set even though it doesn't get used very often.
I suggest you stop persisting with attempting to make it go. If brushes are the problem you could be making things worse so that it could need a new motor rather than some routine periodical maintenance.
I could be completely wrong - sorry if I am.
Feb 04, 2015 | Washing Machines
My lg306g phone's back light goes off after 15 seconds, even though I have it set for 60 seconds.
full factor restore your phone after backing up your phone numbers....this should work......if still problem persists then get your phone flashed.....i.e. get software reloaded
Nov 29, 2014 | Cell Phones
How can i solve error e000001-0000?
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
May 30, 2014 | Canon imageRUNNER 4570 Copier
I have a nikon d3100 , which o bought a month back , of late i didnt experience any probs with it , but unfortunately today mrng , "" WHENEVER I TAKE PICS WITH IT THE IMAGE EXPERIENCES A LITTLE...
For the shake you might want to go to your local camera shop and have it looked at. It could also be that your shutter speed might be very low. For your second question It shouldnt cause a problem as long as your cameras sleep mode is turned on.
Nov 01, 2011 | Nikon D3000 D3100 18-55mm
How can i reset my nokia 6288 even though it is switched off.?? because when i switch it on.. the screen goes to the right and then off again.. i think that there's a problem with its software.
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Second Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Sep 30, 2010 | Nokia 6288 Cellular Phone
Will not print defults to fax even though default is set for printer
Delete both the icons(Fax and Printer icon) and also, if there is any copy if installed.
Insert the Printer driver CD or Run the setup file.
Select Add a Device from the Options that come on the welcome screen.
Select it, follow the onscreen options to complete the installation.
Once it is complete, restart the printer. And then try to print. If the issue still persists, restart the computer and then try to print.
Jun 02, 2010 | HP Officejet 6310 All-In-One InkJet...
My Screen freezes then goes blank
I had already done the things that your expert suggested. This morning I purchased a new web cam but the same problem occurred. I took my computer back to the shop where I had just had a new motherboard, graphics card, processor and RAM put into my computer. They managed to solve the problem as it was the problem with 'frame rates per second' that the graphics card was set at. It was on 60 but should be on 85fps. What he did was Rt Click on desktop, > properties, > settings, > advanced > monitor to change the settings. Now problem is solved.
Apr 12, 2009 | Genius VideoCAM Trek Webcam
Xda
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Apr 15, 2008 | O2 XDA Mini S Smartphone
The screen of my motorola shakes
Dear edmflo,
This sounds as a hardware error. Since this is a flip phone the strain ussually is inflicted at the flex cable connecting the Motherboard to the LCD screen. This is a very fragile piece of equipment (chaep though around 5-15$ at ebay) and breaks easily even after normal usage.
If it is not broken it also simply loose at the connectors. Attaching it again will solve the problem.
At this point I believe that the possibility of an LCD that is defective is less than 5-10%.
Regards.
Feb 04, 2008 | Motorola Mobility MPx220
SyncMaster 712N monitor problem
I've had a similar problem. I took apart the monitor (it was out of warranty by that time anyway) and found the lamps would not stay on. They'd flash for a split second before remaining unlit. I tried hooking up another LCD monitor's lamp to the Samsung, and even though I knew the other lamps worked fine, they exhibited the same behavior. Looks like something's wrong with the circuitry. The LCD actually does display the desktop on screen correctly. It's just the lamps refusing to stay on.
Sep 03, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Computers & Internet Logo
257 people viewed this question
David Payne
David Payne
