Question about Canon PIXMA MP530 All-In-One InkJet Printer
"set ink cartridge" won't go away
This " Set ink cartridges" message comes up on the led screen and stays on. Unable to operate machine. Does not seem to be communicating with my pc either... New cartridges installed...
Please help
  • 38 Answers
Hello. Your ink cartridges need to be set. and if it is not communicating with your computer you need to reload the drivers. ok to reload your drivers, on your computer, click start then right click on computer, then another box will open up. when it does, then left click on properties. then another box will open up. click on device manager. Another box will open up. Look for your printer. You should see it in the list. then what you do is, put the software that came with your printer in your cd/dvd rom drive. then disconnect the cable between the printer and the computer. (NOTE) If you do not have your drivers, then go to www.canon.com, then support, then type in your model number, then go to driver downloads and download your drivers there. If you installed a new operating system on your computer, you will have to download the new compatible drivers for the operating system you have installed. after installing them, then once you locate your printer in that list right click on it. then another box will open up. then click on uninstall. it should uninstall the printer drivers. after that is done, then restart your computer and when your computer restarts, the software for your printer should come up. Then just reinstall the software. after the software is installed, then plug the usb printer cable. your computer should then pop up with a box that says "found new device" It will ask you where to look for the new drivers. if you have the disk that came with the printer, click on that drive that contains the disk with your software. after it installs the new drivers, that should take care of the communication problem. If it does not, then try changing your usb cable. it might be or have gone bad. As far as the message of set ink cartridges, look in the manual on how to set the cartridges. If you do not have the manual, then go to canon support, type in the model number, then download the manual for your printer. That will explain how to set your cartridges. If you set them then you will probably have to realign the heads then you should be all SET. No pun intended. lol Hope this helps. Ron
Posted on Sep 08, 2009
Epson stylus photo rx700 lockout
Look for cartridge sensor and clean them with a piece of close. re-install the cartridge and see if the problem is solved. if not may be U have bad sensor so replace with new ones.
Jun 02, 2012 | Epson Stylus Photo RX700 All-In-One InkJet...
I keep getting error U043 even tho I know that the ink cartridge is missing. However, I only need to use the scanner and am unable to get to the home menu because the error message won't go away. How...
Got a reply from Canon support as below.
During Boot Sequence of the machine, one of the checks performed by the machine is presence of Ink/toner Cartridge and the minimum quantity available in it to start up.
When the machine fails to get the signal of Ink availability, it stops the Initialization Process and an error code is displayed
Since the machine is an ALL-IN-ONE, it cannot perform any of its function, had it been exclusive Scanner the Boot Sequence would have been different.
Jun 18, 2011 | Office Equipment & Supplies
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
LEXMARK X63 NOT RECONIZING LEFT CART.
I did find a procedure online to clear the memory and that did the
trick. Here it is, may help someone in the future:
Open lid, take both cartridges out. Physically remove the power cord from outlet or back of unit. While pressing the Stop/Clear button, plug cord back and kee pressing until a message saying "clearing memory" comes on. Reinstall ink. You're done, the message should go away.
May 03, 2009 | Lexmark X63 InkJet Printer
My HP C6180 All in One printer shows an Ink System Error oxc18a0207. I tried removing the ink cartridges and reinstalling them but the message will not go away. What is solution?
You must have inserted a refill ink cartridges or there is a malfunction in the ink registering led.
Get a new set of inl cartridges from an authorized shop and insert.
This will end all the worries.
But if you have already done this, just ignore the error report it will go off later.
Apr 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Message window reads "unable to clean" and machine will not print period
Press:
Menu/Set, Black, Up arrow 4 times, 80, then press black until "Purge" appears on the screen, then press 2783, stop/exit, 99.
Jul 18, 2008 | Brother MFC-5840CN All-In-One InkJet...
Printing onto clear film for screen printing film positives from R2400
midwest screen and supply will have the printers and the films for screen printing, it's the company i go through and i've had no problems in the past 14 years of ordering from them
Apr 18, 2008 | Epson Office Equipment & Supplies
Cannot get Canon PIXMA MP 150 to work at all
salve la mia mi canon mp 150 lo scanner non funziona e mi da errore code 2,250,0
Apr 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
90 people viewed this question
old marine
old marine
