How do you clean the mould build up off the flexible door seal of a front loading machine. Can I take out the door seal safely to do it. Westinghouse front loading washing machine model LF711C
    Scholar:
  • 44 Answers
Bleach:Water solution 1:2 should kill the mould effectively.
What they should have told you when you bought this machine and what it almost certainly says in the owners manual is that front-loading washing machines, all brands, are prone to this problem. You must wipe the rubber gasket/door seal off when done using. Every time.
Dumb, I know, but necessary.
Posted on Sep 08, 2009
Mold door seal
If you want the door seal replaced any local domestic engineer will be able to do this. The mould is caused by excess detergent, constant washing at low temperatures, keeping the door closed when the machine is not in use. If you want to stop the mould reappearing once the seal has been replaced you need to carry out regular service washes (boil wash with a descaler/sanitiser). Use the correct amount of detergent for the amount of washing to be done and the hardness of the water in your area. Give the door seal a quick wipe after you use it and try and keep the door slighlty ajar when not in use.
Oct 18, 2013 | Siemens WFXD5200UC Front Load Washer
Mould inside rubber seal
Bosch Axxis WFL 2060 Front Load Washer mould on door
gasket.
This video will show you how to change a door seal on this Bosch front loader washing machine.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Black mould
this is the fatal flaw of front load washers, see this complaint over and over, use bleach to clean it or Tilex mold and mildew remover, make sure the hole that drains the seal is clean.
May 13, 2010 | Zanussi ZWF1440 Front Load Washer
We have a Fridgedaire front load clothes washer and we would like to know how to get rid of the mildew on the front seal?
be carefull what chemicals you use on the door seal,get in touch the manufacturer or call the appliance guy that sold it to you
Jan 31, 2010 | Frigidaire Affinity ATF7000E Front Load...
I get lots of mould on the door seal - why? The machine also leaks when its empty or only half full
You won't notice the mold on other machines with black door seals because of the color. If your seal is gray, it is a normal thing. Chances are it really isn't mold, but a build up of crud. However in the off chance it is mold, spray the seal liberally with mildew remover, let sit and repeat until the mold is gone. . As for the leaking (assuming the leak is happening at the door), if it is a drip or two during the cycle, although it is not "normal" for this to happen, front loaders do often drip here and there. If you have more problems than a couple of drips, replace the seal. . Other leaks not at the door should be looked at. There aren't too many places it can really leak. It should be easy to find.
Nov 25, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Hotpoint Washing Machine smells mouldy as has mould
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jul 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Is there a way to clean rubber seal around the opening?
Use a vinagar solution to clean the rubber seal. bleach will damage the rubber.
Apr 29, 2009 | Washing Machines
Mouldy door seal on hotpoint ultima 14 months old
hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
Feb 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Zanussi front load washer door seal
Keeping the door open after your wash would help in keeping the interior dry. Do not push the door shut, just leave slightly open. Only before you begin your wash, check to see your cat is not inside.
Oct 13, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
434 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
