Question about Apple iPod touch
My iTouch will not open my new applications.
They worked at first but now they just open for about .5 seconds and then immediately close.
  • NaplesMC Sep 09, 2009
    This did not work. I have tried everything you said.
  • 4,281 Answers
Press power button for 10 seconds.
then remove battery and memory card and sim .
Then put battey and sim then start it.
Then go to menu and reset all settings to factory defaults.
Then check.
May be your memory card is virus infected so check withoutm memory card.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 09, 2009
  • 309 Answers
Lets try a rest first, a hard reset will only force complete shutdown and hopefully clear out any bad memory addresses. if that fails then we need to restore to factory settings.
what i believe has happened is that you put a program on your itouch and it was not written for your model or it has badly written code.
(reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.)
If That fails
try this last and only after backing up your data fully, contacts Anny photos absolutely anything you put their you want to get back needs to be backed up first, good luck.
plug the itouch into your computer
1. Press and hold the home button and the sleep/wake button
2. When the apple logo appears let go of the sleep/wake button (keep holding the home button.)
3. After a few seconds you should see the connect to iTunes image (you can now let go of the home button.)
4. Open iTunes .
5. iTunes should automatically recognize your iPod once the image comes up, if not unplug your iPod and plug it back in.
Posted on Sep 08, 2009
Why my 1999 toyota 4runner Ltd remote locks but cannot unlock
Is this programming guide doesn't work your remote may be bad or batteries are weak or your body computer could be faulty. The body computer controls the remote.
1. Start with the following conditions: you are in the vehicle
a. Key is out of the ignition
b. Drive door is open ( all other doors are closed)
c. Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times. Use an even pace and try
to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times (same as before).
b. Turn the ignition to ON then back to OFF.
c. Turn the ignition to ON then back to OFF.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically)
indicating successful entry into programming mode. Return to step 1
if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the LOCK and UNLOCK buttons on the transmitter
simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons,
press the lock button by itself and hold for 2 seconds.
Within 3 seconds, the door locks should cycle ( LOCK then
UNLOCK) once-- indicating successful programming. If
the door locks don't cycle, or cycle twice. Repeat steps
6a and 6b--this remote has not been accepted.
c. Repeat steps 6a and 6b for EACH transmitter that will
operate the vehicle. Including any old transmitters.
7. Close the driver door.
Mar 02, 2015 | Toyota 4Runner Base/Sr5/Ltd 1999-2002 F....
Coding spare key for a Toyota Echo?
Adding key.
Note:
You must be having one working master key to perform this function.
1. Start with the key out of the ignition, drivers door is open all others closed and drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
3. Perform these steps within 40 seconds.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
C. Insert the key into ignition and leave it in ignition.
D. Close the drivers door.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock and then unlock once indicating successful programming. If the door locks cycle twice, repeat steps A and B in step 6 as the remote was not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
Jan 09, 2013 | 2001 Toyota Echo
How to fix the 2004 CAMRY remote?
not accepted.
Jul 07, 2012 | Cars & Trucks
Fridg. not cooling. digital display not working, frezzer thawing.
he refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
• If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
• If the relay clicks two times, check for an open bimetal.
Jun 11, 2011 | Whirlpool Refrigerators
Programming key sienna 2006 tk
Here are the instructions per the factory manual.
not accepted.
Feb 05, 2011 | GPS
Key buttons will not operate locking system,i have changed battery but still no good.use master key,gets me into the car but alarm goes off and also when i attempt to drive it.
I have the same problem kinda. Lost my master key and sent my ecu off with a home made 2 button key to program immobiliser. This key works to start the engin and drive but I cannot get the key to program with the alarm and locking system. You can try the following steps as may work for you.
I can get my car into programming mode after step 1 but step 2 does not work for me. The locks do not go off at all, not once or twice. Battery in remote key is fine as LCD lights red.
Can anyone help please?
Toyota celica 2000 - 2005 remote keyless entry programming guide
STEP 1
1. Key out of the ignition. Open the drivers door , all other doors are closed . Driver door is unlocked
a. Insert the key into the ignition ( do not turn it ) take key out
b. Insert the key into the ignition ( do not turn it ) take key out
a. Close and then open the drivers door.
b. Close and then open the drivers door.
c. Insert the key into the ignition ( do not turn it ) and pull it out.
c. Close drivers door.
d. Insert the key into the ignition and leave it in the ignition.
Turn the ignition to on (as far as you can go without turning the engine over ), then back to off .
e. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
STEP 2 (Does not work for me)
a. Press the lock and unlock buttons on the transmitter simultaneously for 2 seconds
b. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
Hope this works for you.
Hayley
Oct 03, 2010 | 2000 Toyota Celica
How to enable by ipod
1.Make sure your charger is plugged in to your computer, but not your iTouch.
2.Shut off your iTouch(if charged wait and then shut down)If you can't shut it down.Hold down Sleep/wake button and Home button for about 10 seconds and it will shut down.
3.Hold the home button for 10 seconds, then plug your charger in while still holding it.
4.Keep holding it until a recovery screen comes up(the same screen when you buy one)
5.Open up iTunes, (should open itself) and then click Restore ipod.
Wait around 20Minutes and it should work.
Then it should be done.
(It deletes all your applications, but still works.)
Mar 29, 2010 | Apple iPod touch
I can download applications but they will not work when I click on them. Do I have to do something in order for them to work? Very frustrated...love the iTouch.
Issue : apps open then close
- deautherize cpu
- reautherize cpu
-delete apps off ipod
-delete apps off cpu
- go to itunes store
- download app
- sync app
- app opens
- issue resolved
Feb 01, 2010 | IBM ITouch In-Reach IR-8020 (24P7481)...
I restored my itouch but itunes still wont recognize it
You may need to reset the driver
and then possibly update your itouch firmware to get it working again....
-Close any other open programs
-Unplug the iTouch and any other NON-ESSENTIAL USB devices from the computer (i.e. PRINTER, CAMERA, etc.)
-Open the iTUNES application and leave it on during this process, you may minimize the program if you'd like though!
-click on your Start Menu
go to Control Panel
click on System icon [computer w a check]
goto the tab that says Hardware
then the Device Manager button (alternatively, u can access the device manager by opening up the RUN command and typing in "CONTROL.EXE SYSTEM" and hit ENTER)
-Under DEVICE MANAGER, click on universal serial bus controlers
to expand the catagory
then you itouch should be in there
it may be under a name like "USB
Mass Storage Device"
then click [up/plus on the toolbar] and choose
the unistall driver option[computer with an X]
(don't worry, your data on the iTouch will be fine!)
-Next plug your itouch back in it should
recognize it
Now then, try to update the firmware through Apple
Jan 03, 2010 | Apple iTunes
Apple iPod touch Logo
23 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
