All of my 4 gas burners do not stop sparking....seems to happen mostly after heavy use of the oven and stovetop (when my dad cooks his famous dinners!). HOW DO WE STOP THIS?! Thank you!
One of the burner switches is shorted, take off plate that covers the switches and remove the wires one at a time on each switch then reattach wire before going on to next switch.continue until sparking stops,replace switch (easy fix)
You have a bad spark switch on one of your burner switches. Remove the control panel to access the switches and burner stems. Carefully remove one wire at a time from each switch. When the sparking stops,that will be the bad switch. Replace the bad spark switch.
The igniter in the oven does not spark. It heats up and glows red hot until enough current opens the safety gas valve to the burner. It is not associated with the stovetop burners. Replace the oven igniter itself.
Make sure yo haven't spilled liquid on the ignitor becuase this will cuase all ignitors to spark constantly. If all is dry, the spark module must be replaced.
Its most likely the igniter. It might just be dirty, but its easy to install a new one. They are attached by two screws and a single plug. I'd suggest turning the power off to the stove before plugging in a new one.
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
for the top burners you have to get to see the ignitors so that you can see the spark,the spark have to spark like a spark plug in the car, it most be on the tip of the ignitor.if not. the spark it's sparking on the wroung spot,wires may be wet or broken. thats one of the reason, the second one,there is small holes fasing the spark ignition on the burners when grease blocks them, they will not light, you can clean them with a paper clip or a safety pin. for the oven,some ovens do not have the spark sistem, they have the ignitor wich it looks like a small bar about 4 inches long by 1 inch some of them are round. thats the part that needs replacing
If you have Propane than any range will have to be properly converted to propane they are made for natural gas. Other than that gas ovens do emit quite a large amount of CO and new homes are built very air tight and any good CO detector may sense this. If you have a vent hood or hood/mwave combo and its vent is actually ran to the exterior it should aid in venting that CO. This is why the new dual fuel (gas cooktop, elec oven) are so popular. Hope this helps...
if you are not hearing the faintest sound of clicking / sparking you could have a bad spark module or even bad burner switches i doubt that all switches went bad at the same time but its possible unplug oven check wireing to switches and spark module if you pull your burner knob off thats the switch starring at you follow wires and check for any loose connections
