Question about Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8 0.05 Gauge Chiesel Chain
I cannot figure out how to increase the oil to my chain on a stihl MS 260 chainsaw
    Sergeant:
  • 302 Answers
This is from my owners manual. Make sure that the oil passages ih the bar are clear and clean. If so, then remove the bar cover, bar and chain and make sure the oil port from the saw to the bar is clean. If so then run the saw and see if oil is being pumped out of the port. If not then you need to remove the pump which is below the port on the bottom of this area by removing 3 screws and carefully removing it. Make sure the tubing that connects to the pump is also good,then carefully dis-assemble the pump and clean it. there is a small spring in there so be careful. There is an oil filter that must be cleaned. wash all parts in gasoline and inspect the diapragms for tears and holes. if all is well it should be re-assembled and put back on. Thsi is all you can do to repair it yourself and the shop guy can't do much more. hope this helps, Now I gotta go fishin". The jumbo's are hitting in Lake Erie today
Posted on Sep 08, 2009
Chain bar oiler adjustment for MS 290 Farm Boss
if there is an adjustment it whould be on the bottom of the saw. usually a flat blade screwdriver to adj it.
Aug 29, 2016 | Stihl Garden
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
How to replace oil pump in stihl 031 chainsaw ?
Remove the worm, sealing ring and washer, loosen the pan head screws on the oil pump and replace. Check if the gasket is re-usable.
Jun 11, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
My stihl ms 390 not oiling chain
flow screw on bottom of chainsaw, increase flow. Vacuum hose could have leak. Filter in oil tank could be plugged(I would check this first).
Jan 30, 2014 | Garden
Hard pull stihl ms 250
UH OH.......may be engine damage, from over heating or not enough oil in gas.
Dec 22, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Chaisaw oiler on ms390 stihl is not working
Take bar and chain off and ensure oil feed is not plugged also use only stihl bars
Feb 11, 2013 | Stihl Hand Guard Chainsaw Ms 290, Ms 310,...
Chain oil leaking on 025 stihl chainsaw
Their is a oil passage that has a plastic plug in it by the muffler. It might be gone like mine is.
Nov 29, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
May 09, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8  0.05 Gauge Chiesel Chain Logo
228 people viewed this question
Top Standard Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Standard Measuring Tool and Sensor Expert? Answer questions, earn points and help others
