Question about HP Officejet 4315 All-in-One Printer
When faxing it will dial number and pages will go through but then it says paper jam and I can not find any paper in it
  • 4 more comments
  • pbpilotcars Sep 08, 2009
    i cleaned the sensors with alcohol but it still says the original jam.
    i cleaned it with alcohol and it still has the same problem
    i cleaned it with alcohol but this didn't help the problem
    i cleaned it with alcohol like the expert said but the problem still exists. when faxing it will dial and the pages go through but then a message that the original jam
    i have checked everything you listed and it still has the same problem
    this did not help
Cause This error can occur for several reasons. Some factors that might contribute to the problem:
  • The paper in the input tray is not correctly aligned
  • Using torn or wrinkled paper
  • Using paper that has previously been printed on
  • The rear access door is not fully seated or locked into place
  • The paper feed rollers have accumulated dust or paper particles
  • An envelope is being printed and the flap is not tucked down
Click on the link to learn more:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00621882&tmp_track_link=ot_faqs/top_issues/en_us/c00621882/loc:2&lc=en&dlc=en&cc=us&product=1138342
Posted on Sep 08, 2009
  • Anonymous Sep 08, 2009
    Check how much paper is on the tray. If you are experiencing frequent paper jams, make sure that you are not exceeding the maximum tray capacity. According to the HP user guide, the HP Officejet 4315 can only handle 10 mm of paper in the paper tray.
  • Step 2
    Remove any paper jams if you are experiencing an error message on the display on the front of the printer. To do this, lift up the automatic document feeder located on the front of the printer. Then, gently pull the paper from the rollers.
  • Step 3
    Update the HP software if the HP product assistant continually displays on your computer screen. This will usually happen each hour if this occurs. See the Resources section below for a link to the updated drivers. Download and install the drivers.
  • Step 4
    Verify that the phone cables are properly inserted into the wall jack and the back of the printer if you are receiving a "Phone off the hook" error message.
  • Step 5
    Perform a partial reset if you are experiencing problems scanning or printing your document. To do this, disconnect the power cord from the wall. Then, hold the "#" and "3" while reconnecting the power cord. Release the buttons once the cord is plugged in. Try to rescan or reprint your document.
  • Step 6
    Perform a semi-full reset if the partial reset did not work. To do this, unplug the power cord. Hold "#" and "6" buttons while plugging the cord back in. Then, release the buttons and try to rescan or reprint your document
    Try cleaning it with rubbing alcohol
      President:
    • 2,600 Answers
    This is a very common problem for most HP units. There are sensor pads before and after the feed rollers that sense the movement of the paper and are on lookout for tension that stays on a feed sensor. What happens over time is these feed sensors get dirty and caked with a sticky paper residue along with the rollers. All this causes the device to think it has a jamb when it doesn't feed something through smoothly enough. The device needs a good cleaning, this can be done with alcohol or a suitable cleaner along with using compressed air from a can. Good luck with it.
    4 Suggested Answers
    SOURCE: Fax Jam
    hp tells me to do the following
    does this help you ?
    Issue While printing, copying, or receiving a fax, a paper jam occurs. If the jammed paper is removed incorrectly, other problems may occur. Clearing paper jams Remove the jammed paper by following the steps below: WARNING: Jammed paper must be removed using the rear access door to avoid mechanical damage. Do not remove jammed paper from the front of the all-in-one.
    1. Turn off the HP product and turn it so the back of the all-in-one faces you.
    2. Disconnect the power cord from the back of the all-in-one. CAUTION: The power cord must be disconnected to allow the paper feed rollers to turn freely and avoid mechanical damage.
    3. Locate and open the rear access door by pressing in on the left side tab to release the catches and then pulling the door toward you. Figure 1: Removing the rear access door c00100775.jpg
    4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
    5. From the rear access door opening, remove the jammed paper.
    6. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
    7. Reinstall the rear access door.
    8. Reconnect the power cord and turn on the all-in-one.
    Preventing paper jams The following information will help prevent paper jams from occurring:
    • Never use paper that is wrinkled or damaged in any way.
    • If you are having problems using paper that has already been printed on once (recycling), replace it with fresh paper.
    • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door isn't locked.
    • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
    • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
    richard from chicago
    Posted on Apr 07, 2008
    SOURCE: paper feed jams
    I had this problem and suddenly noticed that I had not pushed the paper tray totally in. It looked like it was in but it wasn't. Fixed the problem completely for me.
    Posted on Sep 02, 2008
    • 4 Answers
    SOURCE: I am having trouble with faxing information to another fax.
    I have had this problem before. Either your fax is not hooked up properly or whoever you are trying to send the fax to does not have their fax hooked up properly. If it's not one of these problems makes you have the right fax number and that you are putting the fax number in correct. Some fax require the whole number to be entered 1 including the area code.
    Posted on Nov 11, 2008
    Cant install fax software for lexmark x5495 aio printer.
    1. Unplug the printer from the PC
    2. Uninstall all the software related to the All-in -One ( that is on the PC)
    3. Connect the All-in-One again then follow the software instructions for reinstalling the printer.
    From the instruction manual:
    Sending a fax
    Entering a fax number
    1 From the control panel, press Fax Mode.
    2 Enter a fax number using:
    The text box Enter a fax number using the keypad.
    Notes:
    • You can include a calling card number as part of the fax number.
    • Enter a maximum of 64 digits in a fax number.
    • Press Pause / Redial to insert a three-second pause in a number you
    are entering to wait for an outside line or get through an automated
    answering system.
    Speed Dial or Group Dial a Press Phone Book.
    b Enter Speed Dial and/or Group Dial numbers.
    • Press or repeatedly until the Speed Dial or Group Dial
    number you want appears.
    • Use the keypad to enter the number of the Speed Dial entry (1–
    89) or Group Dial entry (90–99).
    Notes:
    • For instructions on how to add Speed Dial or Group Dial numbers
    using the computer, see “Setting up Speed Dial” on page 118.
    using the control panel, see “Using the Phone Book” on
    page 108.
    3 If you want to send a fax to a group of numbers (broadcast fax):
    a Press .
    b Repeat step 2, using any combination of the previous methods, until a maximum of 30 fax numbers have
    been entered.
    Sending a fax using the software
    You can scan a document to the computer and then fax it to someone using the software.
    1 Load an original document facedown in the Automatic Document Feeder (ADF).
    2 From the desktop, double-click the Productivity Studio icon.
    3 From the right pane of the Welcome Screen, click Fax.
    4 Select the Document option.
    5 Click Start.
    6 Enter the recipient information, and then click Next.
    Note: A fax number can include up to 64 numbers, commas, periods, spaces, and/or these symbols: * # + - ( ).
    Faxing
    103
    7 Enter the cover page information, and then click Next.
    8 If there are any additional documents that you want to send with your fax, add these now, and then click Next.
    9 To send your fax:
    • Immediately—Select the Send now option.
    • At a scheduled time:
    a Select the Delay sending until option.
    b Set a time and date.
    10 If you want a paper copy of your fax, select Print a copy of your fax.
    11 Click Send.
    Sending a fax using the control panel
    1 Make sure the printer is on.
    2 Load an original document facedown into the ADF or on the scanner glass.
    Note: Do not load postcards, photos, small items, transparencies, photo paper, or thin media (such as magazine
    clippings) into the ADF. Place these items on the scanner glass.
    3 From the control panel, press Fax Mode.
    4 Enter a fax number or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
    information, see “Entering a fax number” on page 103.
    Note: To set up Speed Dial, see “Setting up Speed Dial” on page 118.
    5 If you want to send a fax to a group of numbers (broadcast fax):
    a Press .
    b Repeat step 4 and press until a maximum of 30 fax numbers have been entered.
    6 Press Start Color or Start Black.
    Sending a fax while listening to a call (On Hook Dial)
    The manual dialing feature lets you dial a telephone number while listening to the call through a speaker on the
    printer. It is useful when you must navigate an automated answering system or enter a calling card number before
    sending your fax.
    2 Press .
    3 Press or repeatedly until On Hook Dial appears, and then press . You can now hear the dial tone of
    the telephone line.
    4 Enter a fax number. For more information, see the related topic, “Entering a fax number.”
    Note: Press the keypad numbers to use an automated answering system.
    5 Press Start Color or Start Black.
    Faxing
    104
    Sending a broadcast fax at a scheduled time
    You can send a fax to a combination of up to 30 people or groups at a time you choose.
    1 Load an original document facedown into the ADF or on the scanner glass.
    2 From the control panel, press Fax Mode.
    3 Press .
    4 Press or repeatedly until Delay Fax appears.
    5 Press .
    6 Press or repeatedly until Delay Until appears.
    7 Press .
    8 Enter the time you want to send the fax.
    9 Press .
    10 If the printer is not set to the 24 hour mode, press or repeatedly to select AM or PM.
    11 Press to save your settings.
    12 Enter a fax number, or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
    13 If needed, repeat step 12 and press until a maximum of 30 fax numbers have been entered.
    14 Press Start Color or Start Black.
    Note: At the designated time, the fax numbers are dialed and the fax is sent to all of the designated fax numbers. If
    the fax transmission is unsuccessful to any of the numbers on the broadcast list, the unsuccessful numbers will be
    dialed again.
    Receiving a fax
    Receiving a fax manually
    1 Make sure the Auto Answer light is off.
    2 To receive the fax if you have not set up a manual answer code:
    • Press Start Color or Start Black.
    or
    • Press * 9 * on the telephone after you answer it and hear fax tones.
    3 To receive a fax if you have set up a manual answer code, enter the code on the telephone after you answer it
    and hear fax tones.
    Note: For information on how to set up a manual answer code, see the related topic, “Setting a fax manual answer
    code.”
    4 Hang up the telephone. The printer receives the fax.
    Faxing
    105
    Apr 15, 2010 | Lexmark X5495 All-in-One &USB...
    I have a problem with panasonic kx ft938 showing "fax memory full". How can i clear it?
    The memory is full of received documents due to a lack of paper, or a paper jam.
    Install paper or clear the jammed paper.
    or, unplug the unit for about 5 minutes.
    or, to clear the RAM, try one of these procedures:
    (If the first one doesn't work, try the next one)
    1.
    Press menu 7 dial dial dial dial * 6 start
    Press up-arrow key until the display reads shipment set then press start
    The display will read reset counter
    Select yes or no then press start
    2.
    Press # 7 dial dial dial dial * 6 enter
    3.
    Press standby set dial dial dial dial * 6 start 9 9
    On success, a long beep will be heard
    4.
    Press menu 7 monitor monitor monitor monitor * 6 start
    Parameter 65 for memory collation should be set to invalid to maximize the memory page rating
    Nov 27, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
    Saying paper jammed ..but no paper is jammed????
    The course of the problem could well be when you pulled the paper the wrong way out ot clear the jam. Open the machine and have a close look at the unerside of the flap. There should be a micro switch, which could well be desloged.
    George
    Jun 01, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
    I have a lexmark x4270. Having problem sending fax. Sending local number, it's OK, but sending a different area code, it uses the local area code then the first 7 number of that number. Because someone...
    Hi zoaj,
    More then likely you have the fax set up to USE A DIALING PREFIX.
    Therefore it is automatically doing this, regardless of what you input.
    Follow the proceedure below ( which comes directly from the users manual for your printer type ) to change this. Delete the " USE A DIALING PREFIX " information.
    once that is done, it will no longer automatically add the prefix for you. :)
    I have BOLDED the relevant information below that pertains to this.
    Please take a moment to evaluate my solution. Your appropriate rating of my solution would be greatly appreciated.
    Thank you,
    Using the Fax Setup Utility Use this utility to adjust the fax send and receive settings. When you save these settings, they apply to every fax you send or receive. You can also use this utility to create and edit your speed dial list.
    • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Fax Setup Utility.
    • From Lexmark All-In-One Center All-In-One Main Page, click Fax Setup Utility.
    The following table describes the Fax Setup Utility tabs:
    On this tab:
    You can:
    Send
    • Enter your name and fax number.
    • Select a maximum send speed and a print quality for outgoing faxes.
    • Choose whether to scan the entire document before dialing the number.
    • Choose whether to use error correction.
    • Select when to print a fax usage report.
    • Select when to print a fax activity report.
    Receive
    • Choose whether you want to print a footer (date, time, and page number) on each page.
    • Automatically reduce an incoming fax to fit to the paper size loaded or print it on two sheets of paper.
    • Select whether you want to forward a fax or print it, and then forward it.
    Connection/Dialing
    • Select the number of times you want the machine to redial and the time between those attempts if the fax cannot be sent on the first try.
    • Select the phone line format you want to use (Pulse, Touch-tone, Behind a PBX).
    • Enter a dialing prefix.
    • Choose how (manually, if fax tones are detected, or after a certain amount of rings) you want to answer incoming calls.
    • Select a distinctive ring.
    Speed Dial
    Add to, create, or edit the speed dial list.
    Group Speed Dial
    Create a group number and name, and then add phone numbers to the group.
    Oct 11, 2008 | Lexmark Office Equipment & Supplies
    Panasonic UF-890
    Take the swinging drum cover off of the toer cartridge and throw it away. It's only for shipping. They come loose and block the paper path.
    Put the number you want to forward to in a one touch number position. (if you have to dial 9 for an outside line, be sure to put that into the one touch number also).
    Function 74 set 54 set 2 for valid set stop.
    Answer to last question, probably...not.
    Aug 28, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
    HP 1020 fax
    From manual: Insert document; press Scan & Fax button; dial number; press Start/Copy.  All pages will be scanned, number will be dialed, and scan will be transmitted.  If Memory Full displays, repeat procedure without using Scan & Fax button.
    Jul 15, 2008 | HP 1020 Plain Paper Thermal transfer Fax
    Scanning / faxing problem
    you will need to replace the adf assembly or the portion of adf roller which was dameged.
    typically one should open th ecover and take out the jam inth direction of papermovement only
    happy faxing
    omnipresent
    Oct 17, 2007 | Samsung SCX-4216F All-In-One Laser Printer
    "document jammed" but no paper in the machine
    There are a few sensors in the paper path which can easilt dislodged when pulling paper to rapidly from unit. Check all sensor flags and make sure they are moving freely.
    Jun 01, 2007 | Sharp UX P100 Plain Paper Thermal transfer...
    15 people viewed this question
    Seeker5211
    Seeker5211
