Question about Toshiba 2060 Copier
"side door open" displayed continuously
Have checked the left hand microswitch which seems to be ok. not sure about the switch on the centre of the door, what it does or how it works. could this switch be the problem
  • PI-Joe Dec 10, 2007
    The suspect switch appears to be an actuator type photosensor, could this if faulty cause the "side door open" sign to be displayed continuously
  • 69 Answers
Hi im jules_09.if it say side door is open the copier means the side door is open.replace the microswitch photosensors are not easy damage.
Posted on Dec 11, 2007
Model 720EF. Model No 059040415. The grill will not work. The top oven is still working but the grill light or fan will not come on at all. Stoves have told me over the phone that it could be the...
First things first. The top oven lights ONLY come on when the top oven is switched on. Operating the grill DOES NOT turn the lights on. If you wish to see what you are grilling, you have to turn the top oven control knob on to its first position as well as turning the grill on.
Secondly, the grill only works when the door is open. The grill does not work when you shut the door. When you open and shut the door, you should be able to hear the microswitch operating. It is located in the right hand side of the cooker, between the inner and outer panels - you cannot see it. I haven't seen the switch first hand but they normally come with an arm that contacts the door mechanism and the door mechanism operating, causes the arm to move, which causes a button on the switch to move and make the circuit. It has been known for the arm on the microswitch to bend with use so it no longer works correctly.
If you have checked all above and you hear the switch operating, then it could have failed. They are quite common, so if you can't get one from STOVES, try espares or someone like Maplin or RadioSpares.
The get to the microswitch you have to take the oven out of the housing and then take the right hand panel off. You should then be able to see it and check its operation.
All the best
Jul 26, 2011 | Stoves 720EF Electric Double Oven
Blinking display
jph, this is a classic symptom of the high voltage board failure. What board did you replace? The high voltage board is the one on the back side of the refer, left hand side. Catriver.
Sep 19, 2007 | Maytag MFI2568AE Side by Side French Door...
Logitech mouse left button does not work
That is a circuitry problem. You can try this following procedure if you can. --unscrew and open your mouse casing. --you need a tester (VOM) to test the wiring continuity. If one of the wire is open connection you can replace it with a new USB or PS2 connector. If all the wire is shorted, proceed to the next step. --Check if the microswitch is ok by testing the pin connection using the tester. Microswich has 3 pins, test only the soldered pins. When you press the switch, it might be shorted. If not, replace it with a new microswitch.
Microswitch and USB/PS2 connector are available in all electronics shops.
May 27, 2011 | Logitech Computers & Internet
I have a Sharp Microwave R-520 KS. And it stopped working. I thought it was due to a latch problem. But now I am not sure. I took it apart -- and the latching and microswitches seemed to be working...
Did you disconnect and test the three latch assembly microswitches with a multimeter or continuity tester? The top and bottom switch are normally-open, and the middle switch normally-closed. The lower switch seems to be the one that takes a beating and most often fails. It should be an Omron D3V-16G-3C25 and can be found on eBay for $10, or via an electronic parts supplier.
Nov 22, 2010 | Sharp R-520KS Microwave Oven
F9 error error code won't go away, even when turn oven off whirlpool RB260PXYB under counter oven checked air vent is OK, not clogged checked circuit board looks OK, relays look OK
This indicates a problem with the door latch switch. Try moving the latch around by hand to see if it will reset. If not this is likely the microswitch that control the mechanism. You will need to partially uninstall to acess. Once you acess it check it for continuity. It should have none when latch is open and some when closed. If you need diagrams or illustrations of your model enter your model # at the microswitch is #34 in the diagram
Jul 28, 2010 | Whirlpool Ovens
Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Aug 26, 2009 | Samsung RM255LASH Side by Side...
Display indicates "head open" does this require a new print head?
This is due to the microswitch on the left hand side. Either the small flag is not present or the head doesn't press correctly or the microswith is broken.
- change the microswith or strap the switch.
Jun 18, 2009 | Toshiba TEC B-472 Thermal Label Printer
After a cleaning of the group, we're not able to put it back
First step: You need to make the machine think that the group is in place.
Solution: This can be done by locating the three microswitches that need to be set. Turn machine on/Open the door/insert wastetray&dredgebox (switch One)/with plastic stir stix(noconductive material) active brewer microswitch located in the centre of the back wall/with plastic stir stix(noconductive material) active door microswitch located top right side behind door. All 3 switches need to be actived simutainiously with the power one. When installing the brewer, be sure that the microswitch activator slide on the back of the brew group itself is in the up position.
Note: if you do not know what I was talking about(microswitches) best not to attempt
Apr 13, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Dishwasher drains continuously
I dismantled and checked various parts of the dishwasher and everything seemed to be working. I noticed with a phase tester that the pressostat never got any voltage. This led me to check the microswitch on the door which turned out to be broken (never making any connection). This is the microswitch that turns off the dishwasher when someone opens the door.
So an unusual problem - two faults at the same time i.e. clogged and overflowing drain and broken door switch!
I ordered and fitted a new door switch and now the machine is working fine again.
Mar 27, 2008 | Dishwashers
Right Hand door swings open too fast
On the bottom of the door there is a part called a door closure kit.It operates like a cam. There are high and low points on the part that aid in the opening and closing of the doors. Do-it yourselfer project.
Nov 10, 2007 | Maytag MFD2560HES Bottom Freezer French...
106 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
