Won't print - Error message
Error message keeps coming up that says "the process "hpip" stopped unexpectedly with status 1."
I've restarted both the printer and my laptop several times and run all available updates.
  • 244 Answers
You may have to re-install your printer drivers to solve this problem.
Sometime it happens.
Please don't forget to rate this answer if it helps.
Posted on Sep 08, 2009
I was scaning my computer with an antivirus program and it gave me the option to restore my computer to get rid of the issue it had and when it restarted it gave me this message: Stop: c000021a {fatal...
If this continues to happen you will either need to use System Restore to bring the system back to a time before this happened or reload the OS. If you can get to a dos prompt, try running chkdsk.
Jan 26, 2011 | Gateway GT4022 PC Desktop
I have an HP Photosmart Premium C3009 all-in-one printer. Sometimes it refuses to print with a message that says: The process stopped unexpectedly with status 1. I've looked in the manual and find no...
I also experienced the "process 'mdns' stopped unexpectedly with Status 1" message a few days ago with my new HP 7250, and found two solutions. Here are a couple of potential cures:
I downloaded the shareware program 'Printer Setup Repair', then ran their 'Reset and Backup' routine. Restarted, and bingo! Printing was successful. But trying to run either the HP scan software or the HP Ink Widget from Dashboard were not so successful. Got a 'Scanner not found' message. I then went to the printer, tried doing a manual scan there, sending the scan to my PowerBook. Once again, bingo. The scan was sent to my computer, and now the HP software could see the printer. I've since restarted both my computer and the printer several times; printing and scanning are working fine.
Now the second way to fix the problem. It's kind of hokey, but it seems to work, and is what led me to the The process 'mdns' stopped unexpectedly" with Status 1" problem in the first place. What you do is just add an ethernet router, that one you have lying around the house somewhere, between your DSL or cable modem and your Airport modem. Huh?
Here's the deal: when I first bought my HP multifunction printer, my wireless setup was this: Cable modem>Xsense ethernet router>Airport extreme. Unpacked and hooked up the HP printer, and it all worked immediately, perfectly. Print, scan, check supply levels, all no problem. Way too easy. Then, about a week ago I realized that the Xsense ethernet router that I had in the chain was really superfluous, as we no longer use ethernet in the house; might as well eliminate that unnecessary link in the chain. So I changed my setup to a simple: Cable modem>Airport extreme. At this point printing stopped. Tried everything I could think of, no go. Always got the "process ' mdns' stopped unexpectedly with Status 1" message. Put the ethernet router back in the chain, printing/scanning went perfectly. This made absolutely no sense to me, but it worked.
Left my setup with the extra router for a day or two until I remembered about the shareware program 'Printer Setup Repair', described above.
Before doing any of these steps it's probably a good idea to run Disk Permissions (I always run it before and after any installation), just to be sure you're authorized to be using the HP software.
May 04, 2009 | HP Office Equipment & Supplies
My Dell Dimension 4400 running windows XP Home Edition stopped working and displays a blue screen with the following message: STOP: c000021a {Fatal System Error} The windows Login Process system process...
If that is not it reistall and to not loose you files click you partion durring the install and do not format it and click enter then click on leave partion alone
Dec 07, 2008 | Computers & Internet
"The process mdns stopped unexpectedly..."
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Are these printers connected with a LAN cable directly to the router, or are they wirelessly connecting to the router?
HP C8180 has built in wireless adapter and Ethernet according the Website at HP.
If this is connecting to the network wirelessly, check to see that it is connected to the Network, is your router using secure passwords for a connection to the network,
Your printer will need these passwords just as your computers would
If you connect the printer with a Lan Cable, it will be more reliable, and shouldn’t need a password to be on the network. And makes life a little easier...
Your internet provider has nothing to do with your Printer not printing; this is an Internal Network Problem. The settings or your network has changed.
The Printer should have a static IP address
Here is a link to a tip I put together about this subject,
http://www.fixya.com/support/r1173875-network_connected_printer_not_printing
If you need any further assistance, feel free to contact me...
Oct 26, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer not working
Hello Kathi1603,
Please try these few things to see if they will get your printer running again. First off, check to make sure your USB cable is properly connected at both the computer end and printer end. If that's OK..then power cycle the printer.. try to print a test page by going to the control panel from your start button and then select Printers and Faxes.. using the right mouse button for your printer, selcet Properties then pick 'print a test page' see if that works.. If that fails, then transfer the USB can;e to another USB port on your computer and retry all the previous things.. When all else fails, restart your computer and see if you can print a test page to your printer.. Hope this helps get you going..
Sep 28, 2008 | HP Photosmart C4280 Aio Printer
Login problem
hi selvathinesh
the problem is in ur operating system just reinstall it ..it would not show any messages trust me
shailesh
Mar 08, 2008 | Computers & Internet
Error msg status 1
sounds like a communication error, are you wireless?
try connecting direct.
Feb 05, 2008 | HP Photosmart C6180 All-In-One InkJet...
354 people viewed this question
jasbo
jasbo
